I have a VIZIO E470VA 47-inch Class LCD HDTV 120 Hz from 2011
I have a lot of info here. I am an IT guy so I thought it would be helpful for the details up front- sorry if it's not all relevant.
Its been a good TV until recently.
During this time, the LED1 on the inverter (I think) will glow blue and fade out (approx. 3 seconds)
Additional information-
A few weeks prior to my TVs slumber, in the mornings when we turned it on, it seemed to have a “warmup” issue.
Thanks for taking the time to read!
For the first 20min or so, it would turn on and you could hear the sound and see a clean image, but it would stall on a frame for a second or so, then show an updated frame current with the sound. Eventually it would show more frames and then it was working fine until it was turned off for more than a few hours
Removed and visually inspected component for obvious heat or cap issues- none seen but not 100% sure I know what to look for
Voltages noted:
• CN903 to inverter
When you turn it on, you do not get a logo on the screen but the bezel light “VIZIO” will light up bright for the duration of the TV being on.
About a second after the bezel lights up, the screen will have a faint black glow for about 3 seconds.
As soon and the blue light fades out, the backlight glow turns off for about a half a second and then then back on.
a. The bezel light is on the entire time
b. The blue LED1 comes back on and fades out after the 3 seconds
At this point it's done doing anything and will sit like this (Bezel light on, warm even glow on the black blank screen, LED1 not lighted on inverter)
- Remote works- power on/off
- Side Panel- power on/off
- If I hit the input choices on the remote, the blank glow will change slightly like it is trying to change sources.
- No menu or volume image present on screen at any time.
Voltages noted:
• CN903 to inverter
TV in standby- no voltages on any
TV On- 24volts, on/off=5v, DIM,3v
• CN905 to MainTV On- 24volts, on/off=5v, DIM,3v
TV in Standby- 5v on 5v pins 11 and 12- no other power
TV On- on/off=5v, DIM=3v, 12vOK, 24vOK, PS/ON=5v, 5vOK
