Sony KDL50EX645 Six Blink
  • jetadm123
    • 2169
    Re: Sony KDL50EX645 Six Blink
    Thanks for sharing. If it was indeed a design defect, it would be interesting to know if Sony used different part numbers/values from the originals.
    • Allwiredup
      • May 2016
      Hello guys, newbie here, I have also have the 50ex645 tv with the 6 blinks, I'm looking on my power supply for the smd R602d, but on the board R602A-C are smd but the R602D is just a 1/4 watt resistor that is on the top of the board, not the backside, am I looking at the right one?
      • Power sony
        • Aug 2016
        • Spain
        Hello guys
        I need to buy the main board because nobody can repair it in my city.
        could you give me the model number or number part
        Thanks in advance
        • salongaopm
          • Mar 2013
          • 13
          • usa
          Originally posted by ljintexas
          Just got repaired smps back from Sony service agent. They charged me $85 including Priority Mail return shipping. After close inspection here is what I found that was done:
          Replaced R602 A-D
          Replaced IC601
          Replaced IC303
          Replaced D305
          Replaced ZD306
          Works like a champ.
          LJ
          can anyone provide the part number for the above parts(mouser or digikey)?
          thanks!
          • Louis82
            • Feb 2012
            • 240
            Hello there.
            What is R602D resistors value ?
            Thank you.
              Originally posted by Louis82
              Hello there.
              Thank you.
              R602A~D are all same resistance.
              What does it show on your board?
              http://assets.shopjimmy.com/media/ca...-11-bottom.jpg
              • Louis82
                • Feb 2012
                • 240
                Hi Budm,
                Thanks for responding. R602 from A-C are SMD resistors and D is mounted 1/4 w. Colors :RED - PURPLE - GREEN - GOLD. Is this 2.7 Mega Ohms ?
                • Louis82
                  • Feb 2012
                  • 240
                  Ok. SMD's are 2.7 apparently. Can't find this resistor in any of my scrap boards.
                  • Louis82
                    • Feb 2012
                    • 240
                    In case anybody gets confused like I did. Here is a picture of R602D
                      OK, I see now, 602A ~C are SMD, R602D is through-hole resistor under the heatsink. It looks like 2.7M Ohms.
                      • yurivictoria
                        • Jun 2017
                        Replaced in mine: R602D (through-hole resistor under the heatsink) because it read over 20ohms and now tv works again. thank you everyone in this forum, super helpful
                        • BunnyFooFooSR
                          • May 2018
                          I replaced same resistor but with a 2.7m @ 1/4 and she booted, was a salvage from the Dump, total cost $1, boost to pride "Priceless". I love to keep things out of the dump way to much value going into dump. (This must have been a display model still had blue protective peel away plastic on it)
                          Thank you Badcaps.net members.
                          • PabloDiablo
                            • Jan 2019
                            So I have the same model and same issue...
                            I am very much a novice but think I can handle replacing a resistor! My only question regarding this particular one is since it resides under the heat sink, how do you get to it? remove the cage? any advice would be much appreciated.
                            thanks
                            • alfatv
                              • Sep 2020
                              • 353
                              Good tip, fastest repair ever!
                              • RDC55
                                • Dec 2017
                                • 180
                                Does anyone know the actual value for R602D? I pulled the part to confirm it is open, but I am still undecided on the actual value. It appears to be Red Violet Blue Gold, which would make it 27 meg. The others R602A,B,C are SMD and marked 2704, so 2.7 meg.
                                And here is a Spanish speaking gentleman saying it is 27 ohms, but I know you can't believe everything on YouTube
                                https://www.youtube.com/watch?v=r94EW6CuJmo
                                Edit - Nevermind, I seemed to have missed page two which seems to identify this as a 2.7 megohm resistor.
                                • RDC55
                                  • Dec 2017
                                  • 180
                                  Nevermind, I managed to not see page two and the consensus seems to be 2.7 megohm.
                                  I attached a pic (best I could do) and it looks like Red Blue Green Gold
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #37
                                    Strange, but it looks like 2.6 Mohm. Middle band looks blue in your photo.
                                    • RDC55
                                      • Dec 2017
                                      • 180
                                      I guess it just depends on the light - under a bench top microscope the second band appears to be violet, but the third band looks blue. The photo was taken with a digital microscope and video captured, and I agree the second band looks blue. I am going with the 2.7 meg since the SMD R602A,B,and C are clearly marked 2704.
                                      I guess out of curiosity as I didn't see it addressed in this thread is why is the resistor opening and is it offering some protection because of some event? It seemed odd that they used 3 SMD resistors (3mm x 2.2mm) and then the oddball through hole at what appears to be 1/8 watt.
                                      • R_J
                                        • 9633
                                        I suspect they used a through hole resistor because of the distance to pin 5 of the ic, They likely could have used another 2.7m smd resistor and then a jumper wire.
                                        They often use a few resistors in series when connecting the high voltage (385vdc) from the main caps dc to an ic. likely to provide some arc protection.
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #40
                                          There is a maximum safe working voltage you can apply to a set of resistors dependant on their composition and is why as RJ says, they spread any high voltage across a set of series resisitors which drops the voltage across each of them to a safe working voltage.
                                          • EazyBone
                                            Sony 85x90CK 4 red blink
                                            by EazyBone
                                            So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                            But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                            Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                            Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                            07-18-2025, 12:53 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
                                          • Famo
                                            Sony KDL-52Z4500 6 Red LED Blink
                                            by Famo
                                            Hello badcaps forum.
                                            I have a Sony KDL-52Z4500 TV that needs a little trouble shooting. History of the TV: I bought it about 14 years ago. One year ago, I took it off the wall to move to another house. During the past year it sat in its original packaging - even with the thin film plastic bag/cover that it gets shipped in, cardboard box and all. Last week I unpacked it to mount it in the garage for my wife's gym that she has setup. Turned it on, set up a chormecast on it for her, and all was good for a week running like always (brownie points for me from the wife ).
                                            06-09-2023, 10:21 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • EazyBone
                                            Sony XR-77A80J OLED 5 Blink
                                            by EazyBone
                                            Another eazybone post took on this OLED now.
                                            Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                            I'm thinking I have a power board issue though, which is one of the options
                                            Now to check pin voltages from PSU to main and PSU to tcon
                                            Pic 2
                                            1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                            2 bl err -- 0.16
                                            3 evdd on --0
                                            4. Ac off det 3.187
                                            5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                            6 stby...
                                            10-24-2023, 09:09 PM
