LG TV Turning on and off constantly (trying to repair this)
  • zsemago
    • Jun 2014
    • 12
    Re: LG TV Turning on and off constantly (trying to repair this)
    Originally posted by tom66
    It is more than possible you got two boards with the same fault... sellers rarely test their pulled boards despite their claims of doing so.
    • bammbammfran
      • Apr 2014
      • 476
      take the board to that "TV Specialist" and have him resolder that mosfet
      Inverter board look good
      • zsemago
        • Jun 2014
        • 12
        You think thats it? I can't go back to the TV speciliast place as its been such a terrible experience thus far (some other snafoos too).
        I'm tempted to just buy another used power board and give it a shot as I don't know where I'd get resoldering done - my local computer place said they won't do it.
        I read up on some other threads and tried disconnecting all other power buttons in hopes there were some faulty buttons getting triggered - didn't work. Kinda narrows this down a bit more. It seems this on/off junk is a fairly common 52lg50 problem. Lots of other threads not finding too clear of an answer or the thread just ends. Buy a new board and hope for the best?
        This guys issues are quite similar to mine and it looks like even LG didn't know wtf to do - http://www.justanswer.com/tv-repair/...september.html
        • bammbammfran
          • Apr 2014
          • 476
          going back to them was more to be meant as a joke or to shove it in their face !!
          It looks like that pin is lifting itself out of the board so it is a pretty good and likely suspect
          Buy a soldering iron and some flux or borrow one from someone and do it yourself
          if buying one , get a 45 or 60 watt one with a flat type tip
          another used power supply may get the same issues .
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Agreed.....Buy a soldering iron and a roll of solder as suggested and try your hand you can do this.....just heat the work with the iron and then apply the solder and let it flow....Good luck
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #26
              Have you checked those MOSFETs don't have cold solder joints?
              Cant believe I missed that - too busy looking at the brown which didnt look like overheating to me. I usually see cracked poor joints even when there arent any . Also whilst the back of the board is not too sharp a picture the joints look ok from that side.
              Just checking - it was the main board he replaced and we are looking at the original power supply as being faulty.
              • bammbammfran
                • Apr 2014
                • 476
                I can actually see a pin hole on the back side.looks like the pin mostly just slid out
                They had a said that the main was changed, so if they used the correct wording, it was not the power supply
                Went back to first post and saw two mains in the picture. SO yes, main board
                • Steamy777
                  • Oct 2013
                  • 8
                  Hi does you tv have any picture when it goes off and on if no its your t con board shorting had the same tv same problem.
                  • lalease
                    • Oct 2012
                    Hi friends,
                    Try unplugging keypad assembly, from IR detector on/off assembly. Then try remote control, if problem goes away get new keypad or just don't plug it back in.
                    • Steamy777
                      • Oct 2013
                      • 8
                      Ok figured it out replace capacitor c 216 worked for me
                      • densmith123
                        • Sep 2017
                        I successfully repaired this problem on a TV for a friend. Please see my writeup at:
                        https://www.badcaps.net/forum/showth...925#post775925
                        • HP32Sii
                          Philips 50PUS6262/12 (chassis TMP17.7E LA) no picture
                          by HP32Sii
                          This is my first post on this forum, and my first attempted repair of a modern flat-screen LCD-TV (though I have repaired a few LCD-monitors, all with Elco-problems (high ESR). I have repaired my fair share of TV-sets and VCRs in the past ('90s) and was fairly familiar with the different Philips chassis (KT-3M, K12, K2, K3, K7 are some that come to mind). So I have a fair bit of experience on old sets. Obviously, modern TV sets are quite a different cup of tea.... no HOT or flyback-transformer inside, for starters....
                          The set came into my possession by accident,...
                          02-26-2023, 10:00 AM
                        • Mirenia
                          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                          by Mirenia
                          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                          03-30-2025, 06:47 AM
                        • orcic
                          MASTER TL240 and new mainboard LW36BKC01
                          by orcic
                          I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                          The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                          After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                          Now I have some doubts about how to connect the new mainboard to the old power supply.
                          First of...
                          05-12-2023, 08:10 AM
                        • Malva
                          Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                          by Malva
                          I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                          Mainboard model: EAX65684604
                          PCB marking: EBT62954607
                          SPI chip: Winbond W25X20CLNIG Problem description:
                          Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                          After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                          • I bought another
                          06-25-2025, 02:07 PM
                        • Devonavar
                          Vizio M43-C1 - How closely do I need to match the mainboard number?
                          by Devonavar
                          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                          So, I've ruled out the PSU for now.
                          The reboot loop...
                          08-14-2022, 08:46 PM
