Hisense H55U7B vertical stripes
This topic has been answered.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4537
    • Italy - Milan
    #41
    Check the uClamp6514P (UCLAMP6514P.TNT) or uClamp4014P
    • howardc64
      • Jun 2017
      • 653
      Originally posted by halen
      Yes, it's attached to the main frame with 6-7 bolts. Another question where to get SP1064E-04UTG Tvs diode component. Or some alternative on AliExpress. Because I found one in Mouser, cost low, but shipping of parcel costs a lot.
      I did this repair on Vizio and got free SP1064E from littlefuse sample request (USA). Couldn’t find on AliExpress. None in my salvage buffer boards pile. Mouser was only other option I found.
      https://www.badcaps.net/forum/troubl...96#post3489096
        • 12328
        • U.S.
        #43
        Originally posted by lotas
        I wrote about this in post 11.
        Yes you did, nice solve lotas.
        • Diah
          • Feb 2013
          • 6560
          at my post #22 i wrote scrap it, why i did , we are talking on gate transistor inside the glass panel, its the always the main problem to let ESD diode get difect, ESD are just protection, remove them from buffer TV will work, but we still have the gate play crazy,,, lets go over all posts about same ESD issue ir replaced or just removed... did their TV still working ?? i have big doubt ..
            • 12328
            • U.S.
            #45
            Very interesting Diah, that does make me wonder if they are failing again after replacement and or failing if left off.
            • howardc64
              • Jun 2017
              • 653
              I have 2 Vizios with ESD replacement fix. The TVs get very light usage. I will update results in a few months.
                • 12328
                • U.S.
                #47
                Thank you sir. You are a scholar and a gentleman.
                • halen
                  • Jun 2011
                  • 16
                  #48
                  TV is fixed, thanks to all. Replacement of diodes were little bit tricky, I used microscope, but finished and working.
                  • angelos
                    • Dec 2012
                    • 573
                    • South Africa
                    #49
                    Hi Halen,
                    If the set does damage those ESD devices again, will you let this forum know. I am curious on the outcome.
                    Regards
                    A
                      • 12328
                      • U.S.
                      #50
                      Originally posted by Document Archive
                      Just to address the experts on this post complaining about the new layout. previous vbulletin had major security issues so there was no choice to upgrade. I have made alternate (including dark mode) available in the footer and will release more soon.
                      As for being ad revenue orientated. this site makes a significant loss each month which is only partly subsidized by ads.
                      Alright so you had to change the layout, can you at LEAST put the country of the original poster. So we don't have to guess where they are and what mains electricity they use?
                        • 12328
                        • U.S.
                        #51
                        Oh my bad, guess halen just didn't bother to list his area of residence.
                        • Unspun01
                          • Jun 2011
                          • 349
                          Great find on the ESD diode packs. I haven't seen these fail in this way, usually you can tell if one of the paths is "open" across the IC. I see these are commonly used in HDMI input circuits also (located on the traces near HDMI port). If you can't find exact replacements, I suggest seeing if you can locate any from scrap TV mainboards, or definitely on old XBOX One motherboards that are cheap and easy to find just about anywhere.
                          I don't know if the ratings are same, but might be helpful to try.
                          • Daren87
                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                            by Daren87
                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                            08-13-2023, 03:25 PM
                          • kotel studios
                            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                            by kotel studios
                            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                            08-06-2025, 02:07 AM
                          • ahoonid
                            MacBook A1990 vertical stripes on external screen
                            by ahoonid
                            Hey everyone,
                            I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                            The board is neat. Not opened before for sure. Just a little dust, nothing more.
                            Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                            06-20-2025, 08:54 AM
                          • jason123
                            Hisense 65R6E3 double-image / horizontal strips - TCON?
                            by jason123
                            Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                            07-19-2025, 08:07 AM
                          • kevinman
                            KD-55X9005A Vertical Stripes Right Side Mirrored Vertically At Start
                            by kevinman
                            Hi, TV boots with distorted image right side mirrored verticaly sometimes vertical stripes making off-on turns picture to normal and "perfect" (netflix image) that I highly doubt this is something related with t-con signal lines?? rather it looks software corruption bad mem chips voltage collapse or an intantaneous fault with fluctuating powerboard voltages?? As it happens usually when TV is cold sometimes fault comes back after a full day use should I check powerboard voltages with oscilloscope??
                            12-17-2023, 06:22 AM
