Phillips 47PFL3603D/F7 No Power
    Re: Phillips 47PFL3603D/F7 No Power
    That T701 is the high Voltage backlights inverter transformer.
    Does the buzzing sound change with the change in the backlights level?
    The inveter circuits run off the high Voltage (>360VDC) generated by the PFC Voltage booster. You may have to check the DCV between the two legs of the main filter cap to see if it is steady, it is dangerous because you will need to get to the bottom side of the board while the board is powered up plus it is in the HOT Deadly side of the circuit.
    • Gorrillasnot
      • Dec 2013
      • 316
      Unless I am doing something wrong I cant tell that the brightness level adjustment is doing anything at all. From 0-100 the screen looks the same to me.
      C670, C671 Measured 405V pretty steady. It would fluctuate between 404V and 405V, but stayed mostly steady at 405V.
      Something odd, when I would go into the menu of the TV the buzz would go away. Exit the menu and the buzz would start back up.
      The first 3 pictures are of the startup sequence. Pic1. Immediately after pressing power button no buzz, Pic2. buzz starts, Pic3. TV is fully on and buzzing away.
      Picture 4 is after pressing the menu button and the buzz is gone.
      The last 3 pictures are the brightness level adjustments. No buzz while on these screens.
      I exit the menu and the buzzing returns.
      If it's not a cap that's that's causing the buzzing do you think the transformer itself is going bad?
      thanks
      • Terryfictv
        • Mar 2011
        • 124
        thanks
        Did you change out the two caps of wrong value ?
        Transformers usually don't "go bad"...they are usually good or bad.
          Not the Brightness adjustment, there should be another adjustment on the user menu for the BACKLIGHTS level.
          Most TV will have CONTRAST, BRIGHTNESS, and BACKLIGHTS adjustment. Your TV may not have that function for the Backlights level adj.
          • Terryfictv
            • Mar 2011
            • 124
            Please ignore ! I just read your response !
            • Gorrillasnot
              • Dec 2013
              • 316
              I don't see any option for backlights adjustment.
              Could it be the panel itself (or CCFLs) causing the trasnformer to buzz?
              In post #9 I attached a pic showing some problems with the picture at the top of the screen.
              I'll attach a pic here on a lighter screen so hopefully it shows up better.
              thanks
              • Terryfictv
                • Mar 2011
                • 124
                Next step = remove transformer from board and examine...
                Then re-solder wire wrapped lugs...then re-install on board.
                Test =
                • Gorrillasnot
                  • Dec 2013
                  • 316
                  If I am doing this right with my dmm set on 200ohm scale I get 22.2ohm on the primary side and 1.3ohm on the secondary. (see pic1 for test points I used)
                  Does this sound about right?
                  In pic2 are those the places that I should re solder? Then do the same on the secondary side?
                  If so, thsoe spots look to be covered with resin..whats the best way to remove it?
                  thanks
                  • Gorrillasnot
                    • Dec 2013
                    • 316
                    Do you think my transformer is good? I couldn't find any info when searching google to see what ohms it should be.
                    (BTW in the above post I think I have the primary and secondary backwards. primary is the thicker wire right?)
                    I read that Optocouplers is another component that can make a psu board buzz. Do you think that's a possibility in my case and if so how do you test them?
                    thanks
                    • Terryfictv
                      • Mar 2011
                      • 124
                      Solder primary wire wraps then inspect secondary....
                      BTW, MY transformer measures the same.
                      Smell it....does it have any physical problems?
                      • Gorrillasnot
                        • Dec 2013
                        • 316
                        Doesn't have any smell that I can tell and no damage that I can see.
                        Just so I am clear on where to solder, I should solder across the whole top and bottom primary side (thicker) wires as circled in the pic?
                        if that doesn't fix the buzz is there something else I should test?
                        thanks
                        • Terryfictv
                          • Mar 2011
                          • 124
                          DO NOT solder anything !
                          TTYL
                          • Gorrillasnot
                            • Dec 2013
                            • 316
                            ok I will wait for further advice.
                            I was doing some searching and came across a thread on another forum where a guy said he adjusted a pot on a 37" Philips and it fixed 90% of his buzzing.
                            He said it dropped the transformer voltage from 1060V down to 730V without affecting brightness. He said he adjusted fully counter clockwise.
                            I looked on my board and it also has 2 pots covered in glue. 1 is at VR401 and the other is VR402.
                            I believe VR401 is the one he adjusted.
                            Here is the link to the post http://www.avsforum.com/forum/166-lc...-contrast.html
                            Do you think this is something I should try?
                            thanks
                            • azza1234
                              • Nov 2013
                              • 124
                              • united kingdom
                              #34
                              them marks might be caused by the casing screws maybe? try undoing them and seeing if the dark patches go
                              • Gorrillasnot
                                • Dec 2013
                                • 316
                                Thanks azza1234..I will check the screws a little better.
                                About the buzzing..Looking at the back of the TV when I press the menu button and the buzzing stops I can see the backlight is considerably brighter then when not on the menu screen.
                                Is there a way to adjust the backlight brightness level other than in the menu which doesn't have that option?
                                • Gorrillasnot
                                  • Dec 2013
                                  • 316
                                  I reinstalled the transformer and put the board back in the TV.
                                  I ended up not messing with VR401.
                                  I read that turning off auto backlight dimming from the service menu might help.
                                  My chassis is Philips LC8.1U LA and I think this is the correct service manual http://www.s-manuals.com/tv/philips_lc8.1u_la_chassis
                                  In the alignments section of the manual for Byte OP2 it says Bit 3, Dec. Value 8.
                                  My default value for option 2 in the SAM menu is 123 so to turn off the backlight dimming would I subtract 8 from 123 = 115?
                                  I have tried to enter 115 for option 2 but every time I restart the TV it reverts back to 123.
                                  What am I doing wrong?
                                  thanks
                                  • Gorrillasnot
                                    • Dec 2013
                                    • 316
                                    The buzzing is gone..woohoo!
                                    Here's how I fixed it encase it might help someone else.
                                    First download a service manual for your TV.
                                    With the TV powered on (but not on any menu screen) press the following keys on the remote "062596" followed immediately by pressing the Info key.
                                    This should bring up the SAM (Service Alignment Mode) menu.
                                    Scroll down to the options section.
                                    Look in the service manual you downloaded and under the Alignments section find where it mentions "BACKLIGHT_DIMMING" and look for the location and value. In my case it was option 2 and the value was 8.
                                    In option 2 on the SAM menu my value was 123 and I needed to subtract 8 so I changed the value to 115. Go back 1 screen and scroll to the bottom and press "Store" and the setting will be saved.
                                    This turned off the Automatic backlight dimming and fixed my buzzing noise.
                                    As always proceed at your own risk.
                                    Now on to see if I can fix the dark spots at the top of the screen. I dont see any screws to mess with..I probably need to take the front bezel off and get into the metal frame to see if there are any hidden screws.
                                    thanks again everyone
                                      Thanks for the info, so your TV do not have user BACKLIGHT level control for the user to set the backlights level, can only be done in service mode. They should have put that in user mode like other brand.
                                      • Gorrillasnot
                                        • Dec 2013
                                        • 316
                                        I agree budm..why put something that could potentially fix an annoying (buzzing) problem in the service menu where the average consumer would not know how to get to.
                                        The last issue for me on this TV is those dark spots at the top of the screen. the Op Hours on the TV are 35,534..with that many hours I'm guessing that its some kind of panel issue or burn in spots..I've checked the screws and it didnt make any difference...is there anything else I could try?
                                        thanks
                                        • Terryfictv
                                          • Mar 2011
                                          • 124
                                          Call it a day ! Glad you came to a nice ending !
                                          The old Doctor's motto prevailed on this one =
                                          "Above all else,do no harm!"
                                          • Samuel Vincze
                                            Hp 250 g6 burnt IC on the motherboard - is labeled 3h=5g
                                            by Samuel Vincze
                                            Hello, my HP doesn't start, and I found a burnt IC on the motherboard. I can't read the full description due to the damage. The component is labeled 3h=5g. Could someone please advise me where I could buy the component or its suitable replacement? Thank you. It's marked as PUG8 on the motherboard.
                                            02-16-2024, 05:53 AM
                                          • nmbb
                                            Can not find Model/Value of Thermistor.
                                            by nmbb
                                            Machine: Autoclave.
                                            Brand/Model: SANYO MLS-3780
                                            Manual: (Sorry search option not working on this PDF)
                                            Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                                            06-02-2022, 05:55 PM
                                          • dicky96
                                            Zotac GTX 260 burnt component - can anyone identify?
                                            by dicky96
                                            Hi guys
                                            This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                                            This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                                            Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                                            I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                                            The good phase...
                                            12-01-2021, 01:02 PM
                                          • Use2bavolvo
                                            Magic chef oven - thermistor ref voltage issue
                                            by Use2bavolvo
                                            I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                                            Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                                            01-19-2023, 01:32 AM
                                          • mferna14
                                            Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                                            by mferna14
                                            Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                                            06-25-2025, 11:26 AM
