Sony Bravia KDL-40V2500 that will not power on
  • PopsCaps
    Sir Shock-a-lot
    • Mar 2025
    • 5
    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
    I do not hear any sound and I cannot see any backlight.
    I have tried disconnecting every cable on each board one at a time to see if anything changes.
    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times with that one.
    So either both power supply boards are bad or maybe there is a different problem.
  • PopsCaps
    Sir Shock-a-lot
    • Mar 2025
    • 5
    testing voltage on AC-DET.
    With AC-DET cable connected 2.8 V
    with the AC-DET disconnected about 3.4 V
    on the connector to the right, I am not getting 18V on any of those pins. It only reads about 0.2 mV on each one
    • PopsCaps
      Sir Shock-a-lot
      • Mar 2025
      • 5
      testing voltage on the pins on this larger connector on the right hand side of the board I see only low voltage on every pin with the cable connected
      But I get 3.4 V on standby pin with the cable disconnected
      • PopsCaps
        Sir Shock-a-lot
        • Mar 2025
        • 5
        Could anyone please help me diagnose this issue?
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • repair-it
          SONY Bravia OLED XR-77A80J will not power on
          by repair-it
          SONY XR-77A80J shuts off as soon as it is powered on. It goes into standby ok when plugged in but when power button is pressed, relay clicks and tv powers off. Power supply board makes a sound that sounds like momentary coil whine when it clicks off. The main board appears to turn on and has working optical.
          I pulled the power supply board for visual inspection & there wasn't anything obvious. I am not sure how to go about testing this OLED as it is a bit different than the last one (LG) I tried to repair. The only voltage listed on the PSU is 12v for T-CON. The 12v is not present...
          01-24-2024, 10:15 PM
        • SkishyIshy
          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
          by SkishyIshy
          Hey All,
          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
          03-17-2021, 11:44 AM
