Horizontal greenish lines on Samsung UN55D6050
  • bobbygiammarco1988
    • Oct 2014
    • 21
    I just replaced the T con board and lines still exist. They are constant, they do not move or ghost. They take up most of the display, more toward the right and get faint as they go left. Any Ideas?
  • gamethriller
    • Oct 2014
    • 153
    Re: Horizontal greenish lines on Samsung UN55D6050
    Have you checked the tab bonds on the display?
    • sordids999
      • May 2013
      • 2161
      pictures ?
      • gamethriller
        • Oct 2014
        • 153
        I take that back. I don't think the tabs would be bad here yet.
          • 12323
          • U.S.
          sometimes you get a dud, could still be the tcon could be the mainboard, hard to tell at this point.
          • tibimakai
            • Jan 2012
            • 3680
            D series is known for bad panels.
              • Oct 2014
              • 21
              I checked all tabs. Here is what it looks like. Lines do not move position but seem to flicker. Power board checks out. Tested all components on it. Nothing but clean power. Working upside down sorry about the picture
                Similar symptoms have been seen before and are sometimes caused by failed panels (not tab bonds, just plain old panel failures, the driver chips on the tabs failing.) Worth checking T-con for obvious faults, may be worth swapping for 55" screen but hit and miss as to whether it'll fix it.
                  • Oct 2014
                  • 21
                  Also hard to see but on one of two ribbons from the t con to panel, there is a pin or two that seem to have been damaged but all pins checked to be okay with the meter and when I swapped the two, nothing changed. My next guess is main board or bad panel
                    • Oct 2014
                    • 21
                    Yes I figured that. Can't fix them all I guess. Thanks for the help
                    • noipi
                      samsung Oled 65 Horizontal Lines and Flicker
                      by noipi
                      I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                      10-14-2025, 02:11 AM
                    • Ihandyrepair
                      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                      by Ihandyrepair
                      Hi guys
                      I just started fixing 4k TV few months ago. so I am still learning a lot
                      I got this tv from friend complaint is ghosting or horizontal lines on image.
                      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                      then it started to show the ghosting white image.
                      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                      it has 3 thin small boards at the bottom of the...
                      12-05-2022, 04:18 PM
                    • Rubenlily
                      Samsung QE50Q67TAU - horizontal lines
                      by Rubenlily
                      First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                      I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                      I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                      I'm no expert but I've done the tape...
                      08-16-2023, 01:12 PM
                    • x_orange90_x
                      Samsung UN46C8000XFXZA vertical bars/horizontal lines
                      by x_orange90_x
                      I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                      The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                      09-04-2023, 12:09 PM
                    • arctor
                      samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                      by arctor
                      hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                      04-26-2025, 05:22 AM
