Vizio E461-A1 no picture or sound
  • ntehicks
    • Mar 2011
    • 272
    I am looking at a VIZIO Razor 46" LED LCD tv that is only 1.5 years old. this tv was purchased at Costco but the customer was told that the TV only has a 90 day warranty. I have pictures and tests.
    U701 5.2 3.2 0
    U702 3.2 1.2 0
    U703 5.1 3.2 0
    U102 5.1 3.2 0
    power to main board I have all correct voltages
    11.8
    24.2
    5.1
    not sure where to look next.
    so the tv turns on and the led lights up white but no picture or sound. and no backlight.
  • ntehicks
    • Mar 2011
    • 272
    Re: Vizio E461-A1 no picture or sound
    Does anyone know where I can get a service or training manual on this new of a tv. I have tested all of the voltage regulators but not sure if any of them are wrong. I tested the main rectifier when the tv was plugged in but off. and it is 168 vdc. when I push the power button that changes to 123vdc. once the tv is on the power led lights up. but the tv at this point won't turn off. the led stays lit no matter using the remote or the button on the tv to turn it off. when I unplug the tv and then let is sit and then plug it in the power light goes on and then slowly goes out.
    • selldoor
      Slow Learner
      • 7870
      Vizio SMs are like hens teeth. Here is a guide to VRs
      https://www.badcaps.net/forum/showthread.php?t=22231
      Whilst all a little low 0.05 to 0.1 they look as if they will be ok.
      Chances are it is the eeprom many cases of that being the problem on unresponsive vizios.
      There is even an after market for them which is an indication of how many are bad.
      • ntehicks
        • Mar 2011
        • 272
        is there a way to re flash the eprom while in the TV or will I need to get a new one and install it?
        • newer
          • Nov 2014
          • CA
          Hi ntechicks, have you solved the problem? I got the exactly same problem with my Vizio E461.
          • ntehicks
            • Mar 2011
            • 272
            I was looking at this for a friend. and she found out that the tv was still in warranty. The tech came to her house and replaced what she told me was a large board. I wish I would have gotten more info on what board. but once he replaced that board the tv worked.
              • 12146
              • U.S.
              prob. was the mainboard.
              • R_J
                • 9535
                It's a good chance its the U409 eeprom (flash) It's available on S.J. for $15.00.
                Being that it was under warranty, vizio would have replaced the main board not have a tech try and reflash the chip, it's not worth it.
                  • 12146
                  • U.S.
                  the one from sj comes already flashed R_J?
                  • R_J
                    • 9535
                    Yes, It would not be of much use if it did'nt.
                    • Aviretired
                      • Apr 2015
                      • Usa
                      Has anyone solved this yet? I'm having the same problem.
                      • theglubkes
                        • Feb 2016
                        I may have had the same problem. Are you trying to mount the TV to the wall?
                        I have had my model for 3 years. Yesterday I moved the TV to another room to mount on a wall. I installed a generic wall mount system that connected directly to the TV. I first hung the TV and it worked fine. I then removed the base and the "neck" that slides into the bottom of the TV. With the neck out the TV has no picture or sound. I put the neck back in and everything works fine. Vizio says that it should work fine without the next. It would be nice to know if this approach solves the problem for someone else.
                        • walterbeers
                          • Aug 2016
                          • 4
                          I am working on this same model set for a friend and it is completely dead. Power supply voltages check out ok, however when I push the power button on either the set or the remote absolutely nothing happens. I suspect it's also the EEPROM. I located it on the main board, but worried about trying to remove the old one and solder in the new. I have never had much luck soldering in surface mount components. I have the usual small pencil irons, solder wick, also a solder sucker. Since a used main board is quite expensive, (even on e bay), I am going to try my luck at replacing it. Any suggestions as to how to remove the old and replace it without ruining the board?
                          • walterbeers
                            • Aug 2016
                            • 4
                            Well, I tried removing the EEPROM, I was very careful, but still the foil lifted up on 2 of the pins. Does anyone know of where I can get a rebult main board for this model Vizio E4461-A1 Board number is 715G5560-M01-000-004X
                            • Blockboyy36
                              • Nov 2023
                              Did anyone resolve this issue? Was it ultimately the main board? Or the EEPROM ? Sure could use the feedback. Please and thank you in advance 🙏🏽
                              • EazyBone
                                • Jun 2023
                                • 1321
                                • United states
                                Thread is 7 years old. I would assume it's main board, should start a new thread. Can you test voltages etc?
                                • ggil44
                                  Vizio M65-E0 No Picture, No Sound
                                  by ggil44
                                  Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                  09-03-2024, 08:30 PM
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • Mgiffune
                                  by Mgiffune
                                  06-09-2024, 10:28 AM
                                • Ierwin
                                  by Ierwin
                                  05-13-2025, 03:31 PM
