Sony Bravia KDL-46S4100 -- dead set condition
  • gpenn01
    • Jul 2014
    • 7
    Hi all....
    I have a Sony Bravia KDL-46S4100 bought new about 5 years ago. A few months back the daughter was watching the tv and it just shut off on its own.
    I have finally found some time to take a look at it and did some online searches to get me started... thus finding this forum. This is where I am at so far:
    - from this forum, I found and I am referencing the Sony training manual for this model tv.
    - tv does not power up at all.
    - verified 110V incoming to the G board (CN1)... ok.
    - verified main fuse F1... ok.
    - checked for 3.3V STBY on the G board (CN302 pin 3)... getting 0V.
    - per the training manual, the next step is to replace the G board.
    As such, I would ask for advice on my next step.... is there any thing else I can troubleshoot on the G board.... or.... just replace the G board?
    I have searched online for the board and have only found a few on ebay for ~$30-$80 USD.
    Thanks much...
    Garth...
  • R_J
    • 9557
    Re: Sony Bravia KDL-46S4100 -- dead set condition
    Here is a link to the service manual
    Do you have B+ on C801 C802 ? If you do, check for B++ on R614 that supplies the standby circuit on page 48.
    B+ should be around 160V B++ will be slightly less maybe around 100 - 120v?
    Check Q900 for short and check R937 should be 1ohm
    • nuala
      • Aug 2013
      • 37
      I would disconnect the t-con board first as it could have shorted caps and loading down the g board. See if the backlight comes on.
      • gpenn01
        • Jul 2014
        • 7
        Hi R_J and nuala....
        Thanks for the manual and the items to check.... based on that, here is what I have found:
        - disconnected the tcon board (by disconnecting the lvds cable).... no backlight... no obvious change in anything that I could see. Reconnected the tcon board.
        - Checked B+ voltage on C801/C802..... 60V.
        - Checked B++ voltage on R614.... 60V.
        - Found data sheet online for Q900 then checked gate lead to source lead.... 120 ohms (I believe this should be infinite???). All other checks between the gate, drain, and source leads checked out as infinite.
        - checked R937.... measured 1.2 ohms.
        Thanks again...
          Thanks again...
          OK, you are checking the DC voltage on the primary side of the board, you have to use the negative leg of the main filter cap as the ground ref point for your meter, not the chassis. So you need to take those voltage readings again.
          When you make voltage measurement in the secondary side you can use the chassis ground as the ground ref for the meter.
            BTW, how about good clear pictures of the back side of the TV and the power supply board.
            • gpenn01
              • Jul 2014
              • 7
              Hi Bud... thanks for the info... I have attached a few pictures as you have suggested. I am a bit uncertain as to the main filter cap you refer to... could you point me in its direction.
              Again.... thanks much....
                The two big brown caps, you must be real careful due to working in the primary side of the circuit.
                • mmartell
                  • Oct 2013
                  • 3189
                  budm means DON'T SLIP! with the probes !!
                  • truep
                    • Aug 2010
                    • 373
                    And DON'T touch the heat sinks!
                      Yeah, that too. I would at least plug the unit into GFI Outlets. You can test the power supply board by itself without having it connected to other boards since we're only looking to see if at least the standby power supply is working or not.
                      • gpenn01
                        • Jul 2014
                        • 7
                        Thanks to all for the added advice....
                        I re-checked the voltages using the negative leg of the main filter caps as the ground reference....
                        Both B+ and B++ came up as 160V.
                        • gpenn01
                          • Jul 2014
                          • 7
                          I must have been half-a-sleep when I wrote that last post.... a H.U.A. moment.... because I should have stated that B++ was 0V.....
                          I double checked the board and I am measuring voltages as follows:
                          B+ = 167V
                          B++ = 0V
                          Note: H.U.A. = Head Up A#%
                          • gpenn01
                            • Jul 2014
                            • 7
                            Update...
                            Replaced the G board.... unable to find this specific board (# DPS-275MP-1A) at ShopJimmy or any other places online... found and ordered a used one from Ebay.... installed it tonight and TV is now working....
                            • PopsCaps
                              Sony Bravia KDL-40V2500 that will not power on
                              by PopsCaps
                              I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                              I do not hear any sound and I cannot see any backlight.
                              I have tried disconnecting every cable on each board one at a time to see if anything changes.
                              The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                              My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                              03-25-2025, 11:23 AM
                            • justin35
                              Sony bravia kdl-43w755c - boot loop
                              by justin35
                              i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                              from what i read online it looks to be an emmc issue…
                              i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                              i took out the board and say an samsung 16gb emmc
                              i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                              i could try to put one instead of the 16gb one, but will it work?
                              where do i get the software from?
                              any help will be much appreciated!...
                              03-06-2024, 12:26 PM
                            • Arshad alam4659
                              macbook a1706 in dead condition
                              by Arshad alam4659
                              today i received a macbook a1706 in dead condition When I removed the battery the laptop started up i connect the battery again and press power button but laptop not turn on
                              I did smc reset and the laptop started . I have to reset the SMC every time to turn it on. It does not turn on without resetting the SMC. Sometimes it starts without resetting the SMC.
                              someone guide me what is the problem bad smc or anything
                              12-19-2024, 02:41 AM
                            • thstuff
                              Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                              by thstuff
                              A) TV initially dead
                              B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                              C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                              D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                              E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                              12-26-2024, 09:10 PM
                              Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                              Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                              10-16-2024, 05:15 AM
