Insignia ns-42pdp (lg pdp42x30000)
    Re: Insignia ns-42pdp (lg pdp42x30000)
    Ok, in that case, pin 1 is on the left when that mark faces downwards. Writing should also be readable.
    Capacitors, assuming there are 3 x 10uF 400V?
    http://www.digikey.com/product-detai...540-ND/1086766
    Slightly taller but don't see it being a problem
    And 100uF 35V:
    http://www.digikey.com/product-detai...5165-ND/245024
    • DaveL
      • Sep 2014
      • 90
      http://www.digikey.com/scripts/DkSea...77272551675132
      This is what I had found and have in my cart at the moment..
      • DaveL
        • Sep 2014
        • 90
        The mark is upper left with the writing readable
          None of those links work for me...
          • DaveL
            • Sep 2014
            • 90
            I just click each one and they worked for me....
              I get 404 not found using Google Chrome browser.
              Can you give me the Digikey part numbers? Ending in "-ND" usually.
              • DaveL
                • Sep 2014
                • 90
                Ncp1200d60r2gosct-nd
                493-7467-1-nd
                497-5899-5-nd
                565-1321-nd
                  Everything looks OK although I would replace the 400V capacitors with what was previously suggested. This is due to the higher ripple current specification which should mean they last longer.
                  • DaveL
                    • Sep 2014
                    • 90
                    Ok...I swapped those caps out.
                    Is there any thing else I may need before I submit my order?
                      I'd get a reel of Chemtronics solder wick
                      • DaveL
                        • Sep 2014
                        • 90
                        The FDA 59N25 mosfets came in Friday..I installed those.
                        The order from Digi-Key should be here Monday.
                        • DaveL
                          • Sep 2014
                          • 90
                          The package from Digi-Key didn't show up today...maybe tomorrow.
                          • DaveL
                            • Sep 2014
                            • 90
                            Everything came in the mail yesterday...
                            I installed the mosfets last night...
                            I installed the caps and the little switching chip..
                            I noticed that when I had removed the chip that I had a bare (no solder point) on the board...I installed the chip any way...
                            I screwed the little board up when I removed the chip..all I get is sound...no pic.
                            I am pissed at myself now...
                            I guess I will have to order the whole Y board now.
                              It may be possible to repair that little board if you can get me a clear picture of the damage. Is there any way you can borrow a camera? It would really help, otherwise I can't really advise.
                              • DaveL
                                • Sep 2014
                                • 90
                                I've been talking with a guy here in Tennessee...
                                He has a board with a bad chip (the one under the big heat sink).
                                I can get the board and the buffer for about 50.00 dollars..
                                I burnt the spot on this board pretty bad trying to get some solder to stick with no avail...I really think it is beyond repair at this point...still pissed at myself every time I look at it..I'll try to take this as a "lesson learned"...
                                  I suppose you could take the -Vy module off the bad board and put it on yours - assumjng the module is good.
                                  The silver pads are glued on. You can scrape off solder-mask (green stuff) ovrr the copper to make the connection. This only works if the copper is easily accessible.
                                  • DaveL
                                    • Sep 2014
                                    • 90
                                    I'm an idiot at times...
                                    I didn't plug the small ribbon connector at the lower right corner in...
                                    I have a picture..still the same...little specs of red and green if you get up close and look and the screen still "flickers" very faintly...
                                    • DaveL
                                      • Sep 2014
                                      • 90
                                      Ahhh..but something is wrong.
                                      After about 5 minutes the tv shut off and the red light on the power board has come on..
                                        Did you try power cycling, could just be no signal turn off.
                                        The -Vy module will be bad if the pad is lifted, so the fault will likely remain the same regardless.
                                        These older LG based panels are pretty hard to repair, so don't blame yourself if you're finding it difficult. I don't touch them any more, I consider them horrid!
                                        • DaveL
                                          • Sep 2014
                                          • 90
                                          I'm finding them "horrid" myself!
                                          I found another board..exact same board...
                                          I have sound and no picture with the "new" board"...(gave 20.00 for it...figured I could scavenge the Vy module if nothing else)
                                          This board has a blown fuse (closest to the capacitors)..If that means anything.
                                          I hooked this board up to make sure it had sound and no picture...
                                          Besides the blown fuse this board looks to be in better shape than the original board.
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 (third and final post, hopefully!)
                                            by valvashon
                                            I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
                                            Problem was no cold startup; it would only startup when you applied a heat gun to the board....
                                            10-22-2025, 12:33 PM
                                          • oneduane
                                            Samsung Plazma Blues Model PN59D550C1F
                                            by oneduane
                                            I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2...
                                            09-07-2023, 08:17 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 no standby LED; (new problem)
                                            by valvashon
                                            Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
                                            Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
                                            Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
                                            08-30-2023, 10:41 AM
                                          • tbsmith
                                            Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
                                            by tbsmith
                                            There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
                                            08-11-2025, 06:15 PM
