MASTER TL240 and new mainboard LW36BKC01
  • orcic
    • May 2023
    • 3
    • Italy
    I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
    The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
    After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
    Now I have some doubts about how to connect the new mainboard to the old power supply.
    First of all, the new main requires 4A and I don't know if the HKL is capable of that.
    If yes, I don't understand if I can power the new mainboard with the HKL only, or if I have to connect another external power supply to the DC IN plug.
    And then, I'm not sure if the pinouts of the two boards are compatible. The HKL has a plug with 7 pins, that are connected to a flat cable that is splitted in two parts: one leads to a small connector with +5V and ground. The other part goes to another connector that is mechanically compatible with the connector on the new mainboard, but the names of the pins are different: on the HKL the pins are "12V, 12V, O/F, DIM, GND, GND" and on the new mainboard are "12V, 12V, BLON, ADJ, GND, GND".
    How to proceed?
    Last edited by orcic; 05-12-2023, 08:11 AM. Reason: add some missing "s" for plurals
  • R_J
    • 9608
    Re: MASTER TL240 and new mainboard LW36BKC01
    They should be the same pinouts, BLON= O/F (Backlight on/off) ADJ = DIM (Backlight dimming)
    If the power supply rand the original board it should be fine with the new board as well.
    • orcic
      • May 2023
      • 3
      • Italy
      If you look at this video: https://www.youtube.com/watch?v=9s69tQM2-Yo
      The guy is connecting an external power supply to the DC plug, and the connector with those "12V, 12V, BLON, ADJ, GND, GND" pins is connected to the panel directly.
      Should I assume that I'm going wrong with my idea of connecting the power supply output to the mainboard's "12V, 12V, BLON, ADJ, GND, GND" connector?
      Is it possible that the connector on the mainboard is an Input/Output? How to be sure?
      • Jembang
        coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
        by Jembang
        good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
        11-01-2024, 09:55 AM
        by sam_sam_sam
        03-31-2024, 02:12 PM
      • stylishconsultant
        un60j620dafxza - Samsung No Display Problem
        by stylishconsultant
        Hi All,
        Need help.
        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
        09-04-2024, 03:26 AM
        by sam_sam_sam
        07-01-2024, 06:34 AM
