Hitachi LE49S508
  • krygods
    • 257
    Hitachi LE49S508
    I came across this Hitachi TV that doesn't do anything when plugged in.
    No standby light, power button does nothing.
    The power supply is on though because all voltages are present except BL/ON.
    Here are the Voltages
    CON801
    PS-O/F - 3.2VDC
    PB adj - .14VDC
    PB O/F - 0VDC
    GND
    GND
    GND
    GND
    +12v - 12.37VDC
    +12v - 12.37VDC
    +12v - 12.37VDC
    +12v - 12.37VDC
    CON901
    GND
    KEY 0 - 3.3VDC
    KEY 1 - 3.3VDC
    LED G - 3.28VDC
    LED R - 0.07VDC
    IR IN - 5.16VDC
    GND
    +5V - 5.2VDC
    CN4
    LED 1+ - 119VDC
    LED 2+ - 89VDC
    LED 3+ - 60VDC
    LED 4+ - 31VDC
    LED 5+ - 6VDC
  • CapLeaker
    Leaking Member
    • 8215
    Re: Hitachi LE49S508
    burnt out back light leds?
    • krygods
      • 257
      can they be tested for open or short without taking apart the panel?
      • CapLeaker
        Leaking Member
        • 8215
        Look at CN4. LED voltages are all over the place between the strings. The led's are bad this way or the other (shorted vs open). In order to repair that, the panel must come apart and each individual LED to be tested.
        • krygods
          • 257
          Sounds like what I was thinking. I opened the panel up last night and got through testing the first two strips of LED's, accidentally damaged one of the first few removing the lens so I'll be replacing that with one from another LED strip. Let you guys know what I discover after testing all 5 strips.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            You can glue the lense back on woth hot glue saves replacing it, you can test each led with a Dmm.
            • krygods
              • 257
              I damaged the actual LED not the lens, the led still tests good with a DMM it just doesn't light up.
              • krygods
                • 257
                I just got finished testing all the LEDs and regluing the lenses.
                All LEDs test good and light up when checked with a DMM.
                Anything else that could be causing this issue?
                  Can I see the pictures that show the wires from the LEDS that go to the LED connector?
                  • krygods
                    • 257
                    Here's a pic of how the strips are connected and also a pic of the connector on the PSU
                    Let me know if you need better pics or of something else
                      OK, so it does have 5 LED strings and they are connected in series as one big string.
                      Your readings at CN4 do not look right for the string #5.
                      CN4
                      LED 1+ - 119VDC
                      LED 2+ - 89VDC
                      LED 3+ - 60VDC
                      LED 4+ - 31VDC
                      LED 5+ - 6VDC
                      So per your readings:
                      String #1 has 30VDC Voltage drops (119V - 89V =30V).
                      String #2 has 29VDC Voltage drops (89V - 60V =29V).
                      String #3 has 29VDC Voltage drops (60V - 31V =29V).
                      String #4 has 25VDC Voltage drops (31V - 6V =25V).
                      String #5 has 6VDC Voltage drops, it the last string to has Cathode to GND return through current sensing resistors..
                      So are you sure the string #5 is OK? and those readings are valid?
                      • krygods
                        • 257
                        I just re-checked all the LEDs in strip 5 all show a voltage drop of 841-845 and light up with the probes reversed.
                        I re-checked all the voltages at CN4 all remain the same as above.
                        When probing for voltage at CN4 the strips of LEDs light up dimly.
                          "When probing for voltage at CN4 the strips of LEDs light up dimly.' That is good information.
                          So how many LEDs are there in one strip? That will tell us what the Drive Voltage at LED 1+ should be.
                          • krygods
                            • 257
                            12 LEDs per strip
                              12 LEDs x 5 strips = 60 LEDs, so the minimum drive Voltage should be 60 x 3Vf = 180V (or 60 x3.6Vf = 216V), so the drive Voltage of 119V is too low.
                              Need to look at the driver circuit next.
                                Need good pictures of this area.
                                  OK, I trace out the connections.
                                  Seems to me that the boost converter is not working. You should check the capacitance of that GREY rectangular cap, and get the P/N of that 8-PIN SMD IC.
                                  • krygods
                                    • 257
                                    Ok here is a picture of the section you want to see. Let me know if this is a clear enough picture otherwise I'll see if I can figure out how to get a clearer picture while zoomed in.
                                    • krygods
                                      • 257
                                      I don't have any means to test the capacitance right now, the transistor tester / esr meter that I bought from ebay isn't working properly it keeps telling me that its testing a mosfet when there is nothing being tested and tells me that every capacitor is unknown / damaged.
                                      Here is the P/N of the 8 pin IC F28543 and below that is 083350CP
                                        Please check the resistance between LED 5+ pin and the chassis (LED connector in place) to see what you get.
                                        Nothing come up with that IC F28543 yet.
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • sotodefonk
                                          Help finding the correct model of a T-Con board on my Hitachi TV
                                          by sotodefonk
                                          Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                                          I opened the tv to access the board and took the shared pictures of the T-Con board.
                                          I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                                          I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                                          Inspecting...
                                          06-28-2024, 04:39 PM
                                        • dicky96
                                          Hitachi V19B01922 Channel Tune problem
                                          by dicky96
                                          Hi Guys
                                          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                          He also has an LG TV, so three screens in the bar
                                          I installed three Satlink ST-6503 DVB-T Modulators
                                          This model https://www.aliexpress.com/item/32916553905.html
                                          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                          02-09-2023, 09:20 AM
