is there any way to remove minor scratches on TV LCD screen
  • mattstolte
    • Dec 2013
    • 612
    • usa
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: is there any way to remove minor scratches on TV LCD screen
    Lots of old dodges like Beeswax and Oil,--Think covering scratches on higly polished wood surfaces.....
    Maybe Brasso will polish it out--But will also make for a shiny area rather than the matte surface of usual LCD....
    TELEFIX
    • popeye
      • May 2011
      • 155
      Leave the scratches alone I had one I scratched on a 50 samsung brasso just removes the black mat finish ang looks crap just leave it alone.
      • capkid
        • Oct 2010
        • 1339
        Agree. I wouldn't mess with it.
        LG Plasma Mal-Discharge Correction Service
        • johnboy1313
          • Nov 2012
          • 1959
          Try a clean pencil eraser. It works better than you'd think.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            Yes ive done this on a laptop led screen recently too took a while as was a deep scratch but has removed a good 90% of it
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              Toothpaste can help buff some scratches out. Any buffing compound ok for plastic finishes should work too.
              • tibimakai
                • Jan 2012
                • 3680
                I wonder, how those windshield damages are filled, with that special glue, it wouldn't work on an LCD screen as well?
                • civi
                  • May 2014
                  Matt a few years ago we had those machines who could buff a CD with some plactic material, it would remove the scratches from the surface of a CD. You could simply get that machine, it has a very fast rotating motor on which some plastic material is connected. Once it comes in contact with the surface you want to remove scratches from, it fills those scratches up with plastic. I'm not sure if we can find those easily today though.
                  electronic assembly
                  • zomi
                    • Nov 2011
                    • 512
                    You can remove the scratch but its going to remove the matte surface layer too using any rubbing compound.
                    • tom thumb
                      • Jul 2013
                      • 66
                      I use 91% isopropyl alcohol with a cue tip and rub straight along the scratch since i get
                      tv's from a recyling place most have some scratches but i have had good luck with this technique if you try this, test on a small spot and if it makes things worse then do not
                      do the rest of the scratches with this technique but for almost every tv i have worked
                      on this has worked great for me
                      • Comm
                        • Nov 2014
                        • 8
                        There was silicone heatsink compound (clear), instead of the newer white stuff, made by GC electronics, it works well. You just smear it in the scratch with your finger, then buff off the rest along the scratch with a microfiber cloth. It was like Vaseline (petro jelly), not sure if that the Vaseline would work, as it's a petro product, and might react to the plastic, but the GC silicone heat sink compound worked like magic when we used it. one thing, it never sets, so you periodically might have to reapply if you clean the rest of the screen, but we were shocked how well it worked. The scratches literally disappeared. You could try the Vaseline on a junk screen and see if it does the same thing, and not eat the plastic if you can't locate any GC Electronics clear heat sink compound
                        • Comm
                          • Nov 2014
                          • 8
                          BTW, this tip came from another tech, he said he read it on some forum but we just happened to have some of that clear stuff in stock. I can't remember what forum or who he got the tip from, sorry to whoever originally discovered this.
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
                          • Maxpower3
                            Hantek 365 Remove screen on startup
                            by Maxpower3
                            every time I open the tool, I have the screen that appears
                            and I am always in a hurry to use it so I click and it automatically sends me a link to the manufacturer.
                            It annoys me lol.
                            2 solutions to remove it.
                            Either you remove pic.bmp and it no longer appears so no more links when clicking.
                            hope this helps users...
                            01-15-2025, 03:24 PM
                          • reformatt
                            by reformatt
                            07-31-2025, 08:37 PM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
