Sony KDL-46Z4100 - T-con?
  • phil@philporter.com
    • May 2013
    • 113
    Sony KDL-46Z4100 turns on with the screen showing a few white lines that gradually goes mostly to white. Channels and menu items show (sometimes faintly). Interesting to me that when changing the channels they change very gradually fading out from on and fading in to the next.
    I've read many of the threads on this model, but not sure if all the symptoms match. Cleaned ribbon connections with no change.
    Any thoughts as to the probability of this being a T-con board problem?
    Boards are kind of expensive for a 7 year old set, but may take a chance if probability seems to be T-con.
    (took photo of back of TV with T-Con detached) Thanks.
    • 12276
    • U.S.
    Re: Sony KDL-46Z4100 - T-con?
    I'd try a tcon, theyre usually pretty reasonably priced, if it dont fix it, at least you eliminated it and you have a spare if you ever need it, if you get one, be sure to match it up with your panel number.
    • sordids999
      • May 2013
      • 2161
      im guessing possible bad panel or tab bond fault
      • billansor
        • 85
        No
        It is a T con problem
        There are some surface mounted caps on the right side that if heated up will show a picture again... I forget.. but there are about 11 of them...
        This T con is under a lot of heat..
        • white1991
          • Jan 2015
          • 7
          Stupid question, but is it possible for a T.V to not have a T-con?
          I have a LCD T.V, but I don't see any T-cons
          • CapLeaker
            Leaking Member
            • 8327
            the LCD has to have a T-Con. Follow the LVDS cable from the main board to the T-Con. I is usually behind a metal shield close to the top or bottom.
            • Glitcher
              • Mar 2013
              • 673
              • USa
              Looks more like a panel problem to me. This model is known for the tcon failing but usually with the faulty gamma chip, though this problem doesn't look like that. The tcons for this model is hard to source and a little pricey.
              • nicholas1110
                • Aug 2012
                • 127
                • usa
                On this tcon, usually when a as15 chip fails you will get horizontal lines where there is text or an image displayed on the screen. I suggest the first step would be to check the gamma voltages to confirm a failed as15 chip.
                  • 12276
                  • U.S.
                  indeed glitcher the prices on this tcon are sick, I'd troubleshoot that tcon real good, see if you can't fix it on component level.
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • iglitare
                    by iglitare
                    09-04-2025, 07:13 AM
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • thelankanguy
                    Sony KD-55X9000F TCON Issue
                    by thelankanguy
                    The TV shows a black screen with no image.
                    TCON ribbon connectors were disconnected individually for image and there was no half image even.
                    Later both ribbons were disconnected and TCON voltages were tested.
                    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                    There is also a short to ground in this circled inductor.
                    Is this a TCON issue or something else ?...
                    12-13-2024, 12:27 AM
                  • bbrain
                    Sony KD-55AG9 TCON?
                    by bbrain
                    I have this problem with my Sony 55' AG9.
                    It flashes 4x.
                    I have found the service manual, and seems it is the TCON.
                    Before I buy a TCON can someone check the vid?
                    Thanks in advance!...
                    09-19-2024, 10:50 AM
