Insignia ns-42pdp (lg pdp42x30000)
    Re: Insignia ns-42pdp (lg pdp42x30000)
    Unfortunately the pictures really aren't clear enough to be useable. Those pictures are my eyes - I do not have this chassis in front of me (I last worked on one nearly 2 years ago!) - so they really need to be good and clear, which might mean using a different camera.
    However I do have a guide which indicates some possible tests you can do, in the meantime:
    Page 60, 62 and 66 are relevant for now. Please test and adjust as indicated.
    • DaveL
      • Sep 2014
      • 90
      If I didn't need a camera everybody I know would have one...I'm fixing to buy a better camera.
        Sods law, eh?
        For now, you can use the pictures in the guide.
        • DaveL
          • Sep 2014
          • 90
          Ok...From pages 60,62 and 66...
          I'm just posting the ones that were not right and would not
          calibrate out from their pots...
          VY-23-20 as low as it would go. Started at 23 and ends at 20.
          Z BIAS-156-152 as low as it would go. Start 156 ends 152.
          All other adjustments are correct now.
            So Vy and Vzbias would not adjust? Vscan was OK?
            • DaveL
              • Sep 2014
              • 90
              Va and Vs were 1-2 volts off and both adjusted correctly.
              Z bias was at 156 and would only adjust down to 152
              -VY would just bounce from 23 to 20 no matter which direction I turned the pot.
                Ok, so what is the sticker rating for Vzbias?
                Can you try unscrewing the Y-buffer boards (these boards attach to the Y-sustain and have the orange ribbons coming out of them - do not remove the orange ribbons as they are a pain in the arse to replace.) Unscrewing them will electrically disconnect them from the circuit, so then if -Vy returns to normal, it would indicate bad buffer boards are causing a fault.
                And I'm guessing Vscan / Vsc measured correctly.
                • DaveL
                  • Sep 2014
                  • 90
                  Sticker rating for Z bias is 100
                  OK..The Y buffer is the long board to my left with all the ribbon connectors?
                  This board is held in place by 3 screws...Do I disconnect Y buffer from the 2 connectors on the Y board?
                  • ERICSSON89
                    • Oct 2014
                    • 46
                    • NIGERIA
                    #29
                    yes disconnect the ybuffer from the y board
                    • DaveL
                      • Sep 2014
                      • 90
                      Ok...With Y buffer now disconnected from Y board the reading on Z bias is now as high as 143 and as low as it will go is 128. The readings before were 156 to 152. Sticker is 100
                      • DaveL
                        • Sep 2014
                        • 90
                        From looking at individual boards on a site,the board I disconnected is the Y driver...the Y buffer is mounted on the left bottom of the panel and marked XL.
                          That board is the X-buffer. You want to disconnect the boards running from the top to the bottom of the panel, on the left hand side when looking from the back of the TV.
                          Make sure to fully secure the metal heatplate on the X-buffer, if you've removed it already.
                          • ERICSSON89
                            • Oct 2014
                            • 46
                            • NIGERIA
                            #33
                            now he is making mistakes I think he should upload picture of the inner full back side of the set with cover off
                            • DaveL
                              • Sep 2014
                              • 90
                              No..I didn't bother the X buffer.
                              I disconnected the board on the left with the ribbons labeled YDRV/TP that plugs into the YSUS board.
                              • DaveL
                                • Sep 2014
                                • 90
                                Lets not do anything that involve my camera! LOL!!
                                  Ok, and please check -Vy with that board removed too.
                                  • DaveL
                                    • Sep 2014
                                    • 90
                                    Vy now bounces between 24 and 22
                                    • DaveL
                                      • Sep 2014
                                      • 90
                                      VSC is at 120
                                        Ok, it sounds like you have a problem with the Y-sustain board. Probably the IPM on it. Info about testing the Y-sustain IPM is here:
                                        http://blog.coppelltvrepair.com/2011...s-ipm-for.html
                                        (You can do the test in circuit)
                                        The IPM is the large device mounted under the heatsink. It is very difficult to remove although with patience and skill it can come off. I haven't ever tried to replace one.
                                        This fault could also potentially be caused by a PASS FET failure, these would be three MOSFETs mounted on the heatsink on the Y-sustain board.
                                        • DaveL
                                          • Sep 2014
                                          • 90
                                          Ohhh ok..
                                          I have to run to the pharmacy right now...when I return I will look at the IPM info.
                                          Thank you for your help.I really appreciate it.
                                          Be back in about an hour.
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 (third and final post, hopefully!)
                                            by valvashon
                                            I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
                                            Problem was no cold startup; it would only startup when you applied a heat gun to the board....
                                            10-22-2025, 12:33 PM
                                          • oneduane
                                            Samsung Plazma Blues Model PN59D550C1F
                                            by oneduane
                                            I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2...
                                            09-07-2023, 08:17 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 no standby LED; (new problem)
                                            by valvashon
                                            Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
                                            Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
                                            Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
                                            08-30-2023, 10:41 AM
                                          • tbsmith
                                            Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
                                            by tbsmith
                                            There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
                                            08-11-2025, 06:15 PM
