Insignia ns-42pdp (lg pdp42x30000)
  • DaveL
    • Sep 2014
    • 90
    Re: Insignia ns-42pdp (lg pdp42x30000)
    I think I should go ahead and strangle my kid...
      The C2 Panny is a nice basic TV. I'll have a look at the post later.
      • cajoeg
        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
        by cajoeg
        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
        02-10-2025, 04:01 PM
      • oneduane
        Samsung Plazma Blues Model PN59D550C1F
        by oneduane
        I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2...
        09-07-2023, 08:17 PM
      • valvashon
        Insignia NS-LCD19-09 no standby LED; (new problem)
        by valvashon
        Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
        Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
        Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
        08-30-2023, 10:41 AM
      • howardc64
        Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
        by howardc64
        Eventually discovered a burn mark near lower corner of LCD. Here is a summary
        • Backlight on, no image
        • Disconnect right buffer board (view from front), left side display comes on
        • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
        • Buffer board is pretty simple
        Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
        07-11-2025, 04:04 PM
      • arnard
        Insignia NS-32L430A11 backlight issue
        by arnard
        I have a weird backlight issue on the above Insignia Plasma that I am coming up empty on researching.
        The display is darker on the left than on the right side of the screen. It uses 4 U shaped plasma tubes. I have had it apart deep enough to tell you that the tubes are bright as they should be at the electrode ends but dim as they get to and go around the bend.
        Since it is all 4 tubes it seems like it would be an inverter/backlight board but obviously can't be a blown up component as it does still somewhat work. I'm thinking low voltage but no idea where to go beyond...
        06-10-2023, 01:36 AM
