Is it possible to bench test an inverter board?
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    On a recent ebay sale, I think I've got a bad buyer who might be returning me his broken inverter for a "refund". Claims the power supply was the problem, but I've heard that bad power supplies can burn out inverters anyway.
    Also, are there unique serial numbers or markings on some tv boards?
    Thanks much for any ideas.
  • SteveNielsen
    Retired Tech
    • 2327
    Re: Is it possible to bench test an inverter board?
    Yes it is possible to test an inverter board on the bench, which raises the question; Was it tested and working before you sold it?
    • tucocaps
      • Apr 2013
      • 331
      • United Stated
      steve: The panel had backlight and color, but was cracked.
      • tucocaps
        • Apr 2013
        • 331
        • United Stated
        So , how do I go about the bench testing? Thanks for any help.
        • SteveNielsen
          Retired Tech
          • 2327
          Please post the make/model info and good pics of the top and bottom of the inverter board. Then someone here can probably help you.
            It is extremely rare for a PSU to kill an inverter in any way. The inverter will be fine. What you should do is check transistors & fuse on it, and in future write down a unique serial number on it.
            • DemonBG
              • Mar 2012
              • 143
              your best bet for the future to prevent something like this happening is to put a small (with a permanent marker or such like) mark somewhere inconspicuous such that only you know its there - if they send their own, faulty one back then you know they have tried a switcharoo!
              good luck,
              Demon
              • selldoor
                Slow Learner
                • 7870
                I think you need to clarify what you mean.
                What did you Sell. Power supply Main Board Inverter
                On two or all three
                Is he saying he bought an inverter and his power supply broke it?
                Is he saying he bought a power supply and it broke his inverter?
                Is he saying he bought both and both are faulty?
                Dont you have pictures of the items you sell on ebay? almost every board
                will have a slight difference.
                • tucocaps
                  • Apr 2013
                  • 331
                  • United Stated
                  40MF401B/F7 backlight inverter. Here is a picture. I think the board may be the same one sent to the buyer, but would like to make sure it's still in working order. Thanks for any idea on how to bench test this.
                  • tucocaps
                    • Apr 2013
                    • 331
                    • United Stated
                    anyone have an idea on how to test this? thanks!
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      Without a schematic for the board you still might be able to figure it out from the pinout and specs of the chip that is below the white connectors in your picture.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        I sent a working main board from a set with a bad tab bond out a few weeks ago with a serialized "VOID IF REMOVED" label clearly stuck on the back. The buyer claimed it didn't work and sent a board back with no sticker on it, that was warped, had obvious other damage, and had a different serial number on the OEM label. I had pictures showing what I sent and what I received. Ebay still refunded his money. He claimed that he sent my board and that I must have swapped it.
                        • SteveNielsen
                          Retired Tech
                          • 2327
                          That sucks. What kind of proof or chain of evidence is required? Stories like these is why I do not use ebay.
                          • tucocaps
                            • Apr 2013
                            • 331
                            • United Stated
                            Not sure exactly what you mean by that. Based on my experience, I don't think I'll be able to figure it out from any information on the board itself.
                            • SteveNielsen
                              Retired Tech
                              • 2327
                              What I mean is,
                              does the chip have anything printed on it? If you can identify it you may be able to get a pinout of it and determine what voltages need to be applied where to operate it and possibly turn the board on so you can bench test it.
                              • selldoor
                                Slow Learner
                                • 7870
                                I may be wrong but I am not sure you should power up a board without lamps. I believe it might damage the inverters. In normal use the error detection from not having a bulb would switch off the power supply saving the inverters but using an external supply that would not happen. In any case without bulbs there has to be a limit to what you can test.
                                Secondary Voltages would be too high. I dont really think you can bench test it stand alone - that is without more parts, but I often think wrong
                                • SteveNielsen
                                  Retired Tech
                                  • 2327
                                  I wasn't suggesting that. Find out what the thing is first. Knowing what the chip is, is a starting place.
                                    You will need 8 lamps and 24V power supply with current rating at least 7A.
                                    I never try testing the board by itself before but I will give it a try in the future since I have lots of spare power supplies.
                                    ftp://helpedia.com/pub/temp/datashee..._LTA400HM09_0_[DS].pdf
                                    • SteveNielsen
                                      Retired Tech
                                      • 2327
                                      Dead link Bud.
                                      • SteveNielsen
                                        Retired Tech
                                        • 2327
                                        I have bench tested an inverter board from a laptop but it only required one CCFL tube connected to work (laptop had two tubes running from the same board connector in parallel) and I use it for testing individual tubes now. No matter what the inverter type is you will have to know where and what voltages to supply. There's Vcc supply voltage, enable signal voltage, dimming control voltage, etc. That's why the need for a schematic or at least the pinout & specs of the chip. Whether or not you need all 8 tubes connected or not for it to work is not known. It is possible but good trouble shooting techniques written up here suggest that it is not necessary; i.e. disconnecting tubes and trying to light one at a time to check for bad tubes, and the opposite; removing one tube at a time.
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • Nicktronic
                                          Bench Test Samsung BN44-00621C Power Supply Board
                                          by Nicktronic
                                          Hey!
                                          I've got this power supply board that's had some components replaced and I'd like to confirm all the voltages before I install it.
                                          This is what I have when I plug in the board on the bench;
                                          1 - N.C. - 0 VDC
                                          2 - PWM_DIM4 - 0 VDC
                                          3 - N.C. - 0 VDC
                                          4 - PWM_DIM3 - 0 VDC
                                          5 - GND - 0 VDC
                                          6 - PWM_DIM2 - 0 VDC
                                          7 - B13V - 0 VDC
                                          8 - PWM_DIM1 - 0 VDC
                                          9 - B13V - 0 VDC
                                          10 - ECO_ON/OFF - 0 VDC
                                          11 - Vamp - 0 VDC
                                          12 - BLU_ON/OFF - 0VDC
                                          13 - Vamp - 0 VDC
                                          14 - GND - 0 VDC...
                                          07-11-2023, 12:32 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
