troubleshooting TV SMPS sequence
  • budwich
    • Jul 2015
    • 3097
    Re: troubleshooting TV SMPS sequence
    thanks for the recap. It does help contain me... :-)
    From all this, my read is that you aren't actually getting "true DC" coming towards the two output. Your meter is trying its best to get a DC value to some sort of waveform that has a "duty cycle" (in some form... my kingdom for a scope) that is significantly less than expected. The flicker on the bulbs likely confirms this.... as I don't think they would flicker if they were "seeing" just "noise" on top of a good DC value.
    I would think that the lack of stable standby voltage should be addressed first. Assuming it is a "contained circuit", it should be provide a good proving ground for your "restart" of things although potentially going from plug out to plug in, does take some time for things to be happy enough to get to "stable standby", so maybe a slow startup of standby voltage isn't necessarily bad although I would think this might be 10-15 seconds versus 2-5 minutes.
    As I asked earlier, having you rechecked the polarity of all the replaced capacitors to ensure that they are correct?
    • ilikesteel
      • Jul 2012
      • 284
      • usa
      #122
      Yes, I can double check the 6 caps I installed. remember, after I changed all the caps I had the same voltage readings of about 1-2v on the +12 and about 20V on the +24. that's just as it was with all connections from PS to boards connected. so I had same voltage results with old caps and new caps.
      what about the main cap reading of 360V. IS that low? I thought it would be more than that.
      I'll report back on the caps.
      thanks again,
      ilikesteel
      • budwich
        • Jul 2015
        • 3097
        I think perhaps you misunderstand about checking the polarity. You don't use you meter, look at the markings and ensure they agree with what the circuit board indicates.
        • ilikesteel
          • Jul 2012
          • 284
          • usa
          #124
          BudWich,
          I know exactly what you're talking about. I will check them in the morning to be sure I installed them correctly, + to +, and - to - on the board. correct polarity markings on the board against the markings on the caps.
          Thanks,
          ilikesteel
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8327
            360V on a 400V cap is still normal. You couldn't have 400V on a 400V cap. That wouldn't be any good at all.
            • ilikesteel
              • Jul 2012
              • 284
              • usa
              #126
              BudWich, CapLeaker, Budm,
              I checked the 6 capacitors to make sure I installed them correctly on the board. all caps have their NEG lead inserted into the board going through the hole marked as GND with the slanted white lines near the hole.
              with the 360V on the main and with NO load on the power supply for the +12 and +24; what would be keeping the voltage from being up to their required value? I would expect the stated voltage with NO load to be a few volts over the stated value of the supply, not under it.
              Now What, what do I do from here?
              Thanks guys,
              ilikesteel
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8327
                I almost think there has to be something bad with the transformer itself. Remember the blinking light bulb on the secondary? That shouldn't be. Now if we could proof that the primary input is not doing that then we'd be a step ahead again.
                See, as more juice you draw on the secondary, the PWM gives wider pulses to the FET's. Unfortunately that requires an O'scope. Problem is you going to need a isolation transformer for the PSU, you don't want to blow the O'scope up while fiddling around in the primary.
                • ilikesteel
                  • Jul 2012
                  • 284
                  • usa
                  #128
                  CapLeaker.
                  is this it, the end of the road?
                  remember when it was pulsing, I think it was when we had lower voltage on both supplies. right now, they are almost at operating voltages. perhaps I should run the lamp test again?
                  If it is pulsing on the primary side, what do you think would cause it? main cap?
                  thanks,
                  ilikesteel
                  • budwich
                    • Jul 2015
                    • 3097
                    I didn't go thru things "again", but iirc, your "bulb" test showed "reasonable" voltages on both legs (ie. within a couple of volts)... but there was some sort of "flashing" which just doesn't work for me... and probably for your meter as it is trying to "find" a "steady state" measurement of something that should be reasonably stable which the lights are telling isn't true, so your dc measurement is somewhat "fictitious".
                    So related to this, with bulbs attached, do you know what the input of the transformer is /was reading?. Maybe you lost a leg of the bridge rectifier such that the resulting incoming wave form is "gross" as opposed to "slightly rippled / frequency chopped"... :-)
                    Related to the above, you do need to count the flashes to get an idea of what you are "seeing" with your "bulb scope"... :-)
                    • ilikesteel
                      • Jul 2012
                      • 284
                      • usa
                      #130
                      BudWich,
                      what about the steady 360V at the main cap?
                      This is my first time going this deep into a power supply. It's virgin territory for me. I don't have a scope or an isolation transformer. the reason I thought I'd give it a shot at repairing, the set is an older one. I don't want to spend $50 or more on a PS. if I can fix it for my time and everyone else's contributions on this forum, I'd take a chance buying some parts to replace.
                      thanks
                      ilikesteel
                      • budwich
                        • Jul 2015
                        • 3097
                        no problem... you have to make do with what you got.... which means you might have to do a lot more than you would otherwise. But again, you have done lots of testing / changes and "stuff", I think you are probably close based on the help you got so far. If you had a scope ( and knowledge / help from the forum), you would likely have the answer fairly quickly.
                        I admit that I don't know enough about smps power supplies to be "dangerous"... but just to be curious especially around the "test techniques".
                        I suspect that if the input side had issues, there would be other issues / voltages apparent which doesn't appear to be the case... maybe.
                        Anyways, keep going... what have you got to lose.... time and frustation... :-)
                        So I will ask again, what is the flashing rate of the bulbs? and are they both flashing at the same rate? (I hope)
                        one other question, have you "swapped" the output "diode packages" between the two outputs to see if things change in some manner...... forget this, I see that the diode sets are not the same between the outputs.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8327
                          Originally posted by ilikesteel
                          CapLeaker.
                          thanks,
                          ilikesteel
                          We are kind of limited to do tests with a DMM and a load, makes it harder. Yes on the lamp test, because this way you can see the flickering, while measuring something else. Actually did you try to heat up the PSU with a hair dryer yet then turn it on? Desperate times = desperate measures. Everything goes.
                          I could rule out the main cap for sure if I had a picture of the ripple from a scope, or measure the ESR. Not having these, you can go and replace it with something close from the junk pile. At least 400V and preferably the same or more capacitance.
                          • ilikesteel
                            • Jul 2012
                            • 284
                            • usa
                            #133
                            CapLeaker,
                            alright, let me poke around and see what I can find. I'll update when I've done something.
                            thanks again,
                            ilikesteel
                            • ilikesteel
                              • Jul 2012
                              • 284
                              • usa
                              #134
                              CapLeaker and Company,
                              I did not try the hair dryer trick ....... yet. I could not find a CAP 180uf, 400V that I could replace the original cap with. I did manage to resurrect a tektronix 314 oscilloscope. attached are some pics of the front of the scope.
                              now what can I do with the scope to further isolate the problem? I do NOT have an isolation transformer.
                              Thanks,
                              ilikesteel
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8327
                                Check both of the secondary rails. Also post the Voltage / Time per division you used.
                                • ilikesteel
                                  • Jul 2012
                                  • 284
                                  • usa
                                  #136
                                  CapLeaker,
                                  how can I check for ripple at the same time? also, can I gnd the scope to the DC gnd of the PS?
                                  thanks,
                                  ilikesteel
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8327
                                    There is no problem on the secondary to put the o'scope GND to the Secondary GND.
                                    However DO NOT hook up the scope GND to the primary. You run the chance to blow up the scope, unless you have the power supply on a isolation transformer. You can also check with your DMM between scope GND and the point you want to hook up your GND to and see if you get voltage.
                                    TO check for ripple just shorten up the time and voltage on the o'scope. Every cap has some ripple. Maybe you should test that on a different PSU that is working first.
                                    also check youtube for "ripple on capacitor".
                                    W2AEW has something on youtube over the AC and DC coupling... also something to watch.
                                    • ilikesteel
                                      • Jul 2012
                                      • 284
                                      • usa
                                      #138
                                      CapLeaker,
                                      OK, will do and report back.
                                      thanks
                                      ilikesteel
                                      • ilikesteel
                                        • Jul 2012
                                        • 284
                                        • usa
                                        #139
                                        CapLeaker and Co,
                                        here we go again.
                                        powered TV on, NO LOAD on the PS, +12 and +24 are only on the PS.
                                        attached are 3 photos of the results I received.
                                        I used a X10 probe. and the GND line is the very bottom line on the scope screen.
                                        The first photo is the +24V.
                                        .5V per voltage/division
                                        .1 of a volt Time/Division
                                        looked like 18V-22V change, note the photo.
                                        The second photo is the +12V
                                        .2V per Voltage/Division
                                        .1V Time/Division
                                        looked like 10V-11V change, note the photo.
                                        There really isn't any ac ripple that I can tell. it looks like a square wave with the lower reading going up to the higher reading and back down.
                                        Both voltages exhibited the same as did the DVM readings.
                                        here's the KICKER. I decided to check the 5V-VSB.
                                        .1V per voltage/divison
                                        .2 MS Time/Division
                                        That's the 3rd photo. wow, what's going on here?
                                        thanks,
                                        ilikesteel
                                        • ilikesteel
                                          • Jul 2012
                                          • 284
                                          • usa
                                          #140
                                          CapLeaker,
                                          Guess photos didn't attach. here theya re.
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • madan1
                                            Troubleshooting half-bridge smps
                                            by madan1
                                            Hello everyone, I'm trying to fix what seems to be a half-bridge smps.
                                            The switching controller is sg2525a, which I have replaced with a brand new sg3525a. The low and high mosfets are 1c27ac 6n50. The mosfet driver is IRS2301S.
                                            Both mosfets were tested outside circuit with a component tester and seem to be fine.
                                            With oscilloscope I see ~65khz switching signal on both low and high outputs of the controller, but on the output of the mosfet driver there is switchig signal only on the low output (flat line on the high output).
                                            So I guess the mosfet driver is faulty?
                                            01-23-2025, 06:05 AM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • dkneyle
                                            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                            by dkneyle
                                            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                            02-01-2022, 02:08 AM
                                          • ShadowAi
                                            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                            by ShadowAi
                                            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                            03-15-2024, 10:46 AM
