Proscan Plded3996a-c2
  • _N_
    • Nov 2010
    • 52
    Re: Proscan Plded3996a-c2
    Originally posted by budm
    OK, that means the MOSFET is not switching on and off and it just passes the input Voltage right to the output without producing the boosted Voltage needed for the LED.
    So you need to find out what DCV you have on the VCC pin and the GND pin of that 8-pin SMD IC.
    Did you download the spec sheet for that IC? If you did, then you should upload it.
    yes its in my 1st posting, top of thread along with all the other data sheets.
    pin 1: {V.in} gives 12.4V
      OK, sorry I did not go through all the links you provided in the first post, I will download and upload the spec sheet for other people to see for future reference.
      • _N_
        • Nov 2010
        • 52
        pin 1 is Vin gives 12.4Vdc
          OK, we need the DCV on each pin (with ref. to GND pin) of that OB3350 to see if it is active or not.
          • _N_
            • Nov 2010
            • 52
            k
              It looks like there is no drive output from the IC, the VCC is OK, the OVP is OK, so you can try a new IC.
              • _N_
                • Nov 2010
                • 52
                #27
                k, off to purchase one.
                anything else you'd like to verify by chance?
                  Nothing else I can think off, if the you at the diagram in the IC spec sheet, that is probably pretty close to what you have on your board, it is just a simple Voltage booster circuit.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4977
                    • New Zealand
                    #29
                    Could a fault with the feedback circuit cause the driver to shutdown?
                    -David VanHorn
                      Since there not enough output Voltage to turn on the LED, the feedback then will be 0 since no current flowing through LED and through the current sensing resistor as shown in the diagram.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4977
                        • New Zealand
                        #31
                        Oh yeah... that makes sense, but what if there is something wrong with the current sensing resistor\circuit for the FET?
                        (I don't know if that is the problem here, asking more out of curiosity actually)
                        The datasheet doesn't seem to explain much about how the CS pin works and if it's related to the OCP or not.
                        -David VanHorn
                          Right now the MOSFET's Gate is not getting any drive signal from the IC and I do not see anything standing out to stop the IC from drivng the MOSFET, and the MOSFET is not shorted out which will take out the Source resistor, so to be sure he can check the Resistor on the Source pin of that Power MOSFET.
                          The CS sense pin works the same as the SMPS IC by sensing if too much current is being flow through the MOSFET, the more current flow the higher the DCV across the Source resistor, when it reach the trip point (per spec sheet, it is 330mV), the drive circuit shutdown.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4977
                            • New Zealand
                            #33
                            Thanks, it makes sense now.
                            -David VanHorn
                            • _N_
                              • Nov 2010
                              • 52
                              #34
                              Part ordered last night, when it arrives ill install and upload pics, it will be a while since no one stocks it other than the people who make it.
                              Thanks Bud for the help, ill keep ya posted.
                              • _N_
                                • Nov 2010
                                • 52
                                #35
                                New part arrived and soldered it all in , no bridges now i get these voltages all measured to Ground pin of the IC. and still no BL helllllp ? ;}
                                  6, 7 and 8 are now much more different than the old IC. Need to do more thinking here.
                                  • _N_
                                    • Nov 2010
                                    • 52
                                    #37
                                    I left it on for 10 min this mourning and remeasured and now i get slightly different voltage.
                                    1: 12.4
                                    2: 0
                                    3: GND
                                    4: 0.04
                                    5: 0.01
                                    6: 3.6 - 0.60 this one fluctuates
                                    7: 2
                                    8: 2.4
                                    voltages off the main 2 big caps is v164,
                                    also the cap near for the inverter v20.9
                                    • _N_
                                      • Nov 2010
                                      • 52
                                      #38
                                      I was extremely careful in removing everything ,
                                      Curiosity killed the cat, I know,...... I know
                                      But looky looky
                                      ECD029 IC-E-CNA039d139
                                      • _N_
                                        • Nov 2010
                                        • 52
                                        #39
                                        I Just tried to see if the led strips would light using a small tiny H.V.inverter from a colored cold cathode tube for PC Modding, that feeds itself from a pc psu at 12V,
                                        regardless of the horrible /Black-brown states of the back of those LED Pcb strips, they flicker and all do light up (not brightly but they do turn on with the little inverter), Ill heat sink them to the large metal backing before I close it all up using a potting / thermal paste adhesive... WHY the hell didn't they do this at factory the tube costs like $2.14 on ebay sigh.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4977
                                          • New Zealand
                                          #40
                                          Be careful you don't electrically connect them to the frame somehow and short them out.
                                          -David VanHorn
                                          • x_orange90_x
                                            by x_orange90_x
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
