macbook a1706 in dead condition
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    today i received a macbook a1706 in dead condition When I removed the battery the laptop started up i connect the battery again and press power button but laptop not turn on
    I did smc reset and the laptop started . I have to reset the SMC every time to turn it on. It does not turn on without resetting the SMC. Sometimes it starts without resetting the SMC.
    someone guide me what is the problem bad smc or anything
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    Customer took the laptop and he will come after a week, I noticed that if I close the laptop lid and then open it then the laptop won't turn on, I thought the hall switch is bad then I removed the j5250 and j5260 (hall effect pad) and the laptop turned on and after a few seconds it turned off, no display and I put the j5250 and j5260 then the laptop turned on and the display came on, what would be the problem
    Do I need to replace the j5250 with a new one or will the display come back on just by removing it
    • Arshad alam4659
      • Aug 2020
      • 157
      • India
      anyone help i want to disable lid sensor
      • mon2
        • 14747
        Test the SMC_LID sensor that is inside of the trackpad which may be faulty. Suggest to have available a known good trackpad for testing. You are confident that the display is not faulty from flexgate? Test if the caps key toggles after a period of boot time. Perhaps the display is dark due to this known issue with this series. If you truly disable the lid sensor, the display will continue to consume current with full on brightness and will drain the battery very quickly - even when the lid is closed. Therefore, this bypass is not the answer.
        Battery is a known good battery? Test the SMBUS SCL / SDA lines - check their voltage to ground. If either line is flaky, this can halt the boot process since the same lines are being shared with the ISL chip that creates PPBUS_G3H.
        • Arshad alam4659
          • Aug 2020
          • 157
          • India
          i tried without trackpad and without battery and without connect screen cable, with external display same issue when i closed the laptop lid and then open it then the laptop won't turn on, when i removed hall pad why laptop is turned off after few seacond without giving display
          • mon2
            • 14747
            There are sensors in the trackpad. Test with a known good trackpad for this unit.
            From post #4
            • saronno
              Macbook a1706, dead keyboard.
              by saronno
              Anyone has experience troubleshooting keyboard on this model?
              From schematics it seems an i2c keyboard, the problem is I can't find a good test point con scl and sda, in order to see if voltage is present (usually i2c works with the 2 rail pulled up with a resistor to a voltage source ... components attached to the two rail communicate pulling the line down.
              05-30-2025, 08:06 AM
            • gabrielA7
              Macbook pro A1706 / Backlight flex cable compatibility
              by gabrielA7
              Hey guys!!
              I’ve got a question here!
              I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
              Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
              Here’s what the bot told me:
              I said to him: “I’m going to install the 821-01229-A.”
              ChatGPT replied:
              Understood — but before you solder or install the 821-01229-A,
              11-11-2025, 03:26 PM
            • jesi
              macbook pro a1707 dead
              by jesi
              hi all techs
              require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
              adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
              update:
              when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
              08-24-2025, 04:34 AM
            • robka
              MacBook Pro 2018 - A1990 Dead - not charging - only 5V
              by robka
              my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
              I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
              The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
              After that the Macbook was dead. It isn't charging anymore.
              The USB-C Port where the charger was plugged is burned. Also The Cable and the...
              03-02-2024, 02:58 PM
            • Danielreinaa
              HELP need password bios Macbook A1706
              by Danielreinaa
              Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
              Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
              Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
              gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
              Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
              09-07-2024, 03:47 PM
