restart problem with Bush LED TV
    Re: restart problem with Bush LED TV
    so quote me if im wrong your board is 17MB95S-1 170912 but your replacemnt board is
    17MB95S-1 V.1 211212 ? when you ordered the board did it match up to your tv model ?
      yes sordids999 i typed tvs model number into ebay and got this:
      http://www.ebay.co.uk/itm/2717654809...%3AMEBIDX%3AIT
      have i ordered a wrong / incompatible board ?
        well some of the numbers do not match up with your previous board or the firmware could be different on the new one
          i cant seem to find a matching board on ebay with those numbers with same tv they all seem to be toshiba, hitachi etc. none are Bush
            In which case your kind of S.O.L. unfortunately... you'll just have to wait until one comes up for sale.
              ok Tom66 thanks.. has no one come up with a fix for the bestel mainboard like changing the chip the firmware is stored on etc ?
                I'm sure it's possible. But you need the firmware so without it...
                  Mikeyboy, what's the model number of the TV? I'm facing a similar problem with a Bush 40" LED with a possible firmware issue. Am trying to find a file to try reflashing the firmware chip but no luck so far. My board is 17MB95M though.
                  https://www.badcaps.net/forum/showthread.php?t=44389
                    Hi mate my tv is the same BUSH LED40127FHDCNTD i just had a look at your thread there and it seems that both these tvs had the same issue but upon me putting in another mainboard the tv will stay on until its turned off now but i get no picture..
                    where you by any chance using the tvs apps while you turned the tv off and then problem occurred, the lady i got this tv from said she was watching netflix and turned the tv off at the wall and when she got up the next morning the tv would go on for a minute then switch itself off and on for another minute.
                      Interesting. Same model number but mine has the 17MB95M rather than the 17MB95S-1. Do you mind sharing your panel sticker and maybe the sticker on the back cover to see the other relevant numbers? I'm wondering if the firmware we're looking for is specific to the model number, panel number, main board part number or what. Toshiba's website has their Vestel firmwares by TV model number, and I wonder if they also use different boards in the same models. Anybody know about this?
                      I'm about to try some firmware flashing as soon as I get a moment to figure it all out.
                      It's a TV I got spares and repairs so I don't know if the previous owner was using an app when it happened. I didn't think to ask.
                        Hi Mikeyboy. You can try this with your original main board installed to flash the firmware. Download this file and unpack the bin files and txt file to the root of a FAT filesystem usb stick.
                        http://nsi-el.dk/upload_dir/docs/270...EN_256.xls.ZIP
                        With the TV unplugged, put the usb stick in the top usb port. Hold OK on the remote while pointing at the TV and plug in power. Wait a while and hopefully the TV will boot up with new software. Problem is it might not be the exact right software for your TV, which is the problem I'm having - the TV tuner still doesn't work. It at least might get you somewhere anyway.
                          will this work with all vestel boards or just this tv in particular ?
                            This firmware is for 17MB95 boards, and I'm discovering is set up fairly specifically for each TV, so your results may vary depending on things like panel and tuner version. I'm currently messing around a lot with a few firmware dumps trying to put together one tailored for the TV I'm working on but it's pretty complicated. For other boards there are similar things you can do but it varies a lot between boards.
                            Btw I would recommend you take a dump ..... of the firmware on your existing board BEFORE doing the procedure I mentioned above. In fact since you're working on the same model no, it'd be really useful to me if you could send a copy my way. I can send you a script to put on a usb stick that should do that for you if you like.
                              Not got original board anymore sorry... im currently working on 2 bush 32 inch LEDs with vestel boards installed with start up problems
                                Well, if you let me know the model and board numbers I'll keep an eye out for you.
                                  one is Bush DLED32165HD with vestel 17MB82-2
                                    Originally posted by Mikeyboy2007 View Post
                                    No Tim unfortunatly it was 1 month out of warranty when it happened. I will try to search for firmware again. Thanks.
                                    Looks like they're getting pretty good at engineering these things for perfectly-timed self desctruction.
                                    Pity they can't put the same effort into engineering them to last.
                                    -David VanHorn
                                      I've got same television, where sound works fine, backlight is on but no picture.
                                      Any ideas what's wrong?
                                      Thank you.
                                      Regards.
                                        TV LED Telefunken,T50FX182LPS
                                        Please if anyone has the firmware for the motherboard:Vestel 17MB95S-1,170912
                                        Label:10086139 23128614 256 50"
                                        V219f_MB95S(OEM)
                                        27034366 CMOC6
                                        Best Regards!
                                          Data from the cover of the TV
