Vizio M58Q7 colored horizontal lines
  • rapid911
    • May 2023
    Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance.
  • TVAddict
    • Jan 2022
    • 76
    • Caribbean
    Re: Vizio M58Q7 colored horizontal lines
    Could be anything from the t-con to the panel driver board, sometimes even a faulty power supply.
    Could try cleaning the ribbon connectors.
    Does it get any worse?
    Does it go away?
    • rapid911
      • May 2023
      Does it go away?
      I tried to clean the ribbon connectors using some isopropyl alcohol, but it didn’t works. Nothing is changed. What do you suggest to do?
      • rapid911
        • May 2023
        I tried also to apply some tape on the ribbons. The lines disappears but the screen lose some color. Could be the tcon the issue?
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • JRyan
          Vizio 39" horizontal lines
          by JRyan
          Found yet another TV by the road that has lines across the whole screen. What is causing this?
          12-22-2023, 10:02 PM
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • brad2157
          Vizio E70-E3 Two white vertical lines
          by brad2157
          I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
          Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
          Replacement main board - Boots up fine, but starting...
          12-13-2021, 05:11 PM
        • ggil44
          Sony XBR-65X750D Horizontal lines bottom of screen
          by ggil44
          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
          05-30-2023, 07:51 PM
