  • theone111
    • Mar 2022
    • 13
    • Israel
    3. Problem: TV shuts down if AC in the room isn't on
      Frequency: Happened between once on hour - once a week. mainly depends on room temperature.
      Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. Turn on room AC.
    4. Problem: "White" video image (see attached) after powering on after a random shutdown.
      Frequency: Happened once first time today.
      Solution: picture returned to normal without intervention.
    A couple of weeks ago I removed the Power board (middle), Y sustain board (left), Z sustain board (right) and resoldered all MOSFET and coil solder points (some solder points seemed to be slightly cracked).
    No capacitors look bulged.
    No blackening spots on the PCBs.
    Measured internal voltages (as appear on the sticker inside) Vs, Va, 5v are exactly as they should be when TV is working.
    I also attached 4x DC outlet fans to the top outlet grills on the rear of the TV (connected to the TV USB ports - fans power on when TV is turned on).
    Problems - mainly (3) - still happens.
    I tried running the TV without the rear panel (to measure voltages when it happens) for a few hours without AC but couldn't reproduce the problem.
    I think the problem is related to overheating but of what component?
    What could be the problem? How can I continue to diagnose the problem?
    This is my last resort before throwing the TV out - this is our main TV and the wife wants one that works
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Test without the mainboard using the logic board auto_gen.
    I recommend always using energy saving on this TV to extend the life of buffer boards + Y-SUS.
    • theone111
      • Mar 2022
      • 13
      • Israel
      I usually have an image, as I wrote below the main problem I am facing lately is that after some time the tv shuts down randomly and If I wait a few seconds it works OK again until the next random shut down.
      As I understand the autogen is just to diagnose if there is a problem with the inputs and/or the main board. This is not my case as I understand it...
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        With the main board out of the equation it cannot not trigger a shutdown.
        If it still happens, control board or Y-Sus most likely, Y-buffers are also problematic in this model, but the picture would look strange, unstable at least.
        Is VSUS still on when the image/panel shuts down?
        • renech
          panasonic TH-42PC77U plasma television half screen problem
          by renech
          hello,
          I hope someone on this forum can assist me.
          I have a panasonic TH-42PC77U plasma television.
          the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
          i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
          I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
          I have read some posts that suggest the problem is related to the boards on the left...
          12-12-2022, 06:53 PM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • Okan123465676
          Acer Aspire 5 (A515-44G-R2JQ) – 100% Disk Usage Problem
          by Okan123465676
          Hello, sir.
          A customer brought in an Acer Aspire 5 laptop because it was freezing and running slowly. When I checked it, I noticed that the HDD usage was at 100%. I formatted the computer and installed Windows 11, but the problem continued. I then installed Windows 10, but the same problem still persisted.
          The HDD appears to be in good health. It shows 100% health, and there are no bad sectors. In the HD Tune test, the read speed was approximately 100 MB/s. The RAM test also passed successfully, with no errors detected.
          Would replacing the HDD with an SSD...
          07-23-2026, 09:23 AM
        • kevin_allein
          Ecovacs DEEBOT T20 OMNI strange problem
          by kevin_allein
          Hi, I have a Ecovacs DEEBOT T20 OMNI with a very strange problem:
          First I must add, that I got this robot used and it has some confusing setup. The external label states X1e OMNI, however external sensors and board seems to indicate, that it actually is a T20 instead. Maybe this has been to a repair shop before and some parts were swapped.
          The robot turns on the red light, after it is put into the charging station. I originally thought, that it does not charge and I had created that thread before:
          https://www.badcaps.net/forum/troubl...ware-devices-a...
          06-12-2026, 02:56 AM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
