Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • JUCaESAl
    Sony bravia KD-65AF9
    by JUCaESAl
    Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
    Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
    10-20-2025, 04:03 AM
  • PopsCaps
    Sony Bravia KDL-40V2500 that will not power on
    by PopsCaps
    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
    I do not hear any sound and I cannot see any backlight.
    I have tried disconnecting every cable on each board one at a time to see if anything changes.
    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
    03-25-2025, 11:23 AM
  • alegatorul
    sony bravia kdl-43w756c, no power, no sound
    by alegatorul
    the charger brick has 19,2-19,3 vcc
    changed the inverter board same result.
    where should i start?
    cheers
    Yesterday, 10:00 AM
  • justin35
    Sony bravia kdl-43w755c - boot loop
    by justin35
    i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
    from what i read online it looks to be an emmc issue…
    i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
    i took out the board and say an samsung 16gb emmc
    i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
    i could try to put one instead of the 16gb one, but will it work?
    where do i get the software from?
    any help will be much appreciated!...
    03-06-2024, 12:26 PM
