Lg 49uf770v no picture
  • andrews7523
    • Apr 2015
    • 117
    • lancashire
    Hi guys in need of Help and assistance. The Tv comes on fine but has no picture which would believe me to be the Tcon board in my experience. The difficulty I'm having is the Tcon board which is in my set is not the same as the ones listed on Ebay as i found out to my expense. The Tcon that is in my set only has numbers but no actual part number. I was told by a frien that the Tcon board can be found by what screen is in the Tv.......
  • andrews7523
    • Apr 2015
    • 117
    • lancashire
    Re: Lg 49uf770v no picture
    i put the picture of a sony screen by accident pls disregard this picture
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Do you get backlight ?
      • andrews7523
        • Apr 2015
        • 117
        • lancashire
        yes
          Did you check the DCV at both ends of the SMD fuse on the T-CON against chassis GND?
          So those pictures in post 1 are all wrong?
          • andrews7523
            • Apr 2015
            • 117
            • lancashire
            i don't know how to do that, if there is any low voltages is there a way of repairing the tcon?
              So what kind of tools do you have?
              So pictures #5 on post 1 is the TC-ON board you have?
              • andrews7523
                • Apr 2015
                • 117
                • lancashire
                yes thats correct budm picture 5 is the tcon. I have a multi metre
                • vinceroger69
                  • Mar 2012
                  • 6714
                  hi put your multi meter on dc volts with the tv turned on place the black probe on the metal tv chassis and touch the red probe to each side of the white fuse on the tcon board write down the voltages thanks, just be carfull you dont slip taking voltages as you dont want to short anything out!
                  • andrews7523
                    • Apr 2015
                    • 117
                    • lancashire
                    wheres the white fuse? Do you mean each side of where the tcon connector goes in?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      where the t con connetor socket is just above it theres a little white fuse has a o on it just touch the red probe tip to each side of it and take voltage reading.
                      • duffar
                        • Aug 2016
                        • United Kingdom
                        Hey, I have the exact same problem. my LG 49UF770V has no picture but the sound is working and the backlights come on. I have swapped out the T-CON board for a new one but the result is the same! Anyone have any suggestions? I've just ordered a multi-meter so I will take some readings tomorrow. What voltage should I be reading on that fuse? 5V?
                        • andrews7523
                          • Apr 2015
                          • 117
                          • lancashire
                          Mine had the wrong mainbaord fitted
                          • CapLeaker
                            Leaking Member
                            • 8195
                            Not to start anything... but how did you get to that conclusion?
                            Did you actually verify the LVDS signal on a oscilloscope?
                            • andrews7523
                              • Apr 2015
                              • 117
                              • lancashire
                              Because the sticker on the board said 55uf770v and mine was a 49"
                              • CapLeaker
                                Leaking Member
                                • 8195
                                So the TV must have never worked out of the box?
                                • andrews7523
                                  • Apr 2015
                                  • 117
                                  • lancashire
                                  Thats correct
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    some tvs though you can alter the panel size in the service menu so the mainboard may of worked then got faulty or maybe a previous owner swopped it out, the main thing is the set is working now so alls good.
                                    • andrews7523
                                      • Apr 2015
                                      • 117
                                      • lancashire
                                      What setting does the multimeter have to be on to check the fuse? Ohms?
                                      • CapLeaker
                                        Leaking Member
                                        • 8195
                                        Depends on how you test it. While the DUT powered off, test the fuse with your DMM in ohms, continuity or diode mode. A short or beep tells you the fuse is good.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
