Bush lcd40fhda8
+ More Options
Posts
  • Robbiboy1970
    • Aug 2014
    • 6
    • England
    Bush lcd40fhda8
    Ok so I got given this LCD by a friend who was clearing his garage "it won't turn on" he said ,,,,,,I've tested the voltage on psu seems fine ,the backlight works ,so I'm guessing main board problem but don't know how to check these " EEPROM" ,,,,so I ordered a replacement board from TVparts uk now I get bad solariziation on screen,,,,two questions ,,can my original board be repaired or my replacement board be reset (on option byte) but I need a service code
    Re: Bush lcd40fhda8
    Would help to post pictures of the fault.
    • Clydeuk
      • Jan 2012
      • 193
      Re: Bush lcd40fhda8
      Is the main board you got identical (as in from the same TV/correct display type). This problem is common if the board is for a different display. In some sets you can change display type in the service menu, but if it's a recent Vestel chassis you would need to change the firmware, I've had no luck getting firmware from Vestel (other than for Comet OEM products)
      • Robbiboy1970
        • Aug 2014
        • 6
        • England
        Re: Bush lcd40fhda8
        yes identical boards,,,when i ordered the replacement board i quoted the model number..i can go into software update but what with and where from is another matter..her are some pics of the 2 identical boards
        • vinceroger69
          • Mar 2012
          • 6714
          Re: Bush lcd40fhda8
          can you post a picture of the fault shown on the tv screen i see toms asked you for the same too.
          • selldoor
            Slow Learner
            • 7870
            Re: Bush lcd40fhda8
            Pictures are poor - need to be in focus - are they Vestel? What are the board numbers.
            • Robbiboy1970
              • Aug 2014
              • 6
              • England
              Re: Bush lcd40fhda8
              ok, here are some pics of "solarization" and a settings menu..main board no: T.MD306.9A 10331.........PSU no:MLT668L-VM
              • selldoor
                Slow Learner
                • 7870
                Re: Bush lcd40fhda8
                Ok you need to find the Tcon Board get the board number and post it
                  Re: Bush lcd40fhda8
                  If the panel is made by AUOPTO, the T-CON should looks something like this:
                  http://flattvparts.co.uk/bush-lcd40f...w04-vb-ctrl-bd
                  Or SAMASUNG panel version:
                  http://www.ebay.com/itm/V460H1-C11-V...-/281111520069
                  • Robbiboy1970
                    • Aug 2014
                    • 6
                    • England
                    Re: Bush lcd40fhda8
                    t-con board number T315hw04 v0 ..
                      Re: Bush lcd40fhda8
                      Which versions? V0? look at the numbers on the barcode sticker.
                      V3: http://www.shopjimmy.com/auo-55-46t0...-con-board.htm
                      V0: http://www.shopjimmy.com/auo-55-46t0...-con-board.htm
                      • selldoor
                        Slow Learner
                        • 7870
                        Re: Bush lcd40fhda8
                        Ok so you need to test and list the 13 gl voltages that are in a line with 1 below - the description for them is above,
                        There is also another 4 points I cant see the description for and i that is VGH
                        there should also be a VGL if you can spot it.
                        • Robbiboy1970
                          • Aug 2014
                          • 6
                          • England
                          Re: Bush lcd40fhda8
                          ok here goes from left to right on pic above,, the point on its own 27.2 the 4 together read .023 , .006 , 0.1 , 1.3 , the points (long combo) 0.6 , 3.1 , 4.6 , 5.4 , 7.2 , 7.7 , 8.5 , 9.0 , 9.9 , 10.7 , 12.2 , 14.8 , ,,,the point under them on its own is 15.1,,,,there are 4 other points near the connector all around 3.1
                          • boosti45
                            Macbook pro logic board replacement parts quesion
                            by boosti45
                            i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                            08-21-2024, 05:23 AM
                          • tuner2000i
                            Philips 65PUS8518/12 distorted image after main board replacement
                            by tuner2000i
                            hello everyone,
                            I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                            The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                            07-15-2025, 01:15 PM
                          • Cvrado
                            Led TV Board Replacement, same part number and model, different size
                            by Cvrado
                            Hello my friends!
                            I have a question that I think you can answer and help me with!
                            I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
                            So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
                            My concern is that the board won't draw enough voltage to the bac...
                            03-02-2024, 05:05 PM
                          • eum
                            PSU Board repair or replacement Ecler Nuo 2.0 DJ mixer
                            by eum
                            I try to repair this fly-back type PSU, I diagnosed (identifiable) dead N-MOS and fuse, but there are 3 smd resistors on the bottom that burned and became unreadable.
                            The support in charge of the brand in France managed to get me the schematics from Ecler, but it didn't include the PSU board. After a while they finally told me that the unit was too old so they don't have the PSU board schems.
                            I can find replacement PSU board online, but only for the Nuo 3 or 4 or 5, and it seems they ar compatible with each other, as I often find boards compatible with these...
                            07-28-2023, 03:05 PM
