Vizio E320VL won't turn on
  • CraigR
    • Dec 2013
    • 970
    Vizio E320VL has the amber logo lite in front but will not turn on or do anything but have the logo amber. I checked fuses and caps "look" ok and I have 5volt but no 12volt at the plug. I was reading here on this issue and people mentioned chip U18 giving problem so I replaced that and still have the same issue. any help is appreciated.
    Re: Vizio E320VL won't turn on
    You will not get the switched 12V until the main board sends out PS_ON signal to turn on the power supply.
    You should check and report the Voltage readings of the regulator IC on the main board in the format as shown in this thread:
    https://www.badcaps.net/forum/showthread.php?t=22231
    • ecking767
      • Oct 2009
      • 492
      there is a very good chance of a bad eeprom chip, but I will still check regulators, HDMI chip for over heating and the main board cpu for over heating. Just to be on the safe side.
      sometime heating up the eeprom chip with a hot air gun will help determine if the eeprom chip is the problem. its might power on.
      • Shinju
        • Mar 2014
        • 1239
        I going to go with a bad EEPROM, seems to be the consensus repair on this line of Vizio Panels as I have had 2 that both needed it.
        Just my 2 cents worth.
          According to post 1 "I was reading here on this issue and people mentioned chip U18 giving problem so I replaced that and still have the same issue. any help is appreciated." he did replace U18 EEPROM IC, http://www.shopjimmy.com/vizio-e320v...eprom-only.htm
          • Shinju
            • Mar 2014
            • 1239
            Possible he got a bad one or the wrong one? I know these are VERY susceptible to static discharge damage.
            The first time I ordered one, they sent me the wrong one in a package that had the correct model number, when putting it on we didn't noticed it and the TV wouldn't come on as before. After the right one was installed it fired up and is still working.
            Vizio panels give me a headache!
            I just got an older Vizio GVL42 that would do 2 seconds to black, no audio or nothing... Was about to toss it since it was only 720p no stand or remote but then I did a quick search and if it was used as a PC monitor in VGA input and was powered down suddenly or power outage that it would cause the panel to not fire up all the way and shut down as soon as the backlights kick on.
            SO to fix it, I read all you had to do was when the TV was in standby HOLD down the INPUT button for 5-10 seconds and it would power on the TV and move it out of VGA mode.
            So I tried it and it worked, and is still working.
            Craig, you might want to try holding down the input button for 5-15 seconds to see if that works. Worth a shot anyway
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              I would check out the voltage reg. like BudM says. The unit is not powering up completely, which indicated a power problem. The software seems to be saying it will not go any farther because it is reading an error on power up. Perhaps something like holding down a button clears some error register I do not know.
              • Bob1394
                Vizio M65-C1 | Logo appears for 10 seconds then off
                by Bob1394
                I have used the search, and am stumped.
                My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                https://www.badcaps.net/forum/showthread.php?t=81088
                https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                Observations
                1) [Interaction] Power turned on via TV button (or remote)...
                02-08-2023, 01:03 PM
              • Super360
                Vizio E701i-A3 Vizio logo flashing then turns off
                by Super360
                Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                07-25-2024, 07:06 PM
              • Mulp
                VIZIO M65-C1 Does Not Turn On
                by Mulp
                Hi All,
                I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                01-13-2024, 09:57 PM
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • mrtek
                Vizio M65-C1
                by mrtek
                Hi.
                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                07-14-2025, 07:28 PM
