Insignia ns-42pdp (lg pdp42x30000)
  • DaveL
    • Sep 2014
    • 90
    Re: Insignia ns-42pdp (lg pdp42x30000)
    Vy is still at 025..adjust the pot and nothing really happens..meter will bounce 024-025
    • DaveL
      • Sep 2014
      • 90
      wait...I was wrong on 2 of the mosfets...
      1 of them is bad..on all G,D and S
      Now for the other 2 FDA59N25 Mosfets,
      I get NO readings at every configuration of test leads except when neg is on D and pos is on S...I get a reading of 507 on both of these mosfets..
      There was a small layer of solder on the bottom of the mosfet that I didn't notice until I looked over them again..causing the short.
      • DaveL
        • Sep 2014
        • 90
        When I reinstalled the Y board I got nothing on the screen...I then reinstalled the Y buffer and when I powered up the tv I got a small flash from the screen..you could see snow momentarily and then the screen would go black. I got this 3 times powering on the tv.
          Ok, that means only one is failed (which is expected)
          Did you get -Vy when the short was removed?
          If -Vy is good: There's no harm in trying if the circuit is already bad: Install the two good ones. See if you get an image on the panel. If you do, turn the TV off, and order all three as replacements (possible that the others have been "wounded" by the other failure so for continued longevity, I would always replace the set.)
          • DaveL
            • Sep 2014
            • 90
            The Vy was at 025...am I looking for a -200?
              Hopefully -200V. But if it's still at ~25V there is a further fault on this board.
              Maybe time to look at the -Vy module but I've never heard of a repair of one of the modules.
              • DaveL
                • Sep 2014
                • 90
                Just to make sure...what setting should be used on the meter to measure this?
                  The highest available DC volts range (usually 600 or 1000V)
                  • DaveL
                    • Sep 2014
                    • 90
                    Ok..I put the 2 FDA 59N25 mosfets back in..turn the power on and got a Vy reading at 024..
                    When the set powered up I have a screen showing snow and now I have the "no signal" message floating around the screen!
                      Hmm, is the NO SIGNAL clear and OK, or is it very distorted, barely visible?
                      • DaveL
                        • Sep 2014
                        • 90
                        No, it is clear and very readable...
                        It also had the message in the upper right corner of "video" and then it goes off and the "no signal" then pops up and starts floating around the screen...all the messages are very clear
                        • DaveL
                          • Sep 2014
                          • 90
                          oh...while the "video" was on the was a darker band the same width of the video message that ran from top to bottom of the screen.
                            Sounds like there's still a problem - try giving it an actual video source...
                            • DaveL
                              • Sep 2014
                              • 90
                              Put a antenna on it and programmed the channels..turned it to a local HD channel and got a good picture and sound...you can see what looks like faint red snow in the picture..like red sparkle is the only way I can describe it..it doesn't over ride the picture but you can see it...does that my description may any sense?
                                Yes that's a common fault with LG plasmas. The control board needs to be reflashed with corrected firmware. There's a guy on here (capkid) doing the repairs for about $30.
                                I'd make sure to replace the missing MOSFET before running it too long.
                                  I'm still not sure what to make of your -Vy voltage. With a very low -Vy I'd expect a lot of picture issues. I'm guessing that you are making a measurement error with that - perhaps your meter is in error? Maybe try using 200V range.
                                  • DaveL
                                    • Sep 2014
                                    • 90
                                    Ok...checking at the 200v range I get a reading of 16.7 to 17.00
                                    Along with the faint red snow the picture will sort of flicker like the brightness is jumping..its not bold just sort of faint
                                    • DaveL
                                      • Sep 2014
                                      • 90
                                      At 1000 the reading is 16...
                                        I think the -Vy module needs to be repaired/replaced.
                                        Can you remove it? I need good pictures, unfortunately...
                                        • DaveL
                                          • Sep 2014
                                          • 90
                                          I'll try..give me a moment
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 (third and final post, hopefully!)
                                            by valvashon
                                            I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
                                            Problem was no cold startup; it would only startup when you applied a heat gun to the board....
                                            10-22-2025, 12:33 PM
                                          • oneduane
                                            Samsung Plazma Blues Model PN59D550C1F
                                            by oneduane
                                            I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2...
                                            09-07-2023, 08:17 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 no standby LED; (new problem)
                                            by valvashon
                                            Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
                                            Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
                                            Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
                                            08-30-2023, 10:41 AM
                                          • tbsmith
                                            Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
                                            by tbsmith
                                            There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
                                            08-11-2025, 06:15 PM
