Vizio V585-J01 dancing lines and image doubling
  • EazyBone
    • Jun 2023
    • 1363
    • United states
    Yes small TV. Can buy them working on marketplace for 100-150$. As diah said probably some sort of damage somewhere. It's a panel problem.. move on to next TV
    • Diah
      • Feb 2013
      • 6614
      Originally posted by x_orange90_x
      Attached video shows the purple morphing in over the course of 1 minute.
      you have complete the downside have lines where the effect... this why need remove bezel to check the rand if.... however you can live with it
      • Diah
        • Feb 2013
        • 6614
        yours photo condition i saw many.. all damage on glass , this why the downside which it show an this photo remain visible after masking
        • x_orange90_x
          • May 2015
          • 765
          Ah, I understand now. The bottom portion does look similar in the before and after images.
          • x_orange90_x
            • May 2015
            • 765
            I may open this up and take a look for damage to the glass. Quick question though, would removing the bottom side COF tab prevent the color from morphing, or would it simply make things worse? If there's no way to stop the purple from showing up then I'll probably just trash it. Me or someone else could probably live with the shadow band, but not the purple.
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • brad2157
              Vizio E70-E3 Two white vertical lines
              by brad2157
              I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
              Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
              Replacement main board - Boots up fine, but starting...
              12-13-2021, 05:11 PM
            • viking509
              vizio e65 e3 LED tv color vertical lines center tv only
              by viking509
              I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
              03-21-2023, 12:48 AM
            • rapid911
              Vizio M58Q7 colored horizontal lines
              by rapid911
              Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
              05-28-2023, 04:17 PM
