Xenius LCDX42WHD89(A) stuck on standby
  • quiggy
    • Aug 2014
    • 136
    • United Kingdom
    Hi guys,
    Thought I had myself an easy one here but it seems there's more to it.
    The blue light is on and it wasn't coming out of standby so I bust it open to find myself a familiar vestel 17PW26-3 board with visually bad caps.
    I've replaced the caps and the problem remains, I had a spare board which I fitted and that didn't cure it.
    I have noticed that the Optical Out on the other board is flashing away, I've tried to google what this means but I got nothing.
    Has anyone come across this?
    Cheers
    Edit: I recently read something on here about the -3 on the vestel boards being for sizes 32 and 37 not 42, and by that reasoning my TV should have a -4 board in? I think it was tom66 who mentioned it. But surely it came with this board I took out? for it to have bulging capacitors. Confused now haha.
    • 12276
    • U.S.
    Re: Xenius LCDX42WHD89(A) stuck on standby
    been reading lately, how he eeproms get corrupted, from trying to use tvs with faulty caps, the eeproms seem to be getting faulty data, because of the bad caps.
    • quiggy
      • Aug 2014
      • 136
      • United Kingdom
      I'll try and replace the eeprom and see where I end up, if I can find one haha I seem to have trouble finding them.
      • quiggy
        • Aug 2014
        • 136
        • United Kingdom
        I think I've found the problem. Not sure if I'm capable of repairing that. Are the black ones just a set value? I thought all surface mount resistors had a number on them.
        Just noticed how bad that first picture is, ignore that one.
          • 12276
          • U.S.
          what was it a bad measurement on the resistor?
          • quiggy
            • Aug 2014
            • 136
            • United Kingdom
            The 2 resistors, well I assume they're resistors with the marks around them. It was much blacker than that but I cleaned it up before taking the picture.
              • 12276
              • U.S.
              http://www.shopjimmy.com/vestel-2040...x42whd89-a.htm ok its a vestel, they have a pretty bad reputation, theres a pic., looks like they arent cheap ether.
              • quiggy
                • Aug 2014
                • 136
                • United Kingdom
                They're much cheaper on eBay, it's just finding the right one, there's so many different variations it almost makes each board look unique.
                • sordids999
                  • May 2013
                  • 2160
                  have u checked any voltages before ordering a new part ?
                  • quiggy
                    • Aug 2014
                    • 136
                    • United Kingdom
                    I've checked the psu, all seems fine that end. I've also checked it with a replacement board that I had, still the same fault. The PSU did have bad caps but those have been replaced.
                    • quiggy
                      • Aug 2014
                      • 136
                      • United Kingdom
                      It's impossible to decide which to buy, does anyone know if it matters if it's from a 26", 32", 37" or 42" tv? if all the parts match up would it work?
                        • 12276
                        • U.S.
                        guess you have to match up the number on your sticker exactly, every place I call, it seems, they say that, last guy said they may look identical but the software is different.
                        • quiggy
                          • Aug 2014
                          • 136
                          • United Kingdom
                          I thought as much, I couldn't find one exact. I found one 2 digits out and took a risk. Will see if it works. Fingers crossed!
                            • 12276
                            • U.S.
                            Hope it works, if it does, I might try it, some of the boards with slightly different numbers are like half the price of my number.
                            • quiggy
                              • Aug 2014
                              • 136
                              • United Kingdom
                              I'll let you know how it turns out
                              • quiggy
                                • Aug 2014
                                • 136
                                • United Kingdom
                                Well the board arrived today and it works, sort of. The TV comes on fine but there's an issue, the side buttons don't appear to work, even when I press the power switch the blue light remains on. When I turn it on, everything is fine on screen it's just the menu pops itself up and the volume turns itself down, when I turn the volume up, it stays at the level for a min and then turns itself down again.
                                • quiggy
                                  • Aug 2014
                                  • 136
                                  • United Kingdom
                                  I've noticed, the volume will be constantly trying to go down unless I interrupt it by pressing a button then everything will function correctly for a few seconds and then bam! volume down again.
                                  It may sound like a silly question but on top of ensuring the board matches the panel, would it have to be matched up with the side buttons too?
                                    Check the resistance between the switches' legs to see if it shows any Ohms reading, it sounds like the switch is stuck.
                                    You did not notice this problem before the TV went out?
                                    • quiggy
                                      • Aug 2014
                                      • 136
                                      • United Kingdom
                                      I thought it might have been a stuck button too until I noticed the power button turns the blue light on and off with the old board in and not with the new. Also it's not just the vol down, if I leave it for a while with the volume down constantly on, it will eventually change to something menu.
                                      It's really strange. I never saw the TV on before, I had the set given from someone who couldn't work out what was wrong with it, he told me it had a power board issues but it doesn't.
                                      • duwane
                                        MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                                        by duwane
                                        Hi All.
                                        I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                                        Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                                        After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                                        Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                                        10-17-2023, 07:48 PM
                                      • howardc64
                                        by howardc64
                                        07-24-2025, 05:17 PM
                                      • Nevillet
                                        Vestel 17PW01-4 PS board stuck in standby
                                        by Nevillet
                                        Hi All,
                                        I'm looking at a Finlux (Vestel) TV which is stuck in standby. On inspection, the power board had 3 bulging caps (C851, 970,969) which were replaced with Rubycon ZL series. (they are a strange angles at the moment to ensure I have a decent lead length if they are removed) The standby problem did not resolve it self.
                                        Off the TV i've measured the voltages of the PL816 connector that goes to the main logic board. The readings are below:
                                        The original capacitors are Samxon brand. I've measured the ESR and capacitance and all apear...
                                        10-11-2019, 08:37 AM
                                      • mferna14
                                        Apple 820-01958-A logic board stuck on 5V .19amp
                                        by mferna14
                                        Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
                                        02-21-2025, 03:42 PM
                                      • hazi12
                                        Vestel main board 17MB140TC
                                        by hazi12
                                        Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
                                        Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
                                        I can send a dump....
                                        10-01-2025, 01:28 PM
