Vizio M501d-A2R screen jumping from normal to horizontal lines every 2 secs
  • snake91876
    • Feb 2013
    • 236
    TV flashes from a normal screen to lines every two secs anybody know a fix.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Vizio M501d-A2R screen jumping from normal to horizontal lines every 2 secs
    Freeze spray the left and right side of the panel. See if it stops doing it.
    • snake91876
      • Feb 2013
      • 236
      Where do I spray the Panell edges on the front
      • snake91876
        • Feb 2013
        • 236
        anybody got any new ideas
        • doesntmind
          • Feb 2014
          • 65
          • usa
          I have the exact same issue, wondering if i should replace tcon
          • budwich
            • Jul 2015
            • 3097
            disconnect the tcon to panel cables, one at a time and see what the result is. That may tell if its a panel problem... or possibly a tcon problem.
              Gate Tab bond failure.
              • brad2157
                Vizio E70-E3 Two white vertical lines
                by brad2157
                I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                Replacement main board - Boots up fine, but starting...
                12-13-2021, 05:11 PM
              • x_orange90_x
                Vizio V585-J01 dancing lines and image doubling
                by x_orange90_x
                I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                I swapped...
                06-12-2024, 07:57 AM
              • viking509
                vizio e65 e3 LED tv color vertical lines center tv only
                by viking509
                I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                03-21-2023, 12:48 AM
              • rapid911
                Vizio M58Q7 colored horizontal lines
                by rapid911
                Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
                05-28-2023, 04:17 PM
