Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help me troubleshoot this. Thanks in advance
					Apple 820-01958-A logic board stuck on 5V .19amp
Thanks mon2., the current draw is stable to .19amp, does not increase or decrease.I checked for shorts, cannot find anywhere, ever coil & caps have resistence. more than 2K. Enable pins of what?? IC (CD3217B12) you mean??I checked the voltages, only the G3H (20v) is missing. Rest the 12v & LDO voltages are fine & present, only goes when the logic board resets again.Comment
Assuming...7 Photos -
			by AKuchen87Hi there. I am currently trying to figure out if I am undergoing the sunk cost fallacy.
I’ve bought a very cheap MacBook Pro 14 A2442 off eBay. I did some checking and the symptoms were pointing towards a NAND failure.
After some consideration I got an original logic board from Apple as an replacement. However after installing I have no backlight.
I can see the Apple logo if I point a flashlight at it but the MacBook seems to be going to recovery mode.
anybody have an idea of what’s up here? Is the board dead on arrival or is my screen... -
			Apple MacBook Pro 13" A1706 Logic Board 820-00923 Schematic & Board View...
							Channel: Schematics and Boardviews
			by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
			by YanlebHi all, I just want to share the repair of my 60PK550-UA TV set.
The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
C57: 3.30V
C61:...07-20-2023, 12:38 AM - Loading...
