Vizio E701i-A3 Vizio logo flashing then turns off
  • Super360
    • Jul 2016
    • 243
    Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power was applied and turning off. I have replaced both the motherboard and t-con board to only have the same symptoms and no fix. I'm wondering now if something else got smoked in the psu other than the ac filtering caps or maybe leds blew too? Or possible even the display is destroyed somehow? I really have no idea if anyone can help me out it would be very much appreciated. I can take pics of anything you guys need and I have a multi meter to test voltages and stuff.
    btw the three blue new caps are the ones I replaced obviously. The old ones were very much bulged and actually exploded there tops.
    Thanks.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    That would look like the early-LED era, (2012) but I see blue caps that I suspect are high-voltage inverter caps, which are found with CCFL LCDs! SMH! (the little blue circular caps)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Super360
      • Jul 2016
      • 243
      I'm pretty sure this is a led tv and again just so I don't confuse anyone the picture with the 3 big caps highlighted in red are the one's I replaced. I never caught a picture of the three bulging and exploded caps so those are just to show what I replaced.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Not the caps that I were talking about. It's when you see caps that are tiny blue ones, next to a printed triangle with an exclamation point. Those are possibly 1 kV+ caps!
        The ones that clearly failed, are the usual 450V type of switching PSUs.
        Arc A770 16 GB
        • EazyBone
          • Jun 2023
          • 1362
          • United states
          Storms such as lightning strikes will destroy everything connected to your house, AC, fridge etc so it's not a storm.
          Plug everything in as normal, test 12v like to main board and stby voltage. Are they steady and what's the numbers. Also what's the voltage on the caps you replaced.
          If all those caps blew on the PSU I would suspect the PSU is somehow the culprit and start here first.
          The symptoms you talk about though are super common main board failures. Vizio freeze logo and turn off has generally been a CPU issue. Buying a used board off eBay you will sometimes get defective stuff as well...
          Start with testing voltages on PSU if you have 12v, see if you have 12v on the fuse of the TCON as well. Report back. Give a closer pic of PSU legend also.
          Edit, if you get vizio logo without distortion, in my experience it seems the panel is likely okay, still a chance but probably good. And with many Vizio's that I have had if the backlights are bad you can take a flashlight to the screen and still see a picture. So maybe you have a picture and you think it's turning off.. when just the backlight is going out. There's a few things you can test and let us know
          • Super360
            • Jul 2016
            • 243
            thanks for response hear you go. I'm also getting 120 out the main fuse at both ends. I don't believe it's the motherboard as the first one I replaced it was a e-bay cheapo but I bought a shopjimmy board and both motherboards exhibited the same issue.
            • EazyBone
              • Jun 2023
              • 1362
              • United states
              Not concerned about the fuse I want to know if 3.3v is steady and 12v reg. What's the numbers
              • nomoresonys
                • 12332
                • U.S.
                • Super360
                  • Jul 2016
                  • 243
                  I wrote the readings on the attachment.
                  • EazyBone
                    • Jun 2023
                    • 1362
                    • United states
                    Thx didn't see pictures with voltage, change meter to DC and measure main caps.
                    Did you check with flashlight on screen? 3.3v getting on BL error pin, I can't remember if it's supposed to be 0 or 3.3.
                    Interesting problem here.
                    • Super360
                      • Jul 2016
                      • 243
                      Ha, so I just shined a flashlight on it and could faintly see the no signal on the screen. Then I clicked input and could see even more with the flashlight. So I feel like a dummy for not doing this test in the first place but would this mean bad leds? Also changed to dc and they're fluctuating but about 350v dc for those main caps. I really thought the hot side of the power supply was always ac ooops. Thanks again man. How should I continue? Should I tear it apart and look for bad leds? I'm familiar with changing out leds in these tv's. I also have a led tester as well.Thanks.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Is that really 300 LEDs or nearly 300 LEDs in-series?!
                        Arc A770 16 GB
                        • EazyBone
                          • Jun 2023
                          • 1362
                          • United states
                          Hot side can be tested differently I've learned. Generally testing hot side you need hot ground and something else, but those.main caps can be tested DC.
                          No don't take apart the TV what you do is you take off the connector at the power board and then you stick the probes of the LED tester on the positive and negative part and they will light up and show a voltage across them you have to do it for each set if one of them reads short then it's your LEDs minimally
                          Also, welcome
                          Edit you have 3 led circuits to test at the top from the PSU picture
                          • Super360
                            • Jul 2016
                            • 243
                            Also, welcome
                            167 volts on all 3 led strips
                            • Super360
                              • Jul 2016
                              • 243
                              here's the strips for this model https://www.ebay.com/itm/36495880113...3ABFBM1uqOl55k
                              • lotas
                                • Jan 2016
                                • 4900
                                • Russia
                                Who checks this way, you want to burn the power supply (backlight driver...) of the TV by supplying power to the led out output, the connector must be disconnected from the board, and then supply power to the LEDs...
                                • Super360
                                  • Jul 2016
                                  • 243
                                  It seems there is a lot of threads on this tv with similar issues and it looks like they all gave up damn. Would love to get this tv fixed up again.
                                  • Super360
                                    • Jul 2016
                                    • 243
                                    ok sorry will do next time. I turned it on and it's doing the same thing so It will be fine.
                                    • EazyBone
                                      • Jun 2023
                                      • 1362
                                      • United states
                                      Yes!! I said take off the connector, don't leave it connected! Do it again! If they all light up, you got a bad PSU most likely. The thing that blew up in the first place lol.
                                      • EazyBone
                                        • Jun 2023
                                        • 1362
                                        • United states
                                        If all the LEDs light up, I'm willing to bet PSU bad, something isn't giving current to LEDs.. I've had this happen on Vizio. !!
                                        • ossroy
                                          Vizio M60-C3 powers on, perfect logo, turns off
                                          by ossroy
                                          Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
                                          My kids are getting antsy waiting...
                                          08-03-2022, 08:11 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
