Vizio Powers on no pic or sound
  • Falcons2677
    • 19
    Hello all,
    I have a vizio vw47LFHDTV10A the vizio logo on front turns from amber to white but no picture or sound. I am a newbie but have some knowledge. I can use a dmm and solder. Where should I start?
  • CapLeaker
    Leaking Member
    • 8218
    Re: Vizio Powers on no pic or sound
    Does the menu or any OSD come up?
    • Falcons2677
      • 19
      nothing comes on. Since the post I pulled the back off the tv. The only dc power I have at the power supply is 5v standby no other power. I assume the power supply is bad but i would like to try and troubleshoot the problem with some help. All the caps look good no bulging or leaking that I can see.
      • CapLeaker
        Leaking Member
        • 8218
        Need pix and model numbers of the power supply and the main board. Maybe another one of the power supply with the pin out for the voltages. Could be power supply, could be main board.
        • Falcons2677
          • 19
          the power supply # is 0500-0507-0340
          I also disconnected all dc side plugs from ps plugged in and turned power on and got the same readings 5vdc on standby and 0 on all other pins.
            Check the DC Voltage at the PS_ON pin, it should have >2.5VDC when the VIZIO LOGO turns white.
            You must have cables back in place.
            • ricosavy
              • Jul 2012
              • 457
              • united states
              Sometimes the inverter boards go bad on these.Here is a video that shows u what to look at. Also another that explains voltages on your tv http://youtu.be/IBRE1Dcyxp4
              http://youtu.be/jR2UZhoDC2c
              • Falcons2677
                • 19
                I ordered a power supply for $49. PS_ON pin was 0 with all plugs on. With any thing I tried only could get the 5v stand by but the logo would turn white. I looked at the above link on inverter boards. I could not find any dis color or sign of anything burnt. I will update when I get the power supply if it fixes the problem or not.
                • Falcons2677
                  • 19
                  Power supply was not the problem. Same thing 5v stand by 0v on anything other prongs.
                    Main board generates the PS_ON signal to turn the rest of the power supply, without it the TV will not function.
                    You need to check the Voltage regulator ICs on the main board next.
                    Please follow the instruction on how to test and report the readings in the format that will be easy for us to see the data of your findings.
                    https://www.badcaps.net/forum/showth...999#post300999
                    • ricosavy
                      • Jul 2012
                      • 457
                      • united states
                      Best thing is to follow the instructions and i know sometimes we want get thing fixed fast but i have learned here that it is a good idea to do tests and then ask if they think the part is problem before ordering.It has saved me money and has made my knowledge grow.budm has helped me a lot and so have a lot of people here.thanks everyone
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Check the caps and the fuses on the inverter boards too. I think I fixed one of these with a bad inverter.
                          http://www.shopjimmy.com/vizio-3647-...lfhdtv10a.htm#
                          If this is your board, then you need to check
                          U15, 16, 17, 19, 20, 21, 22.
                          • CapLeaker
                            Leaking Member
                            • 8218
                            That's because after unplugging everything on the DC side, you didn't force on the power supply with a jumper. So all you get would be the 5V standby voltage.
                            Anyway, make sure all the voltage are there, then go check the stuff that budm suggested.
                              • 12206
                              • U.S.
                              for sure, that jumper process can be a little hard to figure out, I don't know exactly how it works, but I'm a slow learner.
                              • Falcons2677
                                • 19
                                Main Board # 3647-0052-0150
                                U15
                                1084
                                0723GL
                                1=2.07
                                2=3.31
                                3=5.08
                                U16
                                7805CT
                                RE1651G
                                1=0
                                2=0
                                3=0
                                U17
                                AMC1117
                                F0734J
                                1=2.08
                                2=3.32
                                3=5.09
                                U19
                                1084
                                0723GL
                                1=1.25
                                2=2.49
                                3=5.11
                                U21
                                AMC1117
                                F0734J
                                1=0
                                2=1.24
                                3=2.48
                                U22
                                AMC1117
                                F0734J
                                1=2.05
                                2=3.30
                                3=5.14
                                U44
                                J303
                                G9117
                                1=0
                                2=0
                                3=0
                                I have not tried any jumpers. This is the tv powered on.
                                • ricosavy
                                  • Jul 2012
                                  • 457
                                  • united states
                                  Turn the tv on and get a flashlight point it at front of the screen and move it around screen and look to see if you see a image or message.
                                  • Falcons2677
                                    • 19
                                    Can't see a thing with the flashlight
                                      The Voltages look OK, the U16, 44 will not be working until the 12V power supply is working.
                                      To do the force on PS_ON, you will have to first disconnect that PS_ON wire so we will not backfeed the signal back to the main board, then you will use 100~1K resistor connected between the PS_ON pin and the 5VSTBY pin to force on the power supply.
                                      • Falcons2677
                                        • 19
                                        okay, took the PS_ON wire out of the plug or out of the harness. Jumped with a resistor. The back light come on. The vizio emblem stayed amber.
                                        U16
                                        7805
                                        0723GL
                                        1=10.98
                                        2=0
                                        3=5.02
                                        U44
                                        J303
                                        G9117
                                        1=8.41
                                        2=9.66
                                        3=10.98
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • csmith
                                          Vizio D50u-D1 Powers up no picture
                                          by csmith
                                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                          issue. Set will power up with remote but not power off....
                                          07-11-2025, 11:52 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
