Vizio E701i-A3 no Picture
  • bjorkson
    • Apr 2012
    • 127
    Re: Vizio E701i-A3 no Picture
    Yeah, if your TCON does not fix the issue, only other problem i see is a defective panel or the EEPROM on the main board.
    • freakaftr8
      • Oct 2012
      • 3743
      Good call
      • freakaftr8
        • Oct 2012
        • 3743
        Wow I just went to Target earlier today and I found the 70 and 60 inch model still on sale. Same exact model number. The 70 inch was working perfect but the 60-inch had a small horizontal Black line going to the screen but still working.
          Wouldn't surprise me, many of these LCDs with Sharp panels seem to have huge reliability issues. Until last year, Sharp was the exclusive supplier of 60"+ panels as no other manufacturer had mass-production capability. That's since changed, especially as Samsung etc have moved into curved TVs (now I bet those are fun to repair...)
          • freakaftr8
            • Oct 2012
            • 3743
            Yeah its funny you mention that because before 2014 it seemed that sharp panels had good reliability. Well the panels anyway not so much to say about the LED backlighting but now that other manufacturers are starting a mass produce bigger size panels sharp might have cheap and on their manufacturing processes just to keep up. I have yet to see a true sharp curved lcd panel yet.
            I wouldn't be surprised if this panel was built in China or Mexico. But I'm still reluctant to say the panel is at fault because I have no low voltage going to the gamma processor and the core voltage supplied to the main processor on the tcon board. I can monitor the 1.2 volts try to come up but immediately fell as soon as I turn the TV on. This is on a brand new t-con board that's never been met to the panel yet. Same goes for the old t-con board that supposedly went out while the person was watching it
            • freakaftr8
              • Oct 2012
              • 3743
              Can anyone confirm NPN mosfet with the label COXA ? The only thing I have found is a CO5A 60v 5a npn. These short center pin to right pin on these tcons when the problem arises. Also I should note there is no power going to this transistor at all either.
                MOSFET is either N -CH or P-CH. Bipolar Junction Transisor is NPN or PNP.
                So what do you have?
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Sorry. I meant NPN transistor marking COXA. It's a 3 pin small smd SOT-23 casing
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Okay I got my replacement t-con board tonight same problem however I notice between pin one and three of the Coxa transistor I had 523 ohms after I connected it to the main board nothing I had no pictures still but now its 1.2 ohms between the pi s. Also I should note that on the new board the transistor marking is COPA
                    Also I recently scavenge parts out of a broken screen Philips 55 inch LCD TV that used to sharp panel so I have is tcon board. The connectors are different on the output but I was able to verify that the main board is producing 12 volts and the T CON board is getting 3.3 1.2 and 15 volts. So clearly the mainboard must be fine.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Found the transistor and found a cross reference. Didn't do anything
                      http://m.aliexpress.com/item/32378541068.html
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Ok so now it looks like the other two small SOT-23 transistors on the DC converter circuits are open thus not supplying power to the rest of the board.
                        • CapLeaker
                          Leaking Member
                          • 8035
                          Since there is a lot of folks reading this thread, maybe good if you could add a picture so others know what components you are talking about.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            This pic was posted earlier by another user. The one in red is the transistor that shorts. The other two SOT -23 style in the pic seem to go open.
                            • electronics60
                              • Jul 2013
                              • 3
                              • usa
                              #54
                              Originally posted by bjorkson
                              Need some help or assistance please on a Vizio E701i-A3. Working on one where the power comes on using either remote or side panel power button. When power on, the backlight comes on and stays on, just no picture. I suspect it's a bad T-con board model RUNTK5261TP-ZH. When I measured the F101 fuse, label (5A @32V), getting less than 1 V. I suspect it to be bad. So, I order one off of Ebay and put in in. No change, still getting the backlight on, no picture. But with the new tcon board in there. I am getting a 12.32V reading, but not the 32V. Is it supposed to be a full 32V for the picture to come on? Did I buy a bad Tcon board? Can anyone please advised. Thanks in advance.
                              I have tried replacing the T-con boards on many of the 70" & 60" VIZIO with no luck I know it is the panel . I finally figured out how to repair the panel , I have done 5 of the "70 and 4 of the 60" VIZIO.
                              • electronics60
                                • Jul 2013
                                • 3
                                • usa
                                #55
                                You could also disconnect one of the ribbon cables going to the T-con board one at a time and figure out which side of the panel is shorted you should be able to get half of a picture depending on which side is shorted.
                                • Moroccansoul85
                                  • Sep 2015
                                  Hello! And how did you figured out how to repair the panels?
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Here you go for your reading pleasure.
                                    https://www.badcaps.net/forum/showthread.php?t=49281
                                    And
                                    https://www.badcaps.net/forum/showthread.php?t=48477
                                    Trial and error.
                                    • kingstv
                                      • Oct 2016
                                      Would you please tell me how to repair the panel on the 70"? I have tried replacing all boards to no avail, still no picture. (I got a deal on all 3 boards). I'm about to take it out back and
                                      • kingstv
                                        • Oct 2016
                                        Is your method the same as Freaks?
                                        • Blessed
                                          • Jul 2017
                                          • 5
                                          Could you post where and how you fixed your pannel?
                                          • Fly_Among_Stars
                                            VIZIO E70-E3 Half picture with half TCON
                                            by Fly_Among_Stars
                                            I have a VIZIO E70-E3.
                                            Symptoms: Black screen, no picture, but LED backlights are working.
                                            I probed the power board and voltages are as listed on the board.
                                            Main board appears fine, too.
                                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                            There are two separate ribbon cables feeding the LCD.
                                            If both are connected, the screen is black.
                                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                            04-24-2023, 08:20 PM
                                          • jason123
                                            Vizio P602UI-B3 No Picture or Sound - No TCON Voltage
                                            by jason123
                                            Help is much appreciated as I don't have any experience with this model TV.
                                            Picked it up and it was smoking in the back when powered.
                                            Open opening the LED Driver board was charred (see last photo.)
                                            I noticed some blown caps on the Power board as well.
                                            Replaced the LED driver board, and bad caps on Power supply.
                                            Voltages on CN301 (upper power supply connector to LED driver board)
                                            X000017 - All 24.39V
                                            GND - 0.001
                                            OD - 0.015
                                            VSNS - 0.009 (does that imply bad backlight or bad LED Driver?)
                                            11-14-2020, 08:43 AM
                                          • ggil44
                                            Vizio M65-E0 No Picture, No Sound
                                            by ggil44
                                            Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                            09-03-2024, 08:30 PM
                                          • maricm
                                            Vizio m65-c1 picture flashing on and off on the screen
                                            by maricm
                                            HI all,
                                            hope someone point to the possible issue before I start buying replacement parts.
                                            Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                            Backlight stays on all the time,
                                            Sound works fine.
                                            screen keeps changing form black to full picture in about 1sec intervals.
                                            Picture looks fine with no visible artifacts.
                                            I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                            Disconnecting left and right ribbons on...
                                            11-25-2023, 06:32 PM
                                          • shelby5041
                                            Samsung LCD TV no picture backlight on no 12v at tcon
                                            by shelby5041
                                            hi
                                            i have a samsung lcd tv
                                            it powers on with sound and backlight but no picture
                                            all voltages from PS are good 12v 3.3v and 5v
                                            whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                            i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                            no 12v at the tcon fuse
                                            i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                            the odds of having 2...
                                            10-08-2021, 08:21 AM
