Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
  • Diah
    • Feb 2013
    • 6565
    yes they are TVS diode.... unplug the U ribbon first and test them in Diode mode
    • joel warren
      • Jan 2025
      • 32
      which pins should I be testing on and what results should I be looking for?
      • Diah
        • Feb 2013
        • 6565
        actuality at Operation the defect will get hot ,
        by DM diode ( PeepTon) do it 1 to 4-5-6 and reserve way like wise to 2 & 3. .. write the value on paper and compare all three reading .
        • joel warren
          • Jan 2025
          • 32
          I am getting zero readings in diode mode besides continuity between pins 2&5 on each tvs diode
          • Diah
            • Feb 2013
            • 6565
            2 and 5 they are connect together ,,, if you say so mean no one defect... !! strange for me... you may telling the wrong side by right and left.... lol.... the side which u disconnect and u have picture on the rest... this disconnected side must test esd diode on it as u have 3 on each side
            • joel warren
              • Jan 2025
              • 32
              • joel warren
                • Jan 2025
                • 32
                the 1/4 of the tv with the "no picture" note is the one that has no picture and also the side with the buffer board that I was testing the tvs diodes on. I tested the diodes on the opposite side of the tv and have the same results.
                • Diah
                  • Feb 2013
                  • 6565
                  then block CKV line on the U ribbon side which it was on yours hand... you have the pins NO of CKV printed on the boards... give try
                  • Diah
                    • Feb 2013
                    • 6565
                    however it still strange for me, as 75 RU Panel even you smash it will display picture.
                    • lotas
                      • Jan 2016
                      • 4859
                      • Russia
                      #30
                      2 and 5 pins are common (GND), you need to measure between 1 and 2, between 3 and 2, 4 and 2, 6 and 2.
                      • joel warren
                        • Jan 2025
                        • 32
                        zero readings on anything.
                        • joel warren
                          • Jan 2025
                          • 32
                          I will try the tape method on CKV 1, 2, 3, 4, 5, 6, 7, 8
                          • Diah
                            • Feb 2013
                            • 6565
                            good luck... even you succeed to have the set stay on.... you can track the line over the LVDS socket at MB.... T-CON on MB do funny things too..
                            • Diah
                              • Feb 2013
                              • 6565
                              75 RU series 6 & 7 was build on buffer boards 4 ESD Diode E5 with 6 pins, this what i have under my hand before.. they were not defect but at time i block CKV 2, was no reboot. from this point i always work on MB before i missing at panel buffer boards... one time was R 100Ohn besom more than 120K .. other one one cap was absolute shorted 0
                              at the end i want to say... if with out any Jumpers on FB test points... by disconnecting U ribbon on ODD Panels size only if you got picture on the rest clear... invest yours time on MB if the ESD are fine
                              • lotas
                                • Jan 2016
                                • 4859
                                • Russia
                                #35
                                Without a jumper on the FB and with the U cable disconnected, there will be no image, since the feedback between the T-CON and the panel will be disrupted.
                                • Diah
                                  • Feb 2013
                                  • 6565
                                  he have double LVDS not one style. if this true only with FB connected come U ribbon then for me 99% T-CON on boards. or its spi firmware RU some things was better than TU or NU or MU
                                  BTW.... his issue reboot... if one LVDS disconnected an no more reboot but no picture this will never tell Panel issue
                                    • 12330
                                    • U.S.
                                    #37
                                    So if tvs diodes check ok and not getting too hot, check the other things on that board, I see some caps and a resistor.
                                      • 12330
                                      • U.S.
                                      #38
                                      Thinking I recall a while ago there was a tvs diode problem even tho it checked ok with diode testing.
                                      • joel warren
                                        • Jan 2025
                                        • 32
                                        Ok. Have any extras????
                                          • 12330
                                          • U.S.
                                          #40
                                          Extra whats? Check those 3 caps and the resistor, don't really know what else it could be, seems like it can be one of the tvs diodes, a component on that driver board the panel itself or a problem on mainboard as Diah mentioned.
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                            09-07-2024, 05:50 AM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • rui4892
                                            Samsung UE55NU8005T , rebooting , no picture , no backlight
                                            by rui4892
                                            Good morning.
                                            the original board of this equipment is in reboots without giving an image or turning on the backlight, the board code is BN94-12926P (BN41-02636), I made a copy of the flash ic1603 and ic1604, dumps attached. I tried to put other dumps (from other popis models I didn't find this board) but without success. That said, I bought a board on ebay BN94-12926A, which in principle should at least give image, even if with defects, this board turns on and responds to the command but does not give any indication of image despite the availability of VHG and VGL voltages as well...
                                            01-18-2025, 03:15 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
