Led TV Board Replacement, same part number and model, different size
  • Cvrado
    • Mar 2024
    • 4
    • Portugal
    Hello my friends!
    I have a question that I think you can answer and help me with!
    I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
    So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
    My concern is that the board won't draw enough voltage to the backlight!​
  • Cvrado
    • Mar 2024
    • 4
    • Portugal
    Even the components are all identical and the structure and design are the same .
    I only find a MOSFET that o presume it is a Jumper Junction Power MOSFET . Is the MOSFET responsible for a push up voltage? Or will the board manage for itself the necessary voltage to the backlight has the moment it is connected ?
    • Cvrado
      • Mar 2024
      • 4
      • Portugal
      2 pictures are from my faulty board (65" led TV), and other picture is from the replacement board !
      Has it reads on it's label (150-165V) on 65" faulty board. And it reads (87-99V) replacement 43-50" board.
      I have been searching and one some they say that if the resolution is the same and part number and components structure is the same it will work!
      But on others they mention the eventually of a different DC to DC structure!
      The only difference I can spot by the picture is the on the inverter side of the board my bigger TV (150v backlight) have 3 big and same size capacitors and the other board has 1 big and other 2 smaller !
      • lotas
        • Jan 2016
        • 4813
        • Russia
        You will need to update, change the software for your panel via usb, (If it is possible to change it in service mode or through the console)
        • Cvrado
          • Mar 2024
          • 4
          • Portugal
          Hi lotas , thanks for the reply!
          So if I change the software version or check for screen size on the service menu the backlight driver will change its values to push up from 68V to 150V ? No need to change anything by hardware ?
          • lotas
            • Jan 2016
            • 4813
            • Russia
            Here you also need to look at the position resistors in the backlight driver, current sensors, the number of the transformer (matches the other one), and the voltage on the capacitor (whether it matches the voltage should be 200v-250v)
            Carefully inspect this area for the nominal value and location of the resistors.
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • boosti45
              Macbook pro logic board replacement parts quesion
              by boosti45
              i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
              08-21-2024, 05:23 AM
            • tuner2000i
              Philips 65PUS8518/12 distorted image after main board replacement
              by tuner2000i
              hello everyone,
              I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
              The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
              07-15-2025, 01:15 PM
            • snipersquad100
              Dewalt DCR020 Power Board – No Power, Need Help Identifying ICs / Possible Replacement
              by snipersquad100
              I’m working on a Dewalt DCR020 jobsite radio that won’t power on.
              So far, I’ve checked the following:
              • The mains is reaching the transformer
              • Transformer outputs ~15-20 V AC
              • Bridge rectifier outputs ~15-20 V DC
              • All fuses test OK
              • The on/off button signal reaches the PCB connector
              Despite this, the unit does not power up at all.
              Inside, I’ve identified some of the ICs:
              • ST7317 (appears to be an LCD driver, not the main MCU)
              • LM2937L (voltage regulator)Not putting out power, 0.5V on the input
              • Markings like FS1235, unknown IC
              • Board number:
              09-01-2025, 10:57 AM
