No Picture Samsung LED TV
    Re: No Picture Samsung LED TV
    I would use a slow blow / time delay type - the very fast acting may blow under normal in-rush currents.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      ok probable shouldnt have but bridged a little speaker wire across fuse and plugged tv on, got multi coloured lines running all way through screen but unplugged (was only on for 2 seconds) and a little bit of smoke came from can smell burning copper or likes on the tcon ? im guessing i was wrong to try this ?
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        like these ones Tom ?
        http://www.ebay.co.uk/itm/10-X-FUSE-...item3f38520ad0
          Yes - you have probably damaged the T-con and you may well have destroyed the panel, and possibly the main board power circuit for the panel/T-con, or LVDS cable if the current was high.
          A fuse is there as a protective device, they don't put it on there so you can just jumper it because it'll be fun to see where the smoke comes out, never, ever jumper a fuse unless you really are absolutely certain there is no fault and even then, don't jumper a fuse because nobody is perfect and a fuse is a safety device.
          In future, you can use a lower-rated automotive fuse. For example a 1-2A fuse which may be used in a lighting circuit in a car could be used.
          • newtothis
            • Mar 2013
            • 1556
            • england
            Should of wired a conventional fuse in using wires, Not just a wire... The magic smoke has been released now
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              #26
              whats the next move ? possibly binning the tv now ?
                Try and put the smoke back in - if you capture it all in a jar, you might be able to stuff it in the holes it leaked out of (you'll need a smoke injection kit of course; check on eBay), if not, you'll have to buy replacement Samsung smoke, but they only generally sell it to service techs so you'll have difficulty getting it.
                more seriously, the lines on the screen point to a panel fault, so I'd probably scrap the set, but it would be good to check a few things first, try and locate what may have burnt or caused damage.
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  #28
                  may have been this chip as looks burnt from underneath
                  • tom thumb
                    • Jul 2013
                    • 66
                    Tom66: you made my day i love the smoke idea i had a good laugh
                    • CapLeaker
                      Leaking Member
                      • 8325
                      That is why you should have looked for a short first, before just replacing the fuse with a piece of WIRE!
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        #31
                        is there anything at all i can do to try and fix this ? would it even be worth replacing T-Con ?
                          Replacing the T-con could be a waste of money, as you may well have a damaged panel (especially after jumpering the fuse, lots of current may have gone through the wrong paths.) Very hard to to be sure. That IC could be secondary damage or the primary cause of the fault. It's your money. I wouldn't buy one if I were you.
                          • Mikeyboy2007
                            • Mar 2013
                            • 745
                            • Scotland
                            #33
                            ok i suppose its my fault... should have done what was instructed rather than jumping ahead.. thanks.
                            to start on another tv now i think, will be paying more attention on this one.
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              #34
                              So i got a hold of another tv but slightly different model that just happened to have the exact same Tcon board.. i tried it in the tv and im getting full picture however i am getting 4x 1 pixel wide lines down the screen at the right hand side. Can this be repaired ?
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                #35
                                Haha lol thats made my day
                                • blackfro26
                                  • Jan 2017
                                  • indonesia
                                  #36
                                  Thanks for the explanation, I also have the same problem. I have a samsung models UA40F5000MA, Sound OK, and Backlight OK, but screen black no image. I suspect that there is damage in the T-Con, but I do not understand the "Test Point", I tried to measure the part of the red circle. And get the result Vin 12.85 Volt and in other parts of 6.5 volts. Can you help me. Thank you very much. Sorry but I am not fluent in English, I use google translate
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #37
                                    Use your multimeter set to ohms and measure resistance across the fuse F100 which should measure 0 ohms. Set power off.
                                    • blackfro26
                                      • Jan 2017
                                      • indonesia
                                      #38
                                      Yes I do, and result the fuse is short. But I dont know where part to check or make the fuse short
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        if the fuse reads short its good re connect the tcon back up in the tv but leave one of the top ribbon cables disconnected turn the tv what do you see on the screen then put the ribbon cable back in and take the otherside out what do you see on the screen
                                          Post 36
                                          https://www.badcaps.net/forum/showth...645#post718645
                                          It is impossible to have fuse with 0 Ohms reading and have 12.85VDC on one end and 6.5V on the other end of the fuse. So Basically you have 6.35 DCV drops on 0 Ohm! Got to be measurement error.
                                          What scale are you using in Ohm mode?
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
