Look for Datasheet
  • dabone
    • Aug 2010
    • 30
    Look for Datasheet
    I'm working on a VR-4085DF Tv, and I'm looking for the datasheet for the inverter chip.
    It's a SEM2107, on a Samsung branded inverter board labeled
    SSI_400_14A01.
    It's got the 2 seconds to black, and I'm thinking I might have bad lamps.
    Later,
    dabone
  • paulstef
    • Dec 2013
    • 724
    Re: Look for Datasheet
    please post a picture of the chip, one where we can see what's printed on it. What package is it?
      SEM2107 = Samsung ElectroMechanics part. You would be lucky to find a datasheet, it is a custom Samsung part. However, you can possibly find the schematic of the power board - is there a BN44 number printed on the power board somewhere?
      • topng
        • Dec 2013
        • 56
        • ISRAEL
        hi
        SEM2006=sem2107=sem217
        kim o
        • paulstef
          • Dec 2013
          • 724
          Originally posted by topng
          hi
          kim o
          Nice.
          • braxton
            • Nov 2009
            • 146
            I noticed the SEM2107 is a 28 pin IC and SEM2006 is a 24 pin IC so how are they the same?? Does that mean the two pins at the end on either side of SEM2107 are not used or needed??
            • braxton
              • Nov 2009
              • 146
              I've found a wiring diagram of SEM2107 but I don't know how to interpret it. Can someone tell me which pin is SDT (shutdown timing capacitor) and which pin is OVP (over voltage protection) based on the attached diagram?
                Not possible to tell from that diagram. Possibly 4, 21, or 25 are the timer pins, but if you short the wrong one you may damage the IC.
                  It is not compatible, as you can see pin 14 and pin 15 are used.
                  http://www.shopjimmy.com/samsung-lj9...-inverter.htm#
                  Picture provided by shopjimmy.
                  • braxton
                    • Nov 2009
                    • 146
                    That's what I thought but many internet sites (and a post earlier in this thread) indicate that SEM2107 and SEM 2206 are the same when clearly they are not.
                    I'm hoping I can track down a SEM2107 datasheet or pinout...
                    • braxton
                      • Nov 2009
                      • 146
                      Does this attachment help??
                      • braxton
                        • Nov 2009
                        • 146
                        Ok, so not being 100% sure on the inverter IC pinout, I decided to disassemble the panel down to the CCFL bulbs. As soon as I did I found the problem. One lamp was black and actually broken at one end. When I power up the set, all other lamps come on for a second, although they do not glow all the way across before they turn out again. There are 14 lamps and the 10th one down is bad.
                        My next question is - can I remove the bad bulb and then trick the Inverter IC to think that the bulb is good? I don't think I will come across any spare bulbs for a 40" TV any time soon...
                        Thanks for the help!!
                        • michael dranfield
                          • Jan 2016
                          • 232
                          • England
                          Could you possibly send this diagram to my e mail so I can print it out ?
                          md@digifixltd.co.UK
                          Many thanks in advance.
                          • braxton
                            • Nov 2009
                            • 146
                            md@digifixltd.co.UK
                            Done.
                            Anyways, back to my question of a "bypass", I'm thinking a resistor method might work (I'm not clear on where it goes though) or maybe removing the check circuit for the bad bulb and tying into check circuit for a good adjacent bulb???
                              No, I don't recommend you bypass bulbs as doing so can cause the transformers to fail and burn up, posing a fire risk.
                              • michael dranfield
                                • Jan 2016
                                • 232
                                • England
                                If you look at the output from each transformer there is a capacitive potential divider usually consists of a high voltage capacitor about 5pf on the hv side and a 10nf cap to ground.this is where the voltage is sampled from the middle of the two caps will have a small voltage of a couple of volts which is proportional to the high voltage .if a lamp goes open circuit the hv rises due to no load and the voltage at the tap point in turn rises and triggers the open lamp shutdown circuit in the sem chip.to disable the open lamp protection for an individual tube you need to short the middle of the potential divider to ground connected to the tube which is not lit.however on this board I think the hv capacitor is formed by two copper plates on the top and bottom of the board rather than a blue disk type cap .
                                • michael dranfield
                                  • Jan 2016
                                  • 232
                                  • England
                                  So for example looking at the bottom transformer T104 if you were to short the junction of c418 and r438 to ground which is the middle of the HV potential divider this will disable the open lamp protection circuit of the lamp connected to T104. Top end if this makes sense.
                                  • braxton
                                    • Nov 2009
                                    • 146
                                    Thanks for the info. I am trying to understand what I can try. Bear with me as this is new for me. The board has 14 bulbs. From top to bottom, Transformers T101, T102 and T103 each handle 4 bulbs while T104 at the bottom handles the last 2 bulbs (and is a smaller transformer). I'm not sure I'm reading the schematic correctly, but for non-working bulb 10 would I short the junction of R426 and C411 to ground to remove the check?
                                    Thanks again.
                                    • braxton
                                      • Nov 2009
                                      • 146
                                      Also, based on my assumption, would I short the region indicated by the red circle (which can be traced to a pin on the transformer T103 low side) or the yellow circles in the attachment below?
                                      Or am I completely off base?
                                        You can fool the protection circuit to make it think that is there is good lamp in place but you must also disable the high voltage from the transformer.
                                        • SoulFreeze
                                          Help finding datasheet for component marked G34662
                                          by SoulFreeze
                                          Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
                                          Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
                                          Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
                                          05-01-2025, 03:56 AM
                                        • Rainbow_Chameleon
                                          Searching Datasheet for AM113 IC by O2MICRO
                                          by Rainbow_Chameleon
                                          I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
                                          Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
                                          If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
                                          On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
                                          So if anyone has a datasheet or at least...
                                          01-23-2025, 12:03 PM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • chth96
                                          Is there any datasheet for nichicon RT(M) series?
                                          by chth96
                                          A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                                          https://www.badcaps.net/forum/troubl...e-been-blew-up
                                          and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                                          But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                                          I have spare console...
                                          11-28-2023, 03:36 AM
                                        • vjsmoreira
                                          FA5205P Datasheet
                                          by vjsmoreira
                                          Hi All,
                                          I can't find the FA5205P datasheet, can someone provide a link to it?
                                          I believe is a opamp.
                                          I'm trying to repair an old ROKSAN CD player.
                                          Today, 02:58 PM
