Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
  • tn245
    • Oct 2013
    • 530
    Hi! I've got this Bush/Vestel LED smart TV I'm hoping you can help me get going.
    When first plugged in it starts off in standby and when powered on with the remote it comes up with picture and sound with no issues. 30 seconds later the picture and sound shut off with the power LED flashing continuously. 15 seconds after that it comes back on for another 30 seconds, then 15 off, 30 on, etc, etc. Apart from the initial switch on it doesn't respond to the remote at all and the only way to stop it cycling is to unplug the power.
    I've attached photos of the back and the boards. PSU/LED driver is 17IPS71 which I have not found a schematic for. The main board is 17MB95M.
    With the connector to the backlights removed the symptoms are the same, though obviously with no backlights, just the sound going off and on.
    Does anybody have any ideas or experience with similar issues? I'm not sure whether main board or PSU at this point.
  • tn245
    • Oct 2013
    • 530
    Re: Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
    I have taken voltages along the connector between the PSU and main board. There are two rows of six pins, with the second row hiding behind the first. Helpfully the pins are not labeled and without the schematic we have to figure out what the function of each pin is.
    From top to bottom row 1:
    Code:
    Pin  Standby   With picture   No picture    Pin Function?
    1   12V     12V        12V
    2   0V     0V        0V
    3   0V     3.2V then 1.8V  0V        Connects to Brightness control pin of LED driver IC
    4   0V     3.2V       0V        Connects to Enable pin of LED driver IC
    5   2.2V    0V        0V        Drops to 0V immediately on remote switch on signal so PS_on?
    6   0V     23.7V       23.8V
    Row 2 just has two more 12V pins and the rest are ground.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      I would say corrupt firmware on this one, seen it happen on a 17mb62 that was sending improper signals to the psu. Unplug the mainboard from the psu and see if the voltage still fluctuates you may need to jumper the psu to get it to turn on.
      • tn245
        • Oct 2013
        • 530
        Thanks ReeceyBurger. I'm not clear how to jumper it to turn it on. I was thinking pin 5 needs to be shorted to gnd as it drops to 0V when the power button on the remote is pressed. But with the main board removed that pin is at 0V anyway.
        With the PSU isolated I have ~ 12V pin 1, about 1.8V pin 3, 23.8V pin 6 and the rest 0V. When isolated there is also a faint tick sound on the PSU every 3 seconds and on each tick pin 1 jumps from 11.7V to 12.3V and back down.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Remove the psu from the main board and measure the pins, find the pin that has 5v on it and use a 100-500ohm resistor and short that pin to ground that should be enough to power the psu on then check the voltages if its good it may bring up the backlights. I think that this psu shares the 17pw71-2 schematic.
            I would expect corrupted firmware, have also heard of this happening when accessing certain apps in the menu e.g. Netflix/iPlayer. Since TV works for 30 secs, you MAY be able to update firmware over USB port if you can get hold of a copy. If you have an existing same or similar TV you may also be able to copy off the firmware from the set using the service menu (Copy NVM) available on some Vestels.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              The pain with these sets is that you cant just interchange/swap parts they have to be exact and for the specific panel ohh vestel your tvs are far from smart
              • tn245
                • Oct 2013
                • 530
                ReeceyBurger: Thanks. I had quoted the voltages with PSU removed just about your last post and there's no pin with 5V. It has 12V when isolated which seems to be used as the standby voltage by the main board. I will check out the 17pw71-2 schematic thanks.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  No problem I think that this is firmware tbh if you have no luck with the psu try flashing the firmware, read what Tom66 said.
                  • tn245
                    • Oct 2013
                    • 530
                    tom66 thanks! I have no idea where to even start looking for firmware but I will get looking into it.
                    • tn245
                      • Oct 2013
                      • 530
                      Would I be looking for firmware based on the main board or TV model number?
                      • tn245
                        • Oct 2013
                        • 530
                        I also note I'll probably need to use the remote to do the firmware update, and it doesn't respond to the remote at all once it's got into its on-off cycle.
                        Maybe best to look out for a compatible replacement main board?
                          Product code... a 7 digit number on the back of the set... IIRC there's a database somewhere with tons of firmware files on it... can't find it right now though.
                          • tn245
                            • Oct 2013
                            • 530
                            Can't find any Bush firmware but Toshiba have firmware available for their Vestel TVs that use 17mb95 main boards. I'm guessing one of those would work.
                            As expected I'm not able to do a flash from the TV usb drive in the normal way as the TV does not respond to any input. I'm thinking about getting a cheap eeprom programmer and removing the 25L chip and flashing it that way.
                              That might work - note it's not an EEPROM but an SPI/Serial flash, so make sure your programmer supports it. Copy original data off before flashing. Also, maybe best to replace entire chip, as failure is likely due to flash wear out rather than actual corruption.
                              • tn245
                                • Oct 2013
                                • 530
                                Awesome. Was thinking about one of these:
                                http://www.ebay.co.uk/itm/24-25-Seri...-/400841941718
                                It says it can do MX25L1605. The ic on the board is 25L1606E, but I guess I can replace the ic with an equivalent SPI chip more readily available here?
                                  • 31285
                                  wouldnt surprise me if it was a bad regulator or related part on the mainboard on those - they are very similar to the boards in LG's
                                    • 31285
                                    btw, the system boots by reading the bios from the flash into ram.
                                    then running it.
                                    if the tv starts up and runs then the bios is probably o.k.
                                      Depends if the registers on-chip are compatible, sometimes they will not be, so be careful. Unlike EEPROMs most flash ICs aren't natively interchangeable.
                                      • tn245
                                        • Oct 2013
                                        • 530
                                        Ok thanks Tom. So best to order the same chip from China then I guess. Will probably try rewriting the existing one while I wait for it to come anyway.
                                        • FlailingEngineer
                                          Help with Bush Tv (Vestel 17mb95m Mainboard)
                                          by FlailingEngineer
                                          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                          05-31-2023, 06:52 AM
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
                                        • Chrissygizmo
                                          Bush led40127fhdcntd possile firmware issue?
                                          by Chrissygizmo
                                          I've picked up a bush led40127fhdcntd & the standby led is constantly flashing .. It flashes around 10 seconds then the backlights come on with a blank screen, led continues to flash for about 20 - 30 seconds & then the backlights go off , this is a continuous cycle..
                                          I will upload photos of the mb ,...
                                          11-03-2021, 08:28 PM
