vizio e65 e3 LED tv color vertical lines center tv only
  • viking509
    • Mar 2023
    • us
    I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the cable strips from the tcon board to the buffer boards?
    Not a lot of previous experience with tv repair. The tv has already been replaced (wife) lol but I still like the tv and I'd like to fix it. I guess if someone could break down a progression of actions to take that would be a big help. Youtube and shop jimmy have only limited scope and never have a complete series of actions to take.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: vizio e65 e3 LED tv color vertical lines center tv only
    Take the back off and retrace your steps, you've either not plugged something in right or damaged a tab bond.
    • howardc64
      • Jun 2017
      • 653
      searched for E65-E3 youtube videos. Found 2 (1 by shopjimmy) and both were terrible
      https://www.youtube.com/watch?v=-GC5...nnel=ShopJimmy
      https://www.youtube.com/watch?v=SzXa...el=scottyfixit
      I'm assuming you didn't damage the flex cable between panel glass and buffer boards at the bottom of the LCD panel (shopjimmy video called this buffer boards)
      shopjimmy video is terrible implying removing the buffer board before removing the panel ( would destroyed the panel by peeling off the tab bonded flex ). guy in the other video was handling the LCD panel without suction cups with bare hands (easy to damage)
      Also check the flex cable between t-con and buffer board is seated properly? cable to connection fitting usually have notches on both sides and need to be keyed in properly.
      I'm in Seattle. PM me and perhaps a phone call to go over your dis/reassembly method would be helpful.
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • brad2157
        Vizio E70-E3 Two white vertical lines
        by brad2157
        I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
        Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
        Replacement main board - Boots up fine, but starting...
        12-13-2021, 05:11 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        Sadly it has vertical lines at the left and one line in the middle-right.
        I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
        I have factory resetted the TV as well but also with no luck.
        I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • visionbluedemon
        Help. Sony kd-65x85dj vertical lines
        by visionbluedemon
        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
        tried blocking LC lines too, but same results
        is it lcd panel issue or tcon board issue?...
        07-25-2025, 04:56 AM
