Onkyo DX-V500 Laser Disc Player - weird SMPS fault
  • dkneyle
    • Dec 2013
    • 445
    This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
    Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS board) reads about 3.5VDC whilst the spindle motor is turning.
    Things get nasty with a considerable heavier laser disc. As the spindle motor starts to turn the SMPS drops its bundle, the DBT goes into full brilliance and the SMPS buzzes softly. Shut off mains and it restarts OK again.
    I haven't risked trying it without the DBT in series. Should I risk it? Could it just be that the motor start current is causing the DBT to make the SMPS fail?
    By the way, the fluro display is also no-go. This picks up AC from the SMPS transformer. I haven't gone in to measure if it is producing AC; it's pretty simple, I assume it is.
    I'm a bit at a loss with this one. Normally having got a SMPS going it is plain sailing from there.
  • dkneyle
    • Dec 2013
    • 445
    Re: Onkyo DX-V500 Laser Disc Player - weird SMPS fault
    UPDATE: I took the risk and plugged directly into 230VAC. Laser disc spins up all OK. It appears the DBT was preventing the initial surge current required and tripping the SMPS into fault mode.
    The Unit still has a couple of issue I may or may not be able to sort out. Upon startup the sled motor makes whining sounds and won't move the sled. Give it a couple of reload attempts and it comes good.
    Also the flouro display needs to be sorted as to what is happening there.
    • RolandVossen
      Blu-Ray player Harman Kardon BDS 277 : SMPS IC blown
      by RolandVossen
      I just finished a repair of this player, the symptom was that it was completely 'dead'. I created this topic so it may benefit anyone else.
      The root cause was that one of the SMPS ICs was blown up, which was only visible after a lid on a cooling body was removed (see attached picture).
      The PCB type number is 40-K250HG-PWD1G.
      A service manual for the BDS 277 EU is available online (file name: BDS-275 & 277 & 575 & 577 Rev 1.pdf)
      I replaced the TOP257EN with a type that can handle more current:...
      05-23-2023, 02:16 AM
    • dkneyle
      MK1210 chip SMPS based supply - can I fire this up?
      by dkneyle
      Power supply used in an Onkyo laser disc player, circa 1995?
      Came into the Repair Cafe after another tech had a go and gave up. Only evidence I could see of a repair was C22 (2200uF) cap had been changed and D25 was missing. The power plug had been left disconnected so I figured I wasn't going to apply power until I'd checked everything out. I replaced the usual suspects: the SMPS chip ML1210, all the electros except the main charge caps, the 33V zener, replaced the missing high-frequency rectifying diode. I meticulously checked over remaining components with my meter and all seem...
      01-30-2022, 01:44 AM
    • Rolin
      Onkyo/Integra DBS-50.2 Blu-Ray Player - Won't turn on or shuts off immediately.
      by Rolin
      I have an Integra DBS-50.2 Blu-Ray Player that I haven't used in a while. Tried to turn on and it turned on for a brief moment with "hello" on the display then shuts off. Dead from that point on unless I unplug it and try again. Took it apart and checked a few well labeled voltages on the Power Supply board and found the 3.3V isn't measuring on the board (unless I'm misunderstanding what I'm measuring). I have a few pics of the board and schematics. There's a 4 PIN voltage regulator at location IC1301 with a part number 070XFC1 by Sharp that I believe should output 3.3V on PIN2,...
      09-07-2024, 12:11 AM
    • Junior††
      PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
      by Junior††
      Good Afternoon fellas,
      Issue:
      Disc is showing as not supported when a disc is put in.
      Here's what I've done, you can skip this if you just wanna know the question:
      - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
      - reflowed the disc drive connector
      -reflowed the chip in question (shown on image)
      - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
      Question:
      I...
      02-19-2025, 12:48 PM
      MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
      This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
      09-06-2024, 05:30 PM
