Transistor for TV problems
  • Cue
    • Mar 2015
    • 34
    I'm a noob when it comes to these types of things, I have a transistor that i tested, it seems to be a bad one. I'm trying to order a new one from Amazon but i don't know which one I should get, can someone please post a link from Amazon on which type of transistor I should get,here's a pic of the bad transistor.
    http://imgur.com/17ya9Ae
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Transistor for TV problems
    Image is broken, Please upload using the attachment function under "Go Advanced"
    • tw2005
      • Oct 2011
      • 6458
      TOSHIBA Field Effect Transistor Silicon N Channel MOS Type (DTMOS II)
      TK15J60U is the full number
      600V 15A
      http://alltransistors.com/mosfet/crs...=0.3&caps=SC65
      https://www.digikey.com/product-sear...words=tk15j60u
      UTSOURCE is in china, will take weeks
      http://www.utsource.net/TK15J60U.htm...FREDvAodGXsAjQ
      http://www.ebay.com/dsc/i.html?_from..._odkw=TK15J60U
        How is it tested out? Shorted? What circuit section is it in?
        • Cue
          • Mar 2015
          • 34
          I had the negative lead in the middle, I put the positive lead on the left side It tested OL and on the right side it tested .259
          • tw2005
            • Oct 2011
            • 6458
            maybe explain to every one the fault + Tv model photos of boards etc
            Chances are that FET is ok
            And like newtothis said, click on advanced, manage attachments and upload direct, max size of image is 2000 x 2000 so you may need to resize the photos
            • Cue
              • Mar 2015
              • 34
              It's a Vizio E470VL, picture on the TV doesn't come on but the orange standby light changes from orange to white when I press power on the TV.
              • tw2005
                • Oct 2011
                • 6458
                Dare I even try to get involved as my LCD knowledge is slim but if the front led changes colour have you then checked what DC voltages are present on the PSU at the connectors?
                Does it remain white? If you get a flashlight and try to put some light on the TV can you make out an image?
                there maybe other posts on Vizio E470VL. tried a search on model yet?
                • tw2005
                  • Oct 2011
                  • 6458
                  I get 2 pages on E470VL
                  • tw2005
                    • Oct 2011
                    • 6458
                    backlight on at all?
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      No pic and probably no backlight but will have the 5v STBY as set "attempts" to power.... So will be missing the 12v and 24v.
                      Can you give me a close up pic of the connector that goes from the PSU to main (Top left of your image) so I can see the labels for voltages please.
                      Need to confirm voltages at this connector to confirm the missing voltages and see what's going on.
                      • Cue
                        • Mar 2015
                        • 34
                        Yeah, no picture and no back light, I tried the flashlight test I didn't see anything. Here's the pictures
                          That is body diode of the MOSFET you are seeing, the Cathode of the Diode is connected to the Drain pin (middle pin), the Anode is connected to the Source pin (right pin), this is N-CH MOSFET.
                            Are these readings with the power switch activated? If it is activated, then the main board is the problem.
                            https://www.badcaps.net/forum/attach...7&d=1431658037
                            We will need good clear pictures of the whole back side of the TV to see all the boards.
                            • Cue
                              • Mar 2015
                              • 34
                              Did I measure it correctly?
                              • Cue
                                • Mar 2015
                                • 34
                                OK, I will tomorrow
                                  It is not showing as shorted circuit, using Ohm meter can only do so much for testing the MOSFET, but this MOSFET has nothing to do with what the TV is doing right now, it is the main board that is not sending the signals to turn on the power supply board and the inverter board but we need to know if those Voltage readings are made with the power switch is activated or not, that is VERY IMPORTANT info I need to know.
                                  • Cue
                                    • Mar 2015
                                    • 34
                                    Yes the TV was on when I did the readings. Here's the pics
                                      OK, then the problem is on the main board and will require more troubleshooting.
                                      • Cue
                                        • Mar 2015
                                        • 34
                                        Can a eeprom fix this issue? And what's under that metal rectangle in the middle of the main board?
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • magneh
                                          Behringer Eurolive B205D repair - help identifying transistor
                                          by magneh
                                          Hello
                                          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                          Still, I need to replace this transistor....
                                          06-18-2025, 02:34 AM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                        • elsomer
                                          help to identify transistor msi ms-15ck1
                                          by elsomer
                                          hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                                          02-17-2025, 05:30 PM
