Insignia ns-42pdp (lg pdp42x30000)
  • DaveL
    • Sep 2014
    • 90
    Re: Insignia ns-42pdp (lg pdp42x30000)
    b
    • DaveL
      • Sep 2014
      • 90
      b
        The fault with that board will be the IPM module - the large "chip" (actually a hybrid module, with discrete silicon and a conventional PCB) under the heatsink
        • DaveL
          • Sep 2014
          • 90
          Should I swap the IPM module from the original board and use it on this new board?
          • DaveL
            • Sep 2014
            • 90
            b
              It would be very difficult
              I would swap -Vy module instead
              • DaveL
                • Sep 2014
                • 90
                Ok...
                • DaveL
                  • Sep 2014
                  • 90
                  Ok Tom..
                  I completed the task of swapping the module..
                  I used the hot air technique to remove the module without damaging it at all..
                  I cleaned everything really well and installed the module on the original board as well as possible..remember, I did hack the original board and module up pretty good..(Before I read and researched the hot air technique)
                  After installing the board and double checking all connections I turned the tv on and got picture and sound..with just the lightest hint of those sparkles (green this time and no red sparkles).
                  I still had the light part of the picture doing that fade in and out thing going on...and then I saw the longer the tv was on that my picture faded away and left a white screen.
                  I'm wondering if my "hack job" on the removal of the module from the board the first time may be the reason that the pic faded away...?
                    Can you check the -Vy on your board and see if it is unstable or not.
                    • DaveL
                      • Sep 2014
                      • 90
                      Ok..let me go back through this thread so I get it right and I'll be right back
                      • DaveL
                        • Sep 2014
                        • 90
                        Oh...I tried powering up the tv and it shuts itself off in just a few seconds and the red light on the power board comes on so I probably wont get a reading on on anything
                          These LG based sets are brilliant, aren't they? It's... just... ugh.
                          • DaveL
                            • Sep 2014
                            • 90
                            LOL!
                            I really can't say anything..I did mutilate the board up pretty badly!
                            I'm probably the cause of the problem now.
                            • DaveL
                              • Sep 2014
                              • 90
                              Can't get a reading...
                              It shuts off so quickly I can't get the probes on it to read it...
                              I've taken the board back out of the set...powered it up and my sound came back.
                                I'd suggest checking across Vs and GND on the power connector for shorts. To me it sounds like your IPM has failed.
                                • DaveL
                                  • Sep 2014
                                  • 90
                                  Probably brought on by my mutilation of the board!
                                  Well, I'm going to put the module back on its original board...now that I have the means of doing it without harming anything in the process...
                                  Since I know this "new" board already has a bad IPM I might as well "play" and get some practice in on soldering techniques and swap the IPM from this one to the "new" one and see if anything changes...
                                  I checked Vs and GND on the power connector on the board...I don't get any audible...unless I probe Vs to Vs then I get an audible...
                                  • DaveL
                                    • Sep 2014
                                    • 90
                                    Tom,
                                    Sorry for the lengthy pause, I had to go to the hospital and stay for a while..heart trying to act stupid on me..
                                    Turns out you were right about the IPM..I checked it again and got an audible...upon inspecting the IPM I found a couple of cracks in the base of it and if you put any pressure at all on it I got the audible..
                                    So, I used it to practice desoldering on it...got fairly well with it and went ahead and removed the IPM from the "new" board and cleaned it up real good and will order an IPM for it...
                                      Man, you have a lot of patience. I would have thrown it in the trash by now. Or connected the plasma panel to 2000V and watched for fireworks: https://www.youtube.com/watch?v=mkvQ9aWM0DE
                                      • DaveL
                                        • Sep 2014
                                        • 90
                                        Wow...I can't believe it took all that juice and didn't just melt down....
                                        All the pretty sparklies!!!
                                        • DaveL
                                          • Sep 2014
                                          • 90
                                          The patience of Job...
                                          My son brought me a Panasonic TC-P42C2 to look at for him...I'm not sure if he loves me or not..
                                          So I've tried to revive an old thread that was dealing with the same problem...
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • oneduane
                                            Samsung Plazma Blues Model PN59D550C1F
                                            by oneduane
                                            I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2...
                                            09-07-2023, 08:17 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 no standby LED; (new problem)
                                            by valvashon
                                            Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
                                            Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
                                            Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
                                            08-30-2023, 10:41 AM
                                          • tbsmith
                                            Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
                                            by tbsmith
                                            There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
                                            08-11-2025, 06:15 PM
                                          • howardc64
                                            Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                            by howardc64
                                            Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                            • Backlight on, no image
                                            • Disconnect right buffer board (view from front), left side display comes on
                                            • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                            • Buffer board is pretty simple
                                            Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                            07-11-2025, 04:04 PM
