Vizio M65-C1 No Power
  • Kenable
    • Dec 2019
    • 30
    I have one of these where the front power indicator will come on when i first plug it in but then it just fades off.
    Measured the 12v power and it is a solid 19v which as i understand is normal. Not measuring any 5v standby voltage or 24v. When i unplug the main board from the power board still no 5v or 24v. I've heard there is suppose to be a LED that will be solid red on the main board but it is not on at all.
    I spoke to Vizio tech support and they said it was a problem with the power board, but there doesn't seem to be any in stock so hoping someone could help me troubleshoot it.
  • nomoresonys
    • 12305
    • U.S.
    Re: Vizio M65-C1 No Power
    Check all your diodes for starters, if you have a multimeter.
    • Kenable
      • Dec 2019
      • 30
      All of the diodes I could find seem to be ok, ~.5-.8 v across them
      • nomoresonys
        • 12305
        • U.S.
        And if you reverse the probes you get 1 right, or no reading? check them in diode mode, tv unplugged,as always BE VERY CAREFULL when working with powerboard, DEADLY voltages on the HOT side.
          How about reporting the Voltage for each pin of the power supply connectors?
          Please make sure to report in the format (Pin name follow by the Voltage reading) that we can easily what is there and not there for each pin when the TV is off and when the power switch is activated.
          Also upload good clear pictures of the whole backside of the TV showing how the boards are connected together.
          • Kenable
            • Dec 2019
            • 30
            OK, finally was able to Take some measurements...yes when i reversed the leads in diode check mode it read 1
            CN9101 -__________OFF____ON
            PIN 1 - +5V/+3.5V__5.1V____5.2
            PIN 3 - +12V -______19V____19.0
            PIN 5 - +12V -______19V____19.0
            PIN 7 - +12V_A _____19V____19.0
            PIN 9 - GND -________0V_____0
            PIN 11 - GND ________0V_____0
            PIN 13 - 3D _________0V_____0
            PIN 15 - ON/OFF _____0V_____3.3
            CN9102 -
            PIN 2 - +5V/+3.5V -___5.1V__5.2
            PIN 4 - +12V - _______19V___19.0
            PIN 6 - +12V - _______19V___19.0
            PIN 8 - +12V_A -______19V___19.0
            PIN 10 - GND -________0V____0
            PIN 12 - GND - ________0V____0
            PIN 14 - PS_ON -_______0V___3.7
            PIN 16 - DIM -_________0V____3.3
            CN9201 -
            PIN 1 - ON/OFF - ______0V____0.1
            PIN 3 - 3D ___________0V____0
            PIN 5 - GND __________0V____0
            PIN 7 - GND __________0V____0
            PIN 9 - GND -_________0V____0
            PIN 11 - +24V - _______0V____24.0
            PIN 13 - +24V - _______0V____24.0
            CN9203
            PIN 2 - DIM - _________0V____3.3
            PIN 4 - +12V - ________19V __19.0
            PIN 6 - GND - _________0V____0
            PIN 8 - GND - _________0V____0
            PIN 10 - +24V -________0V____24.0
            PIN 12 - +24V -________0V____24.0
            PIN 14 - +24V - ________0V____24.0
            Back of TV picture attached.
              OK, I am confused, your post #1 indicated no 24V but your post #6 shows 24V is present when PS-ON command from the main board is present.
              So far what you show on post #6 the power supply board is putting out Voltages as it should.
              Since you do not have any indicator light which is driven by the main board, I would try disconnecting the WI-FI card first and see what will happen.
              • Kenable
                • Dec 2019
                • 30
                Yeah i noticed the 24v as well, I'm wondering if the way i measured it is a problem. I had the board upside down and measured the underside to get at the pins and used a ground on the cold side of the board. (I did have the board insulated so nothing would be shorting out.)
                I can try removing the WiFi board...which one is it?
                • nomoresonys
                  • 12305
                  • U.S.
                  In your picture as you look at it, it's far left small unit, it goes to top right of mainboard.
                  • Kenable
                    • Dec 2019
                    • 30
                    Ok tried unplugging WiFi board, still no picture
                    • Kenable
                      • Dec 2019
                      • 30
                      So i guess the new question is, anyone know why i get no picture but the power board seems to be ok?
                      • budwich
                        • Jul 2015
                        • 3097
                        you might want to look closer at the two "on/off" pins on the two different connectors to see what's up with them. My first guess would be you have a backlight issue which is causing the set to shut down.
                          But do you have backlights? or if the backlighs even flash on for seconds before going into shutdown.
                          • neilc6
                            • Nov 2015
                            • 1550
                            Vizio M Series have BGA issues on main boards. Symptom is usually no BL-ON (ON/OFF) signal from processor. https://www.badcaps.net/forum/showthread.php?t=80093
                            But here
                            PIN 15 - ON/OFF _____0V_____3.3 <<< present from main board
                            CN9201 -
                            PIN 1 - ON/OFF - ______0V____0.1 <<< not-present from ps board
                            Believe the second connector is signal to LED driver board. Double check that measurement and trace it back to the first connector.
                            • Kenable
                              • Dec 2019
                              • 30
                              Ok i rechecked and made some observations:
                              When i plug it in the indicator light on the lower left front of the TV comes on then fades off.
                              Right after plugging it in but before powering it on, checking the voltages... the 24V pins looked like they were slowly discharging down from 24V.
                              Checking this again I don't have the 3.3V When powered on:
                              PIN 15 - ON/OFF _____0V_____0.1
                              After i had powered the TV on and was taking measurements, i noticed that the left front power indicator light came back on then faded off on its own (I wasn't touching anything or taking any measurements when it did that)
                              I do not see any backlights turn on or anything on the screen at all when plugging it in or powering on...only the left front power indicator coming on then fading out.
                              • Kenable
                                • Dec 2019
                                • 30
                                So updated question, does the missing on/off voltage or any of the other observations give any clues about what is failing?
                                • Kenable
                                  • Dec 2019
                                  • 30
                                  Finally was able to take a look at the main board and all does not appear well. On the back of it is all this residue. Anyone know if that can just be cleaned off or is that the blood of a dead CPU oozing onto the board?
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    some one did some "washing". What is the history of the set?
                                    • Kenable
                                      • Dec 2019
                                      • 30
                                      I got this new from Costco about 4 years ago. Sadly I only had 3 years warranty on it. I noticed the picture from the post mentioned above shows a main board that looks similar and replacing the board seemed to fix it.
                                      I ordered one from eBay, hopefully it's the correct one and it works!
                                      • Kenable
                                        • Dec 2019
                                        • 30
                                        No backlights, only the power light that comes on then goes out
