Sony KDL-46Z4100 distorted image with green vertical lines
  • cope360
    • Jan 2015
    • 5
    Hi Folks -
    After 6 years this TV is giving me problems.
    Symptoms: after some period of use (could be minutes or hours) TV gets vertical lines, distortion, and a green cast. Power cycling it will fix the problem.
    Image and video below.
    I haven't cracked open the case yet. From reading other posts, it looks like the T-CON might be the problem. Any insight or suggestions?
    Thanks.
    Video: http://youtu.be/pkoXogRBvio
    • 12330
    • U.S.
    Re: Sony KDL-46Z4100 distorted image with green vertical lines
    try re-seating tcon connector and maybe the ribbons into the tcon, could be a bad tcon, check this video for how to. https://www.youtube.com/watch?v=rNNhghZ1pkA
    • cope360
      • Jan 2015
      • 5
      Thanks for the video link.
      TV is now totally dead. On power-up the standby light flashes 14 times.
      I tried reseating the connections to the t-con board. No luck.
      Based on another thread I read, I disconnected the t-con board and tried powering up. Back to green LED and backlight.
      Here are images of the labels and boards. I'm having a hard time finding a replacement board for sale.
      Can anyone tell me which number is the best part number and/or where I could buy one?
      • nicholas1110
        • Aug 2012
        • 127
        • usa
        There is a guy that has a repair service for these boards in eBay. Probably your best bet to get the tv back running.
          • 12330
          • U.S.
          did you try a firmware update?, might not be the problem but you never know. http://esupport.sony.com/US/perl/swu...00&upd_id=5351
            • 12330
            • U.S.
            look the tcon over real good, if you find anything labeled F, F=fuse, test it with multimeter.
              • 12330
              • U.S.
              spotted a fuse here, F601, test it for expected 24v, http://assets.shopjimmy.com/media/ca...253-11-TOP.jpg
                • 12330
                • U.S.
                those tcons seem pretty popular, so I wouldnt doubt thats your problem.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Actually I wouldn't be surprised is that was your problem. I've been spending a lot of time at this board now for various different failures from blown F 603 to slow refresh images to perfect working one minute to fading away locked up image that go us to vertical bars and noise on the screen. All tcon problems and not a panel issue. Still trying. Got 3 of these boards to repair to go into 3 good tvs. I can tell you if F 603 goes open you will get a blank picture upon startup and then 14 flashes. I've replaced all known component failures like the 4 diodes and ics that rrunt he voltage regulators and the voltage regulators themselves and doesn't solve any of the issues.
                    • 12330
                    • U.S.
                    came across this repair kit, requires soldering, http://www.ebay.com/itm/SONY-T-con-R...-/141478161382 the little buggers don't show us the individual parts, just says 8 components.
                      • 12330
                      • U.S.
                      tristate module has one for 76 bucks, seems high to me but who knows, http://www.tristatemodule.com/t-Sear...q=1-857-253-11 heres someone may have fixed a sightly different model, https://www.badcaps.net/forum/showthread.php?t=21939
                        • 12330
                        • U.S.
                        these guys may have a repair kit or can put one together, I usually shoot the seller a question, like do you have a repair kit for whatever model. http://www.ebay.com/itm/SONY-SHARP-V...item1e95a7c20d
                          • 12330
                          • U.S.
                          repair service for 45 plus 10 shipping, you have to send them your board, it says for a kdl-40z4100, you could ask them if they can do yours, they appear to be an electronics repair shop.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Btw. Bought that kit. For me it didn't do crap.
                              • 12330
                              • U.S.
                              couldnt seem to copy paste the url, anyway the ebay seller is masessum, if you put that in ebay search, the store will come up.
                                • 12330
                                • U.S.
                                ok, I havent tried them, maybe some of these so called kit sellers are less than honest.
                                  • 12330
                                  • U.S.
                                  I'm thinking theres a definite problem with these particular tcons, very seldom do I see the tcons costing way more than the main and power boards, like these seem to.
                                  • cope360
                                    • Jan 2015
                                    • 5
                                    Thanks for all the help.
                                    The link to Tri State Module is the right part but if you click to actually try to buy it, then it says out of stock.
                                    I've got enquiries out to ebay seller masessum and to Coppell TV Repair to see if they can do it.
                                    The part number on my board is different than what all the repair places have listed -- 55.46T03.C03 vs 55.46T02.C02.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4540
                                      • Italy - Milan
                                      Sony TCon on AUO panel?? Strange.. The symphtom seems very similar (solarization) to many AUO panels with AS15 faulty, here the gamma chip i don't know where is, maybe IC400 maybe IC901-IC902 but anyway the technique for soldering those become very inaccessible, i saw some video on youtube on how to do this but seems pretty near a sorcery.
                                        This T-CON board is not cheap!
                                        http://www.shopjimmy.com/sony-1-857-...-con-board.htm
                                        • pni
                                          LG 49uf695v vertical coloured lines
                                          by pni
                                          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                          11-14-2025, 03:15 AM
                                        • 265chemic
                                          Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
                                          by 265chemic
                                          Hi All,
                                          I have a Samsung LA46A950 that intermittently was displaying issues with evenly spaced vertical green lines only on dark / black areas - this has progressed to more often and blue lines sometimes, as well as a little image distortion.
                                          My initial suspicion was the T-CON board, which I took out and cleaned but the issue persists. A heat gun on all of the control boards makes no noticeable change. Ive also reseated the T-CON to panel ribbons (4 of them) and moving them while the panel is on doesn't seem to change the issue.
                                          Below are some photos...
                                          03-23-2022, 04:53 PM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          07-25-2025, 04:56 AM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
