Sony 40EX400 Dead No Power....
  • gamethriller
    • Oct 2014
    • 153
    Re: Sony 40EX400 Dead No Power....
    Thats what I been doing. The picture was from a different tv and was acutally curious. Dude has been helping me alot. I just dont know what the parts are called and how to test. I did alot of reading last night after all that.
    • selldoor
      Slow Learner
      • 7870
      #42
      The "pink chip" looks like a fusible resistor - It is difficult enough to follow at a distance
      without throwing in non relevant pictures and queries.
      • chrismurphy
        • May 2014
        • 251
        • australia
        #43
        Originally posted by gamethriller
        I have a Sony that is dead. Totally dead....
        I suggest that you leave servicing to people that have some idea about electronics ,you dont even have the basic understanding ,leave it alone before you kill yourself
          Research, study, test, ect. after you know what all these components are and what they are for, what they look like, how to get the P/N and read the spec sheet, how to read schematic, etc.
          So you want to learn electronics, these items below are just the basic beginning before you ever want to try to repair simple electronics. There are a lot more for me to list, let alone the safety issue (if you cannot identify Primary circuit and secondary circuit, then do not even try working on stuff that is connected to the AC power).
          Just search:
          'What is the fuse?', 'How to identify the fuse' 'How to test the fuse?' 'How to read the fuse rating', 'What does fuse look like', 'What is the fuse schematic symbol', etc.
          'What is the diode?', 'How to identify the diode' 'How to test the diode?' 'How to read the diode rating?' 'How many type of diode there are', 'What does diode look like', 'What is the diode schematic symbol', etc.
          'What is the Bipolar Junction Transistor', 'How to identify the Transistor' 'How to test the Transistor?', 'How to read the Transistor rating?' 'How many type of Transistor there are', 'What does Transistor look like', 'What is the transistor schematic symbol', etc.
          'What is the MOSFET', 'How to identify the MOSFET' 'How to test the MOSFET?', 'How to read the MOSFET rating?' 'How many type of MOSFET there are','What does MOSFET look like', 'What is the MOSFET schematic symbol', etc.
          'What is the resistor', 'How to identify the resistor' 'How to test the resistor?', 'How to read the resistor rating?' 'How many type of resistor there are', 'What is the resistor schematic symbol', etc.
          'What is the capacitor, 'How to identify the capacitor', 'How to test the capacitor?', 'How to read the capacitor rating?' 'How many type of capacitor there are', 'What is the capacitor schematic symbol', etc.
          'What is the inductor', 'How to identify the inductor', 'How to test the inductor?', 'How to read the inductor rating?' 'How many type of inductor there are', 'What is the inductor schematic symbol', etc.
          'What is the transformer', 'How to identify the transformer', 'How to test the transformer?', 'How to read the transformer rating?' 'How many type of transformer there are', 'What is the transformer schematic symbol', etc.
          • gamethriller
            • Oct 2014
            • 153
            [QUOTE=chrismurphy;504337]I suggest that you leave servicing to people that have some idea about electronics ,you dont even have the basic understanding ,leave it alone before you kill yourself[/QUOTE
            Yea ok
            • gamethriller
              • Oct 2014
              • 153
              You are right and that is my mistake.
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • PopsCaps
                Sony Bravia KDL-40V2500 that will not power on
                by PopsCaps
                I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                I do not hear any sound and I cannot see any backlight.
                I have tried disconnecting every cable on each board one at a time to see if anything changes.
                The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                03-25-2025, 11:23 AM
              • Mike Russell
                Lenovo 14ALC6 - NMD521 - No power, totally dead.
                by Mike Russell
                Machine won't power on, no power led, no fan spin, completely dead.
                Checked PQ5400 - AONS32314 and pins 5,6,7,8 are 20v (AC adaptor voltage) but pins 1, 2, 3, 4 are 0v.
                Following Gate Pin 4 to PU5400 - BQ24780SRUYR.
                VCC 20v
                ACDET 2.8v
                ACDRV 0v (goes to pin 4 gate of AONS32314).
                ACOK 0v
                REGN 6v
                According to datasheet, conditions are correct for ACOK to be high but it is not.
                Tracing ACOK it's connected to ACIN which is connected to a pin GPB0 of IT8227 but also shown as connected to +3VL via a 100k resistor...
                12-25-2024, 08:31 AM
