Machine: Autoclave.
Brand/Model: SANYO MLS-3780
Manual: (Sorry search option not working on this PDF)
Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number it says;
The only data in manual document is thermistor temperature/reference resistance chart;
According to this chart, if im reading correct, on room temperature 25c (Centigrade) TH1/TH3 value sohuld be 1390KOhms. So i go to mouser.com to check all brand thermistors and check bunch of thermistor manuals and can not find any thermistor matching 1390K ohm at 25C.
Also for your info here is the circuit diagram area about TH1,TH3,TH2(optional);
You guys can help me about finding what brand or value thermistor i need to use for TH2? Actually i want to find exact Model thermistor as same with TH1 and TH3. if i can find the exact brand thermistor i would be way happy.
And for your info, in the setting menu of the machine, there is thermistor calibration option. So it looks like i can use closer value thermistor and calibrate it. But its my second option. I want exact brand first.
THANKS FOR READING! And i would be greatfull if you can help me.
Regards..
Regards..
It's cold here at times in Canada, but not that cold!
Easy solution is to go to AcuRite website and purchase the sensor. Right?...
