restart problem with Bush LED TV
  • sordids999
    • May 2013
    • 2161
    Re: restart problem with Bush LED TV
    so quote me if im wrong your board is 17MB95S-1 170912 but your replacemnt board is
    17MB95S-1 V.1 211212 ? when you ordered the board did it match up to your tv model ?
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      yes sordids999 i typed tvs model number into ebay and got this:
      http://www.ebay.co.uk/itm/2717654809...%3AMEBIDX%3AIT
      have i ordered a wrong / incompatible board ?
      • sordids999
        • May 2013
        • 2161
        well some of the numbers do not match up with your previous board or the firmware could be different on the new one
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          i cant seem to find a matching board on ebay with those numbers with same tv they all seem to be toshiba, hitachi etc. none are Bush
            In which case your kind of S.O.L. unfortunately... you'll just have to wait until one comes up for sale.
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              #26
              ok Tom66 thanks.. has no one come up with a fix for the bestel mainboard like changing the chip the firmware is stored on etc ?
                I'm sure it's possible. But you need the firmware so without it...
                • tn245
                  • Oct 2013
                  • 530
                  Mikeyboy, what's the model number of the TV? I'm facing a similar problem with a Bush 40" LED with a possible firmware issue. Am trying to find a file to try reflashing the firmware chip but no luck so far. My board is 17MB95M though.
                  https://www.badcaps.net/forum/showthread.php?t=44389
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    #29
                    Hi mate my tv is the same BUSH LED40127FHDCNTD i just had a look at your thread there and it seems that both these tvs had the same issue but upon me putting in another mainboard the tv will stay on until its turned off now but i get no picture..
                    where you by any chance using the tvs apps while you turned the tv off and then problem occurred, the lady i got this tv from said she was watching netflix and turned the tv off at the wall and when she got up the next morning the tv would go on for a minute then switch itself off and on for another minute.
                    • tn245
                      • Oct 2013
                      • 530
                      Interesting. Same model number but mine has the 17MB95M rather than the 17MB95S-1. Do you mind sharing your panel sticker and maybe the sticker on the back cover to see the other relevant numbers? I'm wondering if the firmware we're looking for is specific to the model number, panel number, main board part number or what. Toshiba's website has their Vestel firmwares by TV model number, and I wonder if they also use different boards in the same models. Anybody know about this?
                      I'm about to try some firmware flashing as soon as I get a moment to figure it all out.
                      It's a TV I got spares and repairs so I don't know if the previous owner was using an app when it happened. I didn't think to ask.
                      • tn245
                        • Oct 2013
                        • 530
                        Hi Mikeyboy. You can try this with your original main board installed to flash the firmware. Download this file and unpack the bin files and txt file to the root of a FAT filesystem usb stick.
                        http://nsi-el.dk/upload_dir/docs/270...EN_256.xls.ZIP
                        With the TV unplugged, put the usb stick in the top usb port. Hold OK on the remote while pointing at the TV and plug in power. Wait a while and hopefully the TV will boot up with new software. Problem is it might not be the exact right software for your TV, which is the problem I'm having - the TV tuner still doesn't work. It at least might get you somewhere anyway.
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          #32
                          will this work with all vestel boards or just this tv in particular ?
                          • tn245
                            • Oct 2013
                            • 530
                            This firmware is for 17MB95 boards, and I'm discovering is set up fairly specifically for each TV, so your results may vary depending on things like panel and tuner version. I'm currently messing around a lot with a few firmware dumps trying to put together one tailored for the TV I'm working on but it's pretty complicated. For other boards there are similar things you can do but it varies a lot between boards.
                            Btw I would recommend you take a dump ..... of the firmware on your existing board BEFORE doing the procedure I mentioned above. In fact since you're working on the same model no, it'd be really useful to me if you could send a copy my way. I can send you a script to put on a usb stick that should do that for you if you like.
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              #34
                              Not got original board anymore sorry... im currently working on 2 bush 32 inch LEDs with vestel boards installed with start up problems
                              • tn245
                                • Oct 2013
                                • 530
                                Well, if you let me know the model and board numbers I'll keep an eye out for you.
                                • Mikeyboy2007
                                  • Mar 2013
                                  • 745
                                  • Scotland
                                  #36
                                  one is Bush DLED32165HD with vestel 17MB82-2
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5037
                                    • New Zealand
                                    #37
                                    Originally posted by Mikeyboy2007
                                    No Tim unfortunatly it was 1 month out of warranty when it happened. I will try to search for firmware again. Thanks.
                                    Looks like they're getting pretty good at engineering these things for perfectly-timed self desctruction.
                                    Pity they can't put the same effort into engineering them to last.
                                    -David VanHorn
                                    • jczarniak
                                      • Oct 2015
                                      • 179
                                      I've got same television, where sound works fine, backlight is on but no picture.
                                      Any ideas what's wrong?
                                      Thank you.
                                      Regards.
                                      • JRade
                                        • Nov 2013
                                        • 28
                                        • Serbia
                                        #39
                                        TV LED Telefunken,T50FX182LPS
                                        Please if anyone has the firmware for the motherboard:Vestel 17MB95S-1,170912
                                        Label:10086139 23128614 256 50"
                                        V219f_MB95S(OEM)
                                        27034366 CMOC6
                                        Best Regards!
                                        • JRade
                                          • Nov 2013
                                          • 28
                                          • Serbia
                                          #40
                                          Data from the cover of the TV
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • VikramB
                                            Samsung QN55LS03 | The Frame TV | Weird power cycle and restart problem
                                            by VikramB
                                            First thread here on this forum, excuse me if I miss something in my first post.
                                            I have the 55” variant of the Frame TV which is essentially a QLED tv. There's a weird problem where it would keep on restarting on its own. Funny thing is it might work perfectly for couple of days and then decides to go down the restart route. A few pointers:
                                            1. If I let the TV sit idle for a day, for the very first time it boots after that time period it usually keeps working for 5 minutes before restarting. After that it restarts every 5 seconds.
                                            2. I've tried the tape method and...
                                            03-17-2023, 02:56 PM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                          • GfilipeZ
                                            Macbook A1989 / 820-00850 Restart problem
                                            by GfilipeZ
                                            I'm working on a A1989 820-00850 Logic Board.
                                            The customer complained that the machine restarted randomly.
                                            From the analysis I made to the Logic Board, I detected a small corrosion in the IC U7430.
                                            Although the diode values are all correct, I replaced the IC with another one. But the machine kept the same problem.
                                            However, I noticed that whenever I use the Heaven software, the machine restarts after a few seconds. That is, it is enough to have an increase in graphics processing for the machine to restart.
                                            Has anyone had a situation...
                                            01-03-2023, 12:40 PM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
