Hitachi LE49S508
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Hitachi LE49S508
No! unless you want to blow up the MOSFET and other parts by forcing on hard, it is made for switching ON and OFF at frequency.
Did you check that boost Diode (as marked in the picture I post earlier) to see if it is OK?Never stop learning
When you take voltage readings across the led strings, do you read from led1+ to chassis or do you read from led1+ to led1-?Comment
I have this same tv, It has the red standby light when you plug it in but if you power on the light goes black but nothing happens.. I was testing voltages all over following the conversation in this thread but holy smokes its crazy..
Anyways my voltages are as follows:
CON801
PS-O/F - 3.15VDC
PB adj - 3.22VDC
PB O/F - 3.12VDC
GND
GND
GND
GND
+12v - 12.29VDC
+12v - 12.29VDC
+12v - 12.29VDC
CON901
GND
KEY 0 - 3.28VDC
KEY 1 - 3.28VDC
LED G - 0.03VDC
LED R - 1.68VDC
IR IN - 5.14VDC
GND
+5V - 5.16VDC
CN4 (with tv on all are 0)
LED 1+ - 0vDC
LED 2+ - 0VDC
LED 3+ - 0VDC
LED 4+ - 0VDC
LED 5+ - 15.6VDC
I was guessing a bad LED strip, does that sound reasonable?
ETA: I get 124vdc at the booster diode.Last edited by mrwomp; 08-12-2016, 11:18 PM.Comment
Have you checked the voltage with the leds removed from the connector.
Reading Budm's comments in an earlier post in this thread it looks like there should be approximately 30V drop across each strip. Think I need to read further on to see what the conclusion was.Last edited by dick_barton; 08-14-2016, 11:41 AM.Willing to help but I'm no expert.Comment
I have not, I will do it right now.. I have followed every other step in this thread and everything measured up to what budm said it should have been.
If I remove the connector I get 125.6vdc at led1+ but 0 on the rest. If I read it as I turn the tv on it jumps from 0 to 199vdc and after about 1 second it falls back to 125vdc again.Comment
Reading through the threads the led voltage when the backlights were forced on was 204V. You have 199V with nothing connected which is quite close to the 204V.
I'm suspecting bad leds but would wait for others to verify.Willing to help but I'm no expert.Comment
I hope you didn't mean "I might just break it down"
Be careful when removing the panel.Willing to help but I'm no expert.Comment
You now need to check every led because you may well have more than one faulty. If one goes short circuit it puts a strain on the rest in that circuit and they start to go down like fairy lights.
https://www.youtube.com/watch?v=RxwdC7V5Ue0Last edited by dick_barton; 08-14-2016, 01:46 PM.Willing to help but I'm no expert.Comment
I'm going to check them and keep the good ones in a box somewhere for future use. I wanted to use this tv for learning a bit more and I think I learned a fair bit reading and following this thread. there is no bezel on the tv, the plastics are broken, so I think I will salvage the good light strings and the boards and trash the rest.
Thanks for helping, I just needed that one "I think it may be the led" to push me to go that far.
Again thank you for the help, look forward to seeing you around the forums.Comment
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by wolf1976hi
i have the above tv and the display starts distorts the display at only in applications like you tube
after and on the didital channels
now without connect the antenna only the image of itsselfs tv i have the image i have in attach
i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?... -
by massimomaxChiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
spero che qualcuno può averlo per riprogrammare eprom. grazie
Post in English !!!
I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
by dragometinTV Model: Hitachi 40HYC42
Power Supply: 17IPS71
MainBoard: 17MB95M
Panel: VES400UNDS-2D-NO3
When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
Is there any variants on 17IPS71 power supply's?
UART output pins 10 and 12 on scart connector:
...Code:12:24:04.595
by sotodefonkHi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
I opened the tv to access the board and took the shared pictures of the T-Con board.
I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
Inspecting...2 Photos - Loading...
